Quoting AviationAddict (Thread starter): I was surprised to see two flights with such similar call signs, equipment and routes departing so close together from the same airport; I would think it could cause confusion for ATC. Are there any airlines that avoid clumping similar flight numbers together to prevent confusion with the controllers/flight crews? http://flightaware.com/live/flight/DAL408 http://flightaware.com/live/flight/DAL407 |
Quoting AviationAddict (Thread starter): I was just browsing Flightaware and I noticed that DL has flights 407 and 408 departing from JFK only seven minutes apart and actually today because of weather the flights departed three minutes apart. Both flights are on 763s and both are to western Europe. I was surprised to see two flights with such similar call signs, equipment and routes departing so close together from the same airport; I would think it could cause confusion for ATC. Are there any airlines that avoid clumping similar flight numbers together to prevent confusion with the controllers/flight crews? |
Quoting AviationAddict (Thread starter): I was surprised to see two flights with such similar call signs, equipment and routes departing so close together from the same airport; I would think it could cause confusion for ATC. |
Quoting maverickTTT (Reply 1): There's enough differentiation between the words "seven" and "eight" to |
Quoting Mir (Reply 4): 407 and 408 aren't really a problem. 408 and 48 |
Quoting AviationAddict (Reply 7): Points taken; I was thinking more along the lines of the controllers watching their screens and seeing two DL 767s heading east on nearly identical flight paths and both with flight numbers that start with 40...could see where it might cause confusion if one was busy and JFK during the evening international departures is about as busy as it gets. |
Quoting Viscount724 (Reply 9): Some airlines assign different flight numbers for operational and ATC purposes than the flight number used for reservations and booking purposes. I expect part of the reason could be to avoid confusion with other similar flight numbers. |
Quoting atcsundevil (Reply 10): Quoting Viscount724 (Reply 9): Some airlines assign different flight numbers for operational and ATC purposes than the flight number used for reservations and booking purposes. I expect part of the reason could be to avoid confusion with other similar flight numbers. Usually when I've noticed this, it's because that same number is being used twice in the system. Both BA and UA used to do it quite often, there they'd market the flight as BAW288, but it would operate as BAW288J. Since the same number can't operate in the system for two flights, they have to differentiate them. |
Quoting atcsundevil (Reply 10): I'm not sure if I've ever paid enough attention to see how airlines market and operate to see if they change numbers entirely |
