Quoting musapapaya (Thread starter): It looks weird to me that a 'water pressure' issue lead to a overweight landing, am I right? |
Quoting WildcatYXU (Reply 1): I'm surprised the A380 would be still overweight after almost 40% of the planned distance flown. |
Quoting musapapaya (Reply 6): It still does not explain why the crew did not ensure the landing weight is less than maximum landing weight before landing. |
Quoting speedbored (Reply 5): To be even more pedantic, given that the water was being carried by an A380 at the time, both are probably correct |
Quoting WildcatYXU (Reply 9): BTW, why did they send two 767's to pick up the pax from SNN instead of sending a fresh crew there? |
Quoting WildcatYXU (Reply 9): Let's speculate a bit and let's hope some of the pilots here will correct us. If they were indeed near MZFW, they could have only about 4 hours worth of fuel in tanks to get under MLW. Since they had some 7 hours of flight ahead of them and they can't land of fumes, I'd estimate they had about 9 hours worth of fuel aboard when they arrived to YYZ area. So they would have to dump about 5 hours worth of fuel - roughly 60 tons. Which is not small change either and takes some time, so we don't know if the crew wouldn't time out anyway. |
Quoting musapapaya (Reply 10): Thats a lot of maths but knowing Canada is a rather empty country, can they not just dump the fuel..... I would have thought 'loss of water pressure' does not warrant 'land ASAP' on the ECAM actions. |
Quoting WildcatYXU (Reply 11): If they flew the GC route that night, they would be over sparsely populated area almost until the final approach. But isn't the dumped fuel supposed to evaporate before it hits ground anyway? |
Quoting musapapaya (Reply 6): It still does not explain why the crew did not ensure the landing weight is less than maximum landing weight before landing. This is causing them quite a bit of extra money (and to send 2 767 from LHR to SNN to pick the passengers up!) |
Quoting WildcatYXU (Reply 9): Let's speculate a bit and let's hope some of the pilots here will correct us. If they were indeed near MZFW, they could have only about 4 hours worth of fuel in tanks to get under MLW. Since they had some 7 hours of flight ahead of them and they can't land of fumes, I'd estimate they had about 9 hours worth of fuel aboard when they arrived to YYZ area. |
Quoting Zeke (Reply 13): The pilot report the overweight landing in the technical log, mechanics on the ground download the data from the aircraft, it is sent off for analysis. If the analysis of the electronic data suggests a low rate of descent, the aircraft can dispatch again rather quickly. |
Quoting Zeke (Reply 13): The pilot report the overweight landing in the technical log, mechanics on the ground download the data from the aircraft, it is sent off for analysis. |
Quoting Tristarsteve (Reply 16): So two pilots went to collect the aircraft (with baggage still on board). |
Quoting musapapaya (Reply 10): I would have thought 'loss of water pressure' does not warrant 'land ASAP' on the ECAM actions. |
Quoting Tristarsteve (Reply 16): There was no full A390 cabin crew available. |
Quoting StTim (Reply 19): One would hope the flight crew for the A380 positioned to Shannon on one of the 767's and so likelyhood is that the baggage made it back to Heathrow to meet up with the passengers. |
Quoting a320fan (Reply 22): Why didn't they just fly them back in on the A380 rather than have 2 extra aircraft fly out to SNN |
Quoting Zeke (Reply 2): they lost portable water to the galleys and toilets, this can happen for example if the portable water service panel door detaches inflight. |
Quoting Tristarsteve (Reply 24): On the BA A380 (and others??) there is a problem with the potable water filling system, so that the water system circuit breakers need to be tripped to fill the water tanks. These need to be reset after filling, before flight. This was done in Toronto! |
Quoting barney captain (Reply 25): I wonder what the cost of replacing 60t of fuel is compared to an overweight landing inspection (assuming one was even needed). |
Quoting Tristarsteve (Reply 16): There was no full A390 cabin crew available. So two pilots went to collect the aircraft (with baggage still on board). |
