Quoting LDVAviation (Reply 91): Trim is not the only major difference |
Quoting LDVAviation (Reply 91): (And, even if it were, it is not an insignificant one, given the type of customer.) |
Quoting LDVAviation (Reply 91): In any case, the true premium customer for this route knows the difference. Premium customers have gotten more sophisticated. Thank SeatGuru and all the other channels that scrutinize the various planes/products. |
Quoting BravoOne (Reply 86): I would have to question that one? Can you cite the specific airline? Certainly not DL. |
Quoting BravoOne (Reply 86): I was thinking of EDDF to KLAX and that's where the problem occured not any Lonon to Loas Angeles service. |
Quoting deltairlines (Reply 92): - it's the 76L category |
Quoting deltairlines (Reply 92): Essentially, the 76L would do a ATL-LAX-HND-LAX-LHR-JFK rotation (the LAX-LHR can only turn to the current late JFK flight) with the return being US hub-LHR-LAX-ATL. |
Quoting Deltal1011man (Reply 101): When was FRA operated on a 767? I only remember L10 and M11s. |
Quoting deltacto (Reply 102): Deltal1011man is correct. LAX-FRA started on the L15's then switched to M11 - no 763 from LAX The longest 763 route from FRA was DFW |
Quoting sevenheavy (Reply 56): There are also numerous videos and pictures out there of aircraft overtaking each other across the Atlantic. |
Quoting 1337Delta764 (Reply 67): Nope, they are real leather, regardless of what anyone wants to believe. |
Quoting Deltal1011man (Reply 103): nd Delta did have crew rest issues on the 777 when they first got them. I also seem to remember an issue with the crew rest on the L10s. but I don't remember an issue with the M11. |
Quoting Mah4546 (Reply 99): Yet Delta is, IIRC, the only major long-haul airline |
Quoting bobnwa (Reply 104): Quoting 1337Delta764 (Reply 67): Nope, they are real leather, regardless of what anyone wants to believe. No US airline uses real leather for its seats just as no car company does. They may call it leather, but it is artificially produced. |
Quoting Viscount724 (Reply 107): A few carriers are using it including Southwest, JetBlue and several other mainly LCC carriers. |
Quoting deltacto (Reply 100): But they don't say anything about the terminals at LAX Will VS continue to operate from T2 and the DL flight LAX-LHR from T5? |
Quoting DTWLAX (Reply 109): Yes. I see no reason for that to change |
Quoting laca773 (Reply 110): deltacto, are you asking if VS might move their operations to T5 for DL to handle so they are under one roof? If they were to do so, they would need to use 68 or 69 in T6 as I don't believe T5 can handle the 744, or A346s, unless it's gate 57 or 58? Please correct me if I'm wrong. |
Quoting mayor (Reply 111): What are they using, now, for 744s (they are flying 744s out of LAX, right?) |
Quoting laca773 (Reply 112): Today: 22 May 2014 VS008 @ 1655-->744 VA024 @ 2200-->346 Friday: 23 May 2014 VS008 @ 1655-->744 VS024 @ 2200-->343 |
Quoting DTWLAX (Reply 113): As for DL operating 744s to other destinations out of LAX, I believe they use gates 57 & 58 at T5 and gates 68 & 69 at T6 |
Quoting Mah4546 (Reply 13): You haven't flown the hard products if you really think it's equal to AA's J on the 77W. It's a very weak hard product, but made weak by the limitations of the 763 size more than anything else. AA's 763s use the same weak seat. |
Quoting klkla (Reply 54): Also there is nothing inferior about the 767. Business: 100% lie-flat seats with direct aisle access, excellent service, and very good catering (better than AA or UA international business for sure). |
Quoting Viscount724 (Reply 64): Most passengers aren't in J class. |
Quoting bobnwa (Reply 104): |
Quoting oc2dc (Reply 116): Hands down, fliers would prefer the AA product. . . |
Quoting goldenstate (Reply 120): This has been a truly fascinating debate about e-leather vs perforated leather vs non perforated leather, as well as DL vs AA seat trim. Just the things that came to mind when I learned that DL and VS were trading an ATL and LAX frequency. |
Quoting oc2dc (Reply 116): Quoting Viscount724 (Reply 64): Most passengers aren't in J class. You're right, most passengers aren't flying J, but J passengers are paying most of the bills. |
Quoting delta2ual (Reply 118): Quoting oc2dc (Reply 116): Hands down, fliers would prefer the AA product. . . So you're comparing F to J and saying that pax's would prefer F? No kidding! |
Quoting Viscount724 (Reply 123): But how many flights would be profitable if there were no Y class passengers? It's still an important market that carriers shouldn't ignore. |
Quoting travelin man (Reply 16): The 767s are getting old, and while I'm sure DL's maintenance is good, old planes break down and I'll take my chances on a newer A380 or 77W. |
Quoting Mah4546 (Reply 99): Yet Delta is, IIRC, the only major long-haul airline that uses cheap, un-perforated leather. "A lot of people" must not be very many if every other major airline sees fit not to use the material. |
Quoting oc2dc (Reply 124): I flew on the A321T in F which is the exact same product as the J cabin of the 77W on AA(LAX-LHR is flown on the 77W). |
Quoting delimit (Reply 126): And I am sure, given this important factor, it will show up in Delta's revenue. Oh, wai |
Quoting Mah4546 (Reply 128): What's your point? I never said anything about how it would affect their numbers. It's premium product on this plane and the 772 really sucks, that's all. It's removing a bunch of J seats from the 777s because it can't sell them. That's quite telling. Other airlines aren't doing that. |
Quoting Coronado (Reply 130): Average Completion Factor Last 12 mos. 99.1% Average Completion Factor excluding outlier WX (weather cancellations due to severe winter storms) months of Jan 2014 and Feb 2014: 99.8%. And I am sure that analyzing the two next lowest months of June and July 2013 there was probably a high incidence of weather cancellations during those two months--severe thunder-storms, lightning storms and tornado's have a way of disrupting operations. There is probably a small number of cancellations due to a crew being out of position. In summary, it does not strike me that operating an ''experienced'' fleet seems to slow down Delta's operational reliability! |
Quoting travelin man (Reply 132): And take that 0.9% "incompletion" factor and multiply it across the number of flights Delta has -- how many tens of thousands of flights is that? |
Quoting questions (Reply 127): Isn't that going to change? I thought I read somewhere that AA's J product is changing, i.e., the seats on the first 77W's (which are similar to CX and DL (744 and A330)) were installed because the planned new J product was not yet available. |
