Quoting g500 (Reply 1): Charlotte is sandwhiched between PHL, DCA and MIA. I still don't believe AA/US is going to maintain CLT as a hub forvever. My guess, in a couple of years they'll start escaling back CLT |
Quoting washingtonflyer (Thread starter): Charlotte Douglas International Airport plans to start work on a new concourse next spring, with eight to 12 domestic gates – not a separate international terminal the airport had previously considered. |
Quoting g500 (Reply 1): Charlotte is sandwhiched between PHL, DCA and MIA. I still don't believe AA/US is going to maintain CLT as a hub forvever. |
Quoting Polot (Reply 4): CLT will always be a hub. Out of all the ones you mentioned, CLT is the best to serve the Southeast. PHL is too far north, MIA too far south, DCA too far north and slot constrained. |
Quoting MaverickM11 (Reply 6): I'm still not clear how CLT needs more infrastructure in an environment where AA's costs are higher than US', and US' fare structure is out the door. Wouldn't they be lucky to hold on to what they have, let alone grow? |
Quoting Polot (Reply 4): CLT will always be a hub. Out of all the ones you mentioned, CLT is the best to serve the Southeast. |
Quoting Cubsrule (Reply 8): I don't necessarily disagree, but CLT needed more gates yesterday |
Quoting g500 (Reply 1): Charlotte is sandwhiched between PHL, DCA and MIA. |
Quoting Ryefly (Reply 18): Im flying CLT-BCN and returning from FCO to CLT next May. If the flights are non-stop on AA that would be great, but if they are not I will likely book Delta thru ATL vs dealing with the northeast delays or flying way out of the way to Miami in order to connect. |
Quoting Mah4546 (Reply 15): CLT officials have obviously been given the message, probably directly from AA, that international growth is not coming anytime soon. |
Quoting david_itl (Reply 20): So CLT-MAN seems to be sticking around for a bit longer than people would expect. Odd for a secondary European city to have 4 daily services from a major carrier. The latter article also says that most passengers on the route will be coming from the States. |
Quoting justplanenutz (Reply 16): Given that these are domestic gates, I am surprised they are building an entirely new concourse rather the expanding B as previously planned. |
Quoting D L X (Reply 14): You have to realize, CLT is closer to ORD than it is to MIA, and no one would ever cite CLT's proximity to ORD as a reason to dump it. There is PLENTY of room for CLT as a hub in that big a gap. |
Quoting USAirALB (Reply 21): Regardless of what happens, something DOES need to be done regarding gate space for International flights at CLT. Today's TATL has several flights departing from Domestic Concourse B. These gates were not designed for international flights, and there is no waiting room around any of the gates, as they were designed for 737s/A32Xs. |
Quoting PITrules (Reply 25): Quoting justplanenutz (Reply 16): Given that these are domestic gates, I am surprised they are building an entirely new concourse rather the expanding B as previously planned. I'm wondering the same thing. The concrete ramp is already laid and it would be much easier for connections. |
Quoting apodino (Reply 27): Part of the problem is if you extend the B concourse out too far, as busy as the CLT ramp gets with planes taxiing, you would take up some of that space taxiing, which already is at a premium, and all you would do would be create more bottlenecks. Look what happened at the E gates after they expanded those? |
Quoting ExL10Mktg (Reply 26): |
Quoting g500 (Reply 1): I still don't believe AA/US is going to maintain CLT as a hub forvever. My guess, in a couple of years they'll start escaling back CLT |
Quoting DLPMMM (Reply 29): Quoting ExL10Mktg (Reply 26): I am sorry, but I have to disagree with you about JFK, EWR, and PHL being just as acceptable for connections as CLT for most of the Southeast. I live in the Southeast (but not the CLT area) and travel internationally 5-6 times per year. (AA Exp and was also DL Diamond until this year) PHL, JFK, and EWR I avoid like the plague whenever possible...which is usually. The bags miss connections too regularly, baggage claim is slower than sin, delays are terrible, and lines and CBP are way too long. It is also nicer to have an 8 hour flight to Europe and get some sleep, than a 2 hour+ flight to the northeast, then only have 6 hours to Europe and the associated jet lag. |
Quoting ExL10Mktg (Reply 32): At the end of the day, the total travel time from the South to Europe should be about the same regardless of the hub (CLT or the other two) depending on how close the connection times are and that's really all most people look at. |
Quoting justplanenutz (Reply 16): Given that these are domestic gates, I am surprised they are building an entirely new concourse rather the expanding B as previously planned. Are they going to build the new landside component of the international terminal too? And the connector? That is a going to be a massive hike from the high-E gates to these. |
Quoting Cubsrule (Reply 33): Not really. Because of the airfield congestion at PHL, EWR and (particularly) EWR |
Quoting ExL10Mktg (Reply 35): In any case, the difference in actual flight time is less than an hour from either PHL or JFK vs CLT. While more sleep is better than less, that difference shouldn't be a deal breaker for most people, even if it is for you (which is fine -- we all have different priorities!) |
Quoting Cubsrule (Reply 33): Not really. Because of the airfield congestion at PHL, EWR and (particularly) EWR, there's a lot of schedule pad at those places. Being number 47 for takeoff at JFK and taxiing for an hour doesn't really let me (or most folks) sleep for that hour. The nice thing about ATL and CLT is that, compared to the block time, you spend a lot more time in the air. A bad line for takeoff at either of those places--even during the late afternoon rush--is 8 or 10 aircraft. Not so further north. |
Quoting jfklganyc (Reply 39): I always laugh over statements that discuss the lack of airfield congestion in CLT. |
Quoting jfklganyc (Reply 41): If, for some unfortunate reason, you need to go to D or E...you have to cut through the lower ramp on one frequency to the north hold line. That is the single lane alley for traffic in and out of the north ramp. Not unusual to come nose to nose with aircraft there. Then the north ramp fun begins! |
