justloveplanes
Issue In UA Cockpit 777 Diverts From HI To Midway
Fri Jul 11, 2014 7:25 pm
A Guam Bound flight from HNL was diverted to Midway after fire was detected in the cockpit.
Instrumentation was lost including:
Radar
Radio Comms
Flying blind and cockpit gear going out one by one progressively.
Landed in Midway. Passenger luggage still stuck on a tiny runway in Midway since Midway has no gear for extracting luggage from a 777.
Serious stuff and not a whiff on the news I could see.
Just talked to a passenger (fellow UA million miler). He is on the ground waiting for his replacement flight.
Lucky things turned out OK. Pilots must have been pretty sharp.
barney captain
Fri Jul 11, 2014 7:28 pm
Wow. Do you have a flight number?
Southeast Of Disorder
KELPkid
Fri Jul 11, 2014 7:29 pm
Quoting justloveplanes (Thread starter):
Seriously? There's enough demand between GUM and HNL for a 777? What happened to Air Mike and the 737's?
DocLightning
How did you talk to him? Midway is a rock in the middle of a lot of water. It's barely large enough for the runways it has. There are some researchers and a whole bunch of birds there. Have they been stuck out there for five days?
-Doc Lightning-
-Carl Sagan
planespotting
Fri Jul 11, 2014 7:32 pm
Looks like United 201
http://flightaware.com/live/flight/U...1/history/20140711/0015Z/PHNL/PMDY
Just happened yesterday. According to the graph estimates it took them about 80-90 mins to get on the ground after they started descending, as they were pretty far from Midway at the time.
[Edited 2014-07-11 12:38:08]
Do you like movies about gladiators?
N62NA
Fri Jul 11, 2014 7:43 pm
Just reading the subject line, I thought it had diverted to MDW
ripcordd
Fri Jul 11, 2014 7:56 pm
this is a great web site about midway
http://peteatmidway.blogspot.com/
ScottB
Fri Jul 11, 2014 8:01 pm
Things must have been getting a bit hairy from looking at the flightpath on flightaware; it appears that they initially decided to return to HNL and then chose to divert to MDY. And it looks like they were still quite a way from MAJ.
mwhcvt
Fri Jul 11, 2014 8:02 pm
Going to be interesting to see this one develop/investigated...I wonder if it will cause any ideas/theories on that big mystery of the year...glad that it has landed safely, and in a place I would love to visit
Must think up a new one soon, slow moving brain trying to get into gear ;)
SpaceshipDC10
Fri Jul 11, 2014 8:04 pm
Quoting KELPkid (Reply 2):
Even before the merger CO had direct flights between HNL and GUM as well as Air Mike islands hopper.
rfields5421
Fri Jul 11, 2014 8:06 pm
UA flew in another aircraft which landed 5 1/2 hours later.
http://flightaware.com/live/flight/UAL2068
The extra aircraft spent about an hour on the ground and returned the pax to HNL
http://flightaware.com/live/flight/UAL2104
Pretty quick dispatch and return of a replacement B777.
Not all who wander are lost.
BoeingGuy
Fri Jul 11, 2014 8:07 pm
Quoting ScottB (Reply 7):
The procedure for smoke that is not visually confirmed to be extinguished is to land at the nearest suitable airport - period. Looks like they did so. If this incident was another Swissair 111 or Air Canada 797 (which it does not appear to have been) then minutes could have made a difference. The crew did exactly the right thing.
I'd rather be sleeping on a cot on a concrete floor in the likes of MDY or CDB then having tried to make it HNL or ANC with nice hotels, but end up dead, if it were that kind of situation. The crew likely had no way of knowing at the time.
Nice job on their part. Anyone know what caused the smoke and apparent instrument failure?
dakota123
Fri Jul 11, 2014 8:16 pm
If the description of consequences is accurate maybe the other shoe has dropped (Malaysian 370)...
“And If I claim to be a wise man, well surely it means that I don’t know”
ScottB
Fri Jul 11, 2014 8:23 pm
Quoting BoeingGuy (Reply 11):
Oh, I totally get that. The point being that the initial decision made by the pilots was to return to HNL, but after what appears to be about half an hour of flying a return course to HNL, the situation became more serious as they chose to divert to MDY. If things had looked bad initially, they likely would have immediately diverted to MDY which was only about an hour's flying time away.
bchandl
Quoting DocLightning (Reply 3):
With a telephone?
There is comm equipment on the island and they likely tried their best to accomondate the pax to reach out to people.
No, it happened yesterday and they were picked up by a fresh plane a few hours later.
bchandl
SonomaFlyer
Fri Jul 11, 2014 8:30 pm
Quoting ScottB (Reply 13):
What proof do you have that they actually made a decision to return to HNL? You can't rely on the Flightaware track as they've been known to be very wrong. There is no quote from anyone I see at UA confirming that they were returning to HNL.
The procedure is to get the airplane on the ground ASAP. If the runway can accommodate a 777, they land. That strip has taken a 744 before from DL which had a cracked windscreen so the runway itself is not a problem.
BoeingGuy
Fri Jul 11, 2014 8:35 pm
I don't know enough about what was going on. It's possible that they could have gotten some EICAS messages of system failures and turned back to HNL. Then when the smoke appeared, the turned to MDY. It's also possible that Flight Aware doesn't show it correctly.
I don't have enough information to know if they correctly followed the "Smoke, Fire or Fumes" procedure correctly from the start.
ScottB
Fri Jul 11, 2014 8:46 pm
Quoting SonomaFlyer (Reply 15):
I realize that flightaware isn't an authoritative source, which is why I qualified my statement with "it appears that" (based on the track in flight aware. That said, from examining the track log data, the data which isn't from flightaware itself doesn't appear to be obviously unreliable either.
Quoting BoeingGuy (Reply 16):
I wouldn't infer from the flight path that they had or hadn't followed procedure correctly. IMO it is far more likely that something failed which led to the decision to turn back to HNL, followed by a smoke/fire/fumes indication which would have required the diversion to MDY
[Edited 2014-07-11 13:50:00]
hivue
Fri Jul 11, 2014 8:55 pm
Radar
Radio Comms
Any corroboration/confirmation? What's your source? That's pretty serious sounding.
727LOVER
Fri Jul 11, 2014 8:58 pm
Quoting N62NA (Reply 5):
777 landing @ MDW? That would have been a sight !!
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
hivue
Fri Jul 11, 2014 9:00 pm
If true, how on earth did this avoid the MSM always-breaking news cycle?
BoeingGuy
Fri Jul 11, 2014 9:10 pm
Quoting ScottB (Reply 17):
Like in my previous paragraph when I stated:
Incidentally, the "Smoke, Fire or Fumes" checklist is what's called "unannunciated". There means there is no crew alerting "indication". The indication is that you smell it or see it.
There are some Fire Warnings like Cargo Fire, Engine Fire, Crew Rest Smoke, etc with their own checklists, but in a case like smoke on the flight deck or a galley oven or something, there is no airplane crew indication.
bchandl
Fri Jul 11, 2014 9:18 pm
No you can't rely on it, but the track makes sense, and the odds that an error yields a track that could be a logical conclusion seems quite low to me.
karadion
Fri Jul 11, 2014 9:19 pm
It isn't the first time a plane that large has landed at Henderson Field. Delta Air Lines flight 277 (744) had to make an emergency landing due to a crack windshield back in 2011.
http://www.staradvertiser.com/news/2...747_forced_to_land__at_Midway.html
[Edited 2014-07-11 14:19:44]
iahcsr
Fri Jul 11, 2014 9:20 pm
Ship 2510 a 777A for those who track such things.
747megatop
Fri Jul 11, 2014 9:41 pm
Radar
Radio Comms
Too early to say without the incident report for this and without the black boxes & incident report for MH 370; but can't help wonder if something remotely similar happened to MH 370 but far more serious. Only time will tell i guess. Thankfully everyone on this flight is in one piece thanks to prompt action by the flying crew.
hivue
Fri Jul 11, 2014 9:48 pm
Quoting iahcsr (Reply 24):
777A
I don't recognize that ICAO designation.
redzeppelin
Fri Jul 11, 2014 9:51 pm
Quoting hivue (Reply 26):
Quoting iahcsr (Reply 24):777A
777-200, non-ER/LR.
jetfuel
Fri Jul 11, 2014 9:52 pm
Plane was delayed on the ground in HNL over 4 hours with mechanical issues before leaving HNL
Where's the passion gone out of the airline industry? The smell of jetfuel and the romance of taking a flight....
747megatop
Fri Jul 11, 2014 10:35 pm
Henderson Field airport information for those who are interested - http://www.airnav.com/airport/PMDY
mcg
Fri Jul 11, 2014 11:06 pm
I saw "Midway" and thought MDW.
7BOEING7
Fri Jul 11, 2014 11:29 pm
Hopefully they didn't take out any "goonie birds" that like to frequent the runway.
justloveplanes
Fri Jul 11, 2014 11:33 pm
Quoting hivue (Reply 18):
A passenger onboard. He is someone used to handle information of this type, so I am guessing he got it from one of the pilots and yes it was serious sounding. Ongoing degradation of systems was how it was described to me.
Quoting hivue (Reply 20):
I expect it to get there. Midway obviously an emergency of some magnitude.
rfields5421
Sat Jul 12, 2014 12:03 am
It will show up on Saturday or Sunday - after the media has some passengers to interview.
Quoting SonomaFlyer (Reply 15):You can't rely on the Flightaware track as they've been known to be very wrong. There is no quote from anyone I see at UA confirming that they were returning to HNL.
Midway is an ETOPS diversion airport. However, there is still coordination required. If it is gooney bird season at MDY - landing any aircraft can be risky.
Crews will of course try to take a sick aircraft back to a maintenance base especially if it is the origin of the flight if the situation does not require an immediate landing.
My personal opinion is that the crew had indications of problems which led them to decide to turn back to HNL. Which escalated to fire/ smoke warnings in a few minutes making an immediate landing necessary.
garpd
Sat Jul 12, 2014 12:06 am
Quoting mwhcvt (Reply 8):
I win! I told my friend someone will link this to MH370 within 10 posts!
Seriously though. There is no evidence the two are in any way similar, other than involving 777s!
arpdesign.wordpress.com
shengzhurou
Sat Jul 12, 2014 12:13 am
Sheng Zhu Rou
citationjet
Sat Jul 12, 2014 12:17 am
From avherald:
A United Boeing 777-200, registration N210UA performing flight UA-201 (dep Jul 10th) from Honolulu,HI (USA) to Guam,MP (USA), was enroute at FL350 over the Pacific Ocean about 300nm southsouthwest of Midway Islands,UM (USA) and about 850nm west of Honolulu when the crew decided to return to Honolulu due to smell of smoke on board. The aircraft descended to FL300 for the way back. About 10 minutes later haze was observed in the cabin prompting the crew to turn north and divert to Midway Islands. The aircraft dumped fuel and landed safely in Midway about one hour after turning around.
A Passenger reported there was a "problem with one of the wings" and the cabin became smokey. Multiple passengers reported the aircraft had suffered technical problems involving a burning smell in the cockpit prior to departure and departed Honolulu with a delay of about 4 hours as result. Passengers tweeted that the aircraft dumped fuel on the way to Midway.
There is a report on the Internet telling that the aircraft lost transponder, radios and other systems one by one, however, radar data indicate the transponder worked until touchdown.
A replacement Boeing 777-200 registration N779UA positioned to Midway as flight UA-2068 and returned the passengers to Honolulu as flight UA-2104 delivering the passengers back to Honolulu about 14 hours after their departure from Honolulu.
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,73G,738,739;741,742,743,744,747SP;752,753;762,763;772,773,788.
LittleFokker
Sat Jul 12, 2014 12:22 am
CO flew a daily 764 HNL-GUM round trip (the aircraft would then do a GUM-NRT round trip before returning to HNL). This missing is now being done by a 777. Never had a problem filing up that plane with cargo.
Still there and thriving. See the thread about adding GUM-ICN and GUM-PVG service.
"All human activities are doomed to failure." - Jean Paul Sartre
777Jet
Sat Jul 12, 2014 12:26 am
Quoting dakota123 (Reply 12):
That's what I was thinking. Glad everything turned out okay though...
bchandl
Sat Jul 12, 2014 12:33 am
Quoting 777Jet (Reply 38):
Were they both 777-200?
Interesting connection, but we may be drawing correlations because we want a correlation for answer's sake.
777Jet
Sat Jul 12, 2014 12:45 am
Quoting bchandl (Reply 39):
Yes, but FWIW the MH bird was a -200ER and the UA bird was just a -200 (non-ER) IIRC...
I agree. The only reason a correlation was drawn was because of the MH370 cockpit fire theory proposed by some and the fact that this incident was a 777 with the term 'fire in cockpit' in the headline... Interesting to see what will be made of it nonetheless...
SonomaFlyer
Sat Jul 12, 2014 1:01 am
The HNL-GUM sector is a big money maker. Between govt contracts/military families and cargo, they do nicely flying a 777.
GentFromAlaska
Sat Jul 12, 2014 1:18 am
Here's a pix showing the two 777 side-by-side http://abcnews.go.com/blogs/headline...land-after-burning-smell-reported/
By coconut husk phone of course. Contrary to popular belief there was a cell tower on Midway. They also use satellite phones. At last check it's a little bit more than Gilligan's Island. There are about 100 residents who reside on the Atoll and a whole lot of bird poop. The bird outnumber humans by about fifty to one. If you go there take a hat. A school of about 300 dolphins also call the island waters home as do sea turtles.
[quote=DocLightning,reply=3]Midway is a rock in the middle of a lot of water
Actually the correct term is Atoll. Coral Reef works too.
At roughly two and a half miles It's a little bit larger than one might think if you have good shoes you can wade a considerable distance in shallow water. There is also a tourism component. We flew maritime inspectors out to Midway from HNL twice a year. The U.S. National Park Service keeps employees out there too. The FAA and or their contractors travel out there to inspect the runways.
Here's what tripadvisor.com says about Midway Island http://www.tripadvisor.com/Travel-g2...ii:United-States:Midway.Atoll.html
There have been quite a few diversions to Midway Island; most recently a DL 747 in 2011
Man can be taken from Alaska. Alaska can never be taken from the man.
Revelation
Sat Jul 12, 2014 1:37 am
Quoting rfields5421 (Reply 33):
Compared to a cockpit fire? I know gooneys are big birds, but I think one takes the chance on a bird strike, given one isn't demanding much thrust from the engines when landing.
DocLightning
Sat Jul 12, 2014 1:49 am
Quoting bchandl (Reply 14):
With a telephone?
They let 300-odd people use the phone? Or is there cell service out there?
How does an airline handle a situation like this? The 777 that went out would have to have enough fuel for the return trip, right? Would that cause problems for landing? What sorts of facilities are there on the island to shelter that many people from, say, inclement weather if an aircraft had to land and be evacuated in the middle of one?
-Doc Lightning-
-Carl Sagan
Revelation
Sat Jul 12, 2014 1:54 am
Quoting DocLightning (Reply 44):
They put their best people on to the case:
chrisair
Sat Jul 12, 2014 1:57 am
Quoting GentFromAlaska (Reply 42):
Tourism for whom? The govt workers or can I go there?
Speaking of vacationing on a remote rock in the middle of an ocean: CXI sounds like a great place to vacation where nobody from my office can bother me.
rfields5421
Sat Jul 12, 2014 2:18 am
Quoting Revelation (Reply 43):
Back in the late 60s, an EC-121 of my first US Navy squadron hit several birds at Midway while attempting to land, knocking out two engines on one wing. The Flight Engineer told me he was sure they were going down short of the runway, but barely made it.
bchandl
Sat Jul 12, 2014 2:49 am
Quoting 777Jet (Reply 40):
Yeah but notice how these pilots were able to communicate their problem with someone on the ground. MH370 made no comms of any type.
That fact just doesn't add up at all with any legitimate fire/emergency issues that may have come about.
But all of that is off topic, so...
bchandl
FlyDeltaJets
Sat Jul 12, 2014 3:30 am
We activated our emergency response, sent a rescue aircraft and got our passengers and crew out of there as quickly as possible.
The only valid opinions are those based in facts
Users browsing this forum: 777luver, alggag, amc737, Baidu [Spider], bennett123, Boiler905, cskok8, dk44, Gavros33, hyd09l27r, Jos227, kdaman, Pottok, Qantas737, QF41, shamrocka330, sise1989, SIVB, SYDSpotter, T54A, VolvoBus and 199 guests
