Quoting trex8 (Reply 5): Would the incident where the BA 747 flamed out all 4 engines from volcano ash have ended differently if it was a twin?? |
Quoting SEPilot (Reply 1): There were exactly the same number of engine caused crashes on twins as on jets with more than two engines. And since there are far more twins flying than jets with more than two engines, that says that you are much less likely to be in an engine caused crash in a twin than in a three or four engined plane. |
Quoting horstroad (Reply 9): The more relevant question is the hypothetical part. would this exact incident that happened on a twin have the same result on a triple or quad? |
Quoting RedChili (Reply 2): Perhaps SK686 or Lauda 004? |
Quoting trex8 (Reply 5): I don't remember the specifics of the accident but hasn't a 747 saved a Singapore flight that lost power because of volcanic ash? |
Quoting CXfirst (Reply 8): Imagine being in a twin, both engines stopping. You restart them, and soon after, one of them stops again. There is a real fear that the last engine can go. With 4 engines, and the one stopped, there is at least some more confidence knowing that you can handle one more stopping. |
Quoting SEPilot (Reply 13): The one that I can think of is the British Midland 734 where the crew shut down the wrong engine. |
Quoting mandala499 (Reply 14): Lauda 004, if the engines ripping off bled off the hydraulics (which if I remember correctly, happened with this case too), then it's useless... |
Quoting Viscount724 (Reply 4): Not 4 engines, but if the Eastern L-1011 that had all 3 engines flame out on a MIA-NAS flight in 1983 hadn't been able to restart one engine (#2) and make a one-engine landing at MIA, it would have been a much more serious event. With 3 engines they probably had a higher probability that they could restart at least one than if they only had 2 engines. http://aviation-safety.net/database/record.php?id=19830505-2 |
Quoting mrcomet (Reply 17): But in the end, failures are so few that basically it may be a wash all things considered. |
Quoting mrcomet (Reply 17): In the end, I guess the issue comes down to, all things being equal, would you prefer to board a two or four holer. Sounds like there are inherent advantages and disadvantages of each. |
Quoting flyboy730 (Reply 20): Would UA811 from Hawaii be considered a 4 engine blessing? If memory serves me correctly, they ended up landed on 2 left engines. |
Quoting CXfirst (Reply 8): They got the engines restarted, but one stopped again. With that damage, all the other engines faced the same dangers, so easily could have been 2 or 3 engines not working. I believe in this case having 4 engines gave the crew some more confidence. |
Quoting mandala499 (Reply 14): If you fly into volcanic ash, you can have 1, 2, 3, 4, or 16 engines and the number of engines wouldn't help. |
Quoting CXfirst (Reply 8): They got the engines restarted, but one stopped again. With that damage, all the other engines faced the same dangers, so easily could have been 2 or 3 engines not working. I believe in this case having 4 engines gave the crew some more confidence. Imagine being in a twin, both engines stopping. You restart them, and soon after, one of them stops again. There is a real fear that the last engine can go. With 4 engines, and the one stopped, there is at least some more confidence knowing that you can handle one more stopping. |
Quoting Lufthansa (Reply 10): There is a problem though with the question. If being a quad saved the aircraft, then, it didn't crash.. it was merely an incident. So we may not know of things actually being different if the aircraft had have been a twin. |
Quoting mandala499 (Reply 14): I don't know why SK686 is even considered. That's a runway incursion. |
Quoting lightsaber (Reply 19): So unless the airframe is too large for two engines, then the economics will dramatically favor a twin. |
Quoting mrcomet (Thread starter): Has there ever been a crash where there was a belief that had it been a 4 holer, the outcome would have been different? |
Quoting part147 (Reply 12): Qantas Flight 32mwould probably have ended very badly if she was a twin with an engine exploding and puncturing/emptying the wing fuel tank like it did. A testament to the 4 holers over the twins in this case! |
Quoting part147 (Reply 24): After thinking about this a little more... the design philosophy between them can be distilled down as follows ... if you want the max level of safety at the expense of a little extra fuel, go for 4 engines |
Quoting warden145 (Reply 23): This is a matter of personal opinion |
Quoting spacecadet (Reply 15): I'm not sure what would have happened on that flight with four engines. Would the loss of lift on that wing have been the same, or halved? I'm not an aerodynamic engineer so I'm not sure. Intuitively I would think the increase in drag would have been the same, so the result would have been the same. But I could be wrong. |
Quoting SEPilot (Reply 1): But to answer your original question, it is no. Which is why ETOPS was developed in the first place. |
Quoting mrcomet (Thread starter): Is there some set of circumstances in the allowed flight envelope where you do run a greater risk with just two engines? |
Quoting kurtverbose (Reply 26): Given many think the A380 is too large, doesn't that mean that realistically all future wing and tube airliners will be twins? |
Quoting part147 (Reply 24): ...if you want the max level of safety at the expense of a little extra fuel, go for 4 engines |
Quoting part147 (Reply 24): After thinking about this a little more... the design philosophy between them can be distilled down as follows ... if you want the max level of safety at the expense of a little extra fuel, go for 4 engines - if you want the best possible fuel economy, go for the twins with an acceptable (close to negligible) reduction in that max level of safety. |
Quoting kurtverbose (Reply 26): I do wonder how powerful they could make an engine. 130,000lbs has already been done on the test bench I think. Could even an A380 sized plane be a twin? |
Quoting PhilBy (Reply 27): I seem to remember that there was this two-holer that lost 2 engines and landed on the Hudson..... |
Quoting bond007 (Reply 29): Only from a perception standpoint. It's not a matter of opinion on whether they are truly safer or not. |
Quoting tommy1808 (Reply 30): Well, if the plane have had for engine and on one engine the reverser deployed, there would still be positive trust left on that wing and the result should not have been different from a single engine out on a twin, especially if the inboard reverser was the one kicking in. I would think as a 4-Engine aircraft Lauda 004 would not have went out of control and broken up midair. |
Quoting Roseflyer (Reply 33): Now 2 engines vs 4 engines is not a factor. However, before ETOPS with the engine reliability rates of early jet engines, it was an important factor. |
Quoting SEPilot (Reply 36): Actually, I have been unable to find any case of two unrelated engine failures on the same flight on any jet plane, going right back to the B-47 and B-52. While the statistics do not support ETOPS operations on early jets, as you say, I cannot find ANY engine caused crashes of any of the first generation jets. |
Quoting SEPilot (Reply 36): I have read that the limit of current technology is about 150,000 lbs. But that was quite a few years ago |
Quoting SEPilot (Reply 36): Yes, and if it had been a quad we likely would have had a four-engine plane landing in the Hudson. There have been two airliners that crashed with fatalities resulting due to birds, and both of them were quads. |
Quoting tjcab (Reply 41): No matter what, quads will always be safer - technically |
Quoting RetiredWeasel (Reply 39): Sully's bird strike happened at 2700'. Odds that if he had a 4 engine airplane, the geese would have taken out more than 2 is, my guess, pretty low. |
Quoting tjcab (Reply 41): As some have stated, engine reliability has increased. This also means that it has increased on quads |
Quoting PanAm1971 (Reply 40): As I understand it-Air Force One is required to be a 4 engine aircraft. I guess there must be an argument for 4 holers over twins. |
Quoting d l x (Reply 44): But if you take out two engines on a four engine plane, it's coming down. It no longer has the thrust to climb. |
Quoting mrcomet (Thread starter): Sitting aboard a 744 from SFO to FRA the other day I looked out and saw two engines and said to myself, even though I have full confidence in two engine planes, |
