Quoting Aloha717200 (Reply 265): Getting away from the politics of this thread, I've noticed a few things after looking over much of the video and images coming out of the crash site. What I'm about to discuss is kind of a forensic discussion and if you'd be bothered by an honest examination of the factors that lead to injuries, you might want to skip this post. You've been forewarned! Firstly...I believe this aircraft may have been inverted when it crashed. It's just a theory, but looking at the orientation of the seats at the main impact site, nearly all are upside down. Warning, bodies visible in this shot: http://i.huffpost.com/gen/1916090/thumbs/o-DOMINIQUE-FAGET-900.jpg?3 Second, as we've already observed, the location of the Vstab and Hstab sections indicates that the aircraft lost its tail after the missile either impacted or exploded near the fuselage. The accounts of bodies hitting the ground AFTER the plane impacted the ground, most of which were still in their seats, as well as huge sections of fuselage sidewall landing in nearby villages, indicates that as the aircraft went down, its contents were being strewn laterally and behind into the slipstream. I believe then that this indicates not only that the tail section separated, but that at least one side of the airframe was also destroyed in the strike. The bodies, having less weight than the aircraft itself, would likely stay airborne for longer and retain more of the original intertia of the aircraft, while the aircraft itself dived. I'm still unsure about the mechanism for the separation of the nose from the rest of the plane. I did notice a section of overhead bins laying in a field, one of which had a very clear impact mark from where a person had hit it. This was far away from the main crash site, and thus an artifact from the mid-air breakup. Analysis of this piece would be able to determine whether intertia of the impact was forward, towards the nose, or rearward, towards the tail. Either way though, it definitely indicates a catastrophic scenario going on within the cabin itself, before the plane ever reached impact. But the other thing I find very strange and still don't have an explanation for...is that there is a seriously large amount of bodies that have...to put it as gently as possible...had the tops of their heads removed. And this is the case not only at the main crash site, but also in surrounding areas. It's a nearly uniform injury amongst dozens or more passengers...all at about the same position on the bodies, right at eye level, give or take. I have many theories as to why this might happen, but one of which would be a fuselage section tearing away on descent and flying into the passenger cabin rather than way from it...therefore after the decompression and probably well into the fall to the ground. If this section was grazing over the top of seats...that's about the right height for the head injuries we see...which....means that many of these people were probably already gone before they hit the ground. The lack of bleeding on many of the bodies also tells me that they were probably already deceased. I'm more disturbed by the ones that appear to have bled, as these may have, at least briefly, survived. Probably no more than mere seconds or minutes after the crash. Another thing that I'd like to suggest is that although the site is definitely being compromised by the rebels....we have so much video evidence now of the crash aftermath, especially being posted by Russian and Ukranian people, that an investigation might be able to glean very important information from the videos and photographs alone. Including, perhaps, a simulation of the events that occured from time of missile contact to time of impact with the ground. I hope this analysis doesn't bother you too much. It's posted purely with analytical intent, now that the initial horror and sadness has moved towards a search for answers. |
Quoting SKAirbus (Reply 2): This is very incriminating: http://www.bbc.co.uk/news/world-euro...83625 |
Quoting SKAirbus (Reply 2): Will the black boxes have any use here at all? |
Quoting SKAirbus (Reply 2): This is very incriminating: |
Quoting SKAirbus (Reply 2): The rebels obviously do not want any key evidence to be found, although I doubt their little pea brains will be able to identify missile shrapnel for example. |
Quoting SKAirbus (Reply 2): Will the black boxes have any use here at all? Surely they would not be able to tell anything that happened in such a huge explosion? |
Quoting SKAirbus (Reply 2): Personally, I think the UN should be sending in peace keeping troops to Eastern Ukraine to secure the crash site and allow investigators to go about their work. |
Quoting SKAirbus (Reply 2): The Russian back rebels really are beyond scum. |
Quoting SKAirbus (Reply 2): First they shoot down an airliner and now they are desperately trying to hide the fact they did it. |
Quoting SKAirbus (Reply 2): And Putin... well he is barely a human being. |
Quoting Hywel (Reply 7): |
Quoting Hywel (Reply 7): I would put about 20% of the blame on the Kiev government. It was clear from the 29th June, when the rebels admitted having access to BUK missiles that the airspace should have been closed. The rebels were taking pot shots at a sky that almost inevitably would result in a plane going down. So why was airspace not closed? It's ludicrous the 32000 ft safety limit when the missiles known to be available to the rebels had a vertical limit of 25km and a 95% kill efficacy (according to Wikipedia). The Kiev government was also either negligent or cynically deliberate, and I've started to think they were deliberate |
Quoting MigPilot (Reply 9): I do not want to absolve the rebels at all. Most probably they shot down MH17. Also these people are scum if they did. But this is what you get in any war zone in this world. Local warlords, no clear command structures, all kind of druged up lowlife and failed individuals, who have nothing left than weapons to express their hatred. To not close the airspace was as either criminal or cynical deliberate. |
Quoting Hywel (Reply 12): Likewise, I am not absolving the rebels at all. They clearly have to take most of the blame. But at the same time, I don't buy into the theory that Russia should take much responsibility for it - they just supplied the weapons. |
Quoting KiwiRob (Reply 123): Ultimately I believe Ukraine should just give up the territory which no longer wants to be a part of it, more people will be killed if they don't. Peace should be what we are aiming for. |
Quoting bluesky9 (Reply 16): MH17 was shot down over a war zone. Why was it flying over an area where other aircraft had been shot down? |
Quoting PanHAM (Reply 20): There is no declared war and hence there is no war Zone. There are insurgents who may get some outside help but a war can be declared only between at least 2 legitimate countries, and luckily that has not been the case. Civil unrest or whatever one can call this happens in other parts of the world without leading to consequences like prohibiting overfligth of comercial airliners. otherwise MDW or LAX would need to be closed as well. |
Quoting PanHAM (Reply 20): There is no declared war and hence there is no war Zone. |
Quoting blueshamu330s (Reply 19): This thread is losing all focus and credibility. It has gone from discussing an aircraft crash to a prayer group and conspiracy theory thread. |
Quoting MigPilot (Reply 21): Unfortunately reality doesn't comply with your funny definitions. |
Quoting EA CO AS (Reply 17): MH17 was shot down over a war zone. Why was it flying over an area where other aircraft had been shot down? |
Quoting blueshamu330s (Reply 19): This thread is losing all focus and credibility. |
Quoting PanHAM (Reply 24): It was a sarcastic remark, not funny at all. The comparison is, that like in Chicago or other US cities, the insurgents in Eastern Ukraine are nothing less than street gangs, common criminals, with the granted exception that US street gangs so far have no SAM Missiles. |
Quoting blueshamu330s (Reply 19): This thread is losing all focus and credibility. It has gone from discussing an aircraft crash to a prayer group and conspiracy theory thread. Some serious moderating needed to get it back on track. |
Quoting nupogodi (Reply 23): Shoot someone in a car and you don't call it a car accident. |
Quoting nupogodi (Reply 23): Not much to be learned on the aviation side about it ... |
Quoting MigPilot (Reply 29): Please tell me more about that large scale insurgency in Chicago and other US cities were troops are running around with tanks and AA missiles shooting down aircraft? |
Quoting md80fanatic (Reply 27): I think we've found 9M-MRO. |
Quoting PanHAM (Reply 33): Read the fullparagraph again, try to understand it, don't pluck single sentences and ifyou wish I PM a Translation to you. If you do not understand sarcasm nd irony, which in this ase was direced to the liars in the kremlin, leave it. |
Quoting bluesky9 (Reply 16): Execution Knowing the risks, Ukraine issued a NOTAM that it knew would put hundreds of civilian A/C in danger of being shot down. This was an incident waiting to happen. At the same time US and UK airlines were "strongly warned" not to transit this area. |
Quoting bluesky9 (Reply 16): The only thing to learn from this is that airlines and pilots should not rely solely on NOTAMs issued by authorities in countries that have something to gain if an airliner is accidentally shot down in a war zone. |
Quoting fca767 (Reply 37): Todays flight hasn't left 4 hours on http://uk.flightaware.com/live/fligh...7/history/20140719/1000Z/EHAM/WMKK |
Quoting factsonly (Reply 39): - 19 July 2014: Today MH17 departed AMS with a 4 hour delay: - STD 12:00 - ATA 15.55 Kuala Lumpur MH 017 / Boeing 777-200 / 9M-MRF |
Quoting bluesky9 (Reply 16): MH17 appears to have had only one dual dutch/US passenger (who perhaps was flying using his Dutch passport), which seems an unusually low number of US pax. This raises the possibility that MH17 was selected for this reason |
Quoting flightsimboy (Reply 43): And now you are doing it with me. Not sure if this is a.net glitch, as I've seen it happen before as well. |
Quoting PW100 (Reply 42): Quoting bluesky9 (Reply 16): MH17 appears to have had only one dual dutch/US passenger (who perhaps was flying using his Dutch passport), which seems an unusually low number of US pax. This raises the possibility that MH17 was selected for this reason It took authorities over two days to determine the pax distribution, using all official channels available to them. How would the guy pressing the BUK missile button (or his commander) have that information available to him within two hours after take-off . . . . ??? And how do they have access to that information in the first place, never mind the limited timeframe? |
Quoting fca767 (Reply 35): Todays flight hasn't left 4 hours on |
Quoting AeroWesty (Reply 48): I've also seen links to the MH17 passenger manifest posted on a couple of different forums. I'm reluctant to post a link to it before knowing if it's been officially released yet. Does anyone know? |
Quoting JetBuddy (Reply 3): A Russia Today reporter resigned today in protest. She said she was about the truth, not "Blame everyone but Russia". |
Quoting bluesky9 (Reply 16): There is no benefit for Russia to shoot down an airliner. |
Quoting HOONS90 (Reply 49): It's on their official website as well. |
Quoting PanHAM (Reply 11): If the black boxes turn up in Moscow, Russia, as an ICAO member state, must folllow the protocol and turn them over to Kiev which is in Charge of the Investigation. |
Quoting Aesma (Reply 34): Kiev doesn't have much to gain from that disaster, |
Quoting francoflier (Reply 52): Putin has violated every UN agreement and resolution regarding the Ukraine conflict so far, along with many other international treaties Russia has signed. I'm sure an ICAO treaty will not come between him and his wish of being the 21st century's Stalin. |
Quoting WingBuff (Reply 53): the Russian public is shifting its support away from the pro-Russian rebels and to the Ukrainian government as we speak. |
Quoting yv773p (Reply 54): I don't know about that the Russian propaganda machine is powerful. This video shows that Russians believe it was a plot by the Ukrainians and the West. |
