Quoting xiaotung (Reply 1): Why are DPS flights not affected? I would have thought DPS-Australia routes would be the first ones affected. |
Quoting 777Jet (Reply 2): I doubt this will reach the 2010 Eyjafjallajökull level |
Quoting AngMoh (Reply 3): I don't understand why DRW is closed right now. It is at least 1000-1500km away from the volcano and the eruption happened about 15 hours ago. It is just not possible to be seriously affected right now. |
Quoting BHMNONREV (Reply 5): Neither do I. We received an alert from our HR department this morning informing of all the cancellations, save for Perth then an hour later Perth was gone too. While the reports say there is very fine ash in the atmosphere it is not enough to affect air quality |
Quoting melpax (Reply 8): The rental car agencies in Darwin must be making a killing with people driving to Alice to catch urgent flights. |
Quoting melpax (Reply 8): Have a friend stuck up in Darwin at the moment - not able to fly back down to MEL until Tuesday at the earliest. Ironically her brother is also stuck in Bali! The rental car agencies in Darwin must be making a killing with people driving to Alice to catch urgent flights. |
Quoting AngMoh (Reply 3): Just relative: my brother-in-law was in Bandung earlier this year when Mt Kelud erupted. Have a look at the photographs: |
Quoting AngMoh (Reply 3): The airport was closed. But 2-3 days after these photographs were taken, operations were starting again. He took the train back to Jakarta but if he just waited 12 hours he could have flown back (Garuda) and arrived earlier. Bali & Lombok airports never closed even though they were nearby. Jetstar, Virgin and QF cancelled all flights to Bali while most Asian airlines continued to fly. |
Quoting AngMoh (Reply 3): Earlier this year there was also a major eruption in Sumatra and there was no major impact other than some rerouting of flights. That eruptions was closer to KL and SIN than this one is to DRW and more severe and longer in duration. |
Quoting RickNRoll (Reply 6): It's the very fine ash that is enough to wreck an engine. They can't predict exactly where the ash will go, it is moving at 150kts, apparently. DRW is a long way from anywhere if you are flying from most Australian airports, so by the time you are arriving, if the airport is closed, diversions will be to somewhere small in the middle of nowhere. |
Quoting mandala499 (Reply 11): DPS-PER isn't in the path of the ash. The dispersal projection have it move as far south west as Curtin, but not affect the flights DPS-Australia except for DPS-DRW. DPS-BNE was routed through Curtin then waypoint to waypoint until an airway clear of the ash projection. DPS-SYD/MEL/ADL would be less affected. |
Quoting xiaotung (Reply 12): It looks like all flights into and out of DPS Saturday evening have been either cancelled or delayed to Sunday morning at this stage. |
Quoting RyanairGuru (Reply 9): Unless you tag-team the driving and don't stop longer than to go to the toilet (in which case you might be able to do it in 20 hours), that drive is realistically 2 full days with only one driver. They'd be better off waiting! |
