Quote: “At the end of this year, beginning of next year, we will re-engage with Airbus on this aeroplane [the A350]. We will also engage with Boeing about the 787.” “When the aircraft [the A350 and 787] are mature, they will be better defined in terms of performance, fuel burn,” he added. |
Quoting KarelXWB (Reply 2): Mr Clark said the A380 and 777X will remain the backbone of the fleet, but said there is room for another aircraft carrying between 250 and 300 passengers on regional routes. |
Quoting Karadion (Reply 4): That sounds to me that would be the 789 would fit into this category or alternatively the A358? The 787-10 or A359 even A35J seems to me that it would be too big for those kind of routes. |
Quoting Karadion (Reply 7): We'll find out in three weeks. |
Quoting mffoda (Thread starter): They are considering smaller A/C for regional use later this year or early next year. |
Quoting Stitch (Reply 5): Still thinking we're going to see a top-up 777-300ER order (as they are used regionally). |
Quoting Stitch (Reply 5): Realistically it would be the 787-10 or A350-1000. |
Quoting KarelXWB (Reply 8): I doubt it. Tim Clark said talks about an A350/787 order would start at the end of the year of early next year. It's way too early to tell. |
Quoting Flying-Tiger (Reply 3): Anyone care to expain me why EK first (intends?) to cancel their 70 Frames order just to reconsider to order them again? |
Quoting Stitch (Reply 5): |
Quoting KarelXWB (Reply 12): That said, EK probably had low launch prices because they were an early customer and I doubt they can get a better price taking 7-8 years inflation into account. Maybe they are just re-looking their fleet strategy in this segment. |
Quoting phxa340 (Reply 13): Agreed. You simply don't cancel an order of 70 frames that you probably got at very favorable terms then reorder at a later date. |
Quoting lightsaber (Reply 9): I would imagine EK would also look at the A330NEO (right empty weight for the payload). |
Quoting dtw2hyd (Reply 15): I guess over next few days there will be news about A350R. |
Quoting Zeke (Reply 18): A 777-300ER is a "dumb" aircraft to use only for regional work, empty they are up around 170t. You could fill a 787/A350 and fly it regionally and still be below the empty weight of a 777-300ER, while saving around 3t an hour in fuel. |
Quoting Stitch (Reply 22): Looking at EK's schedule, they are currently using 777-300ERs on "regional" routes, even if that is "dumb" of them. I will hazard a guess that they are seeing high enough passenger and cargo load factors that the revenue at least covers the extra fuel burn, if not exceeds it. |
Quoting Zeke (Reply 23): Does not matter how you dress it up, the 777-300ER is a very poor choice for regional only flying. |
Quoting Zeke (Reply 23): What you are referring to is using a 777-300ER that is flying 12-16 hrs a day long haul for short haul between long hauls, they are taking advantage of capacity that would otherwise be sitting idle. Those aircraft were not purchased for regional work. |
Quoting RayChuang (Reply 25): My guess: EK will order a lower MTOW 787-9--with the range reduced to around 6,500 nautical miles--specifically for regional routes from DXB, for example flights to Saudi Arabia, other parts of the Persian Gulf and Iran. |
Quoting Stitch (Reply 26): Fine, then they buy more 777-300ERs and rotate them on ULH, LH and NLH missions as they (evidently per your statement) currently do with their two and three class frames. |
Quoting seabosdca (Reply 27): I have to confess I find the whole thing baffling. First Tim Clark wants nothing but the biggest aircraft on the market (777-300ER, 777-9X, A380-800), so he cancels his A350s. |
Quoting IslandRob (Reply 29): A lot of members repeat this as though it's a known fact. We don't know that EK only wants the biggest planes... |
Quoting justloveplanes (Reply 20): I am guessing he is highly interested in the regional economics of the 7810 vs the 359. 7810 I would guess has the passenger revenue / cost advantage while the 359 better hot performance with a lot of cargo. So if EK doesn't fly a lot of regional cargo, I think it's the 7810 for this. |
Quoting Stitch (Reply 30): Quoting IslandRob (Reply 29): A lot of members repeat this as though it's a known fact. We don't know that EK only wants the biggest planes... Mr. Clark has made quite a number of statements in the aviation and general press noting that he felt 300 seats in an airframe was about the minimum he felt would work for the airline's current and future route structure. |
Quoting IslandRob (Reply 32): Which still doesn't explain his decision to cancel the A359 and A351, and would not rule out the 787-10. Regards. -ir |
Quoting RickNRoll (Reply 31): Perhaps something like this is happening. The 777X has yet to be finalised. Could be that Boeing and Emirates are working on some tie in for 787 and 777X for a special deal. |
Quoting seabosdca (Reply 34): Could be. A big 787-10 order could also be a nice distraction from a shrinkage of the 777X order (which seems possible to me). Perhaps this is a clever way for Mr. Clark to reduce the capacity on order. |
Quoting Stitch (Reply 33): Of the three frames, the 787-10 would probably be best option as it offers more space than the A350-900 with probably similar OEW. And while a bit smaller than the A350-1000, it should be a fair bit lighter in OEW. So fuel burn should be lower on the 787-10 than either A350. |
Quoting Stitch (Reply 22): they are currently using 777-300ERs on "regional" routes, even if that is "dumb" of them |
Quoting seabosdca (Reply 27): I have to confess I find the whole thing baffling. |
Quoting seahawk (Reply 41): Well only if A350 is just a place holder for A330NEO, as it has not be launched yet. And if he talks about ordering the NEO he would practically launch it. Then the whole move would start to make sense. |
Quoting phxa340 (Reply 13): Agreed. You simply don't cancel an order of 70 frames that you probably got at very favorable terms then reorder at a later date. There is more at play , whether that be a 77W top up order in the works or A330neo order (don't really see the A330 happening however). |
Quoting Stitch (Reply 5): It doesn't strike me as sensible to drop the A350 order only to reconsider it later. He could have deferred deliveries. |
Quoting KarelXWB (Reply 40): Quoting seabosdca (Reply 27):I have to confess I find the whole thing baffling.I don't think you are the only one. |
Quoting Prost (Reply 21): The cancellation of their previous A350 order may have had time parameters included that made cancellation the wisest choice. It doesn't make sense buying something you aren't sure you need, even if you got a good price for it. |
Quoting KarelXWB (Reply 40): Quoting Stitch (Reply 22):they are currently using 777-300ERs on "regional" routes, even if that is "dumb" of themZekes's point is that A350s and 787s would do the same job much better. That doesn't make the 77W a bad aircraft. |
Quoting KarelXWB (Reply 2): Mr Clark also rejected some analysts’ suggestions that Emirates had dropped its A350 order because it was having to rein in expansion plans due to the economic slowdown in emerging markets. |
Quoting seahawk (Reply 38): I think it is will be a 787-1000 order which would turn the whole thing into an epic win for Boeing. From 70 A350 to 777X+787 and probably more of both, that is clear vote of confidence into the Boeing products and slap in the face of the A350 |
Quoting KarelXWB (Reply 40): Zekes's point is that A350s and 787s would do the same job much better. That doesn't make the 77W a bad aircraft. |
Quoting frigatebird (Reply 44): Agreed Karel. But I think Stitch' point is that EK does use the 77W on regional routes. Whether this is wise or not is up to EK. And it is also how you define 'regional'. EK's standards are not the same as others... EK flies the A380 also on many routes around 3000NM, and makes quite a bunch of money with it. And there are more airlines using the 77W or A380 on these kind of stage lenghts. |
Quoting RickNRoll (Reply 45): I doubt anyone lacks confidence in Boeing products. The A350 is still a good aircraft, it looks like it doesn't suit EK with their business model. Just as the A380 does suit their model, but not any other airlines to the same extent. |
Quoting Zeke (Reply 46): You are not going to order those aircraft however specifically for regional routes. |
Quoting dtw2hyd (Reply 47): Do anyone think EK will pickup 11 significantly overweight teen B788s, assuming Boeing offers very good deal. |
