Quoting adicool (Thread starter): Especially the missing link to LIM, SCL and BOG seems somewhat odd. AV could perfectly fly BOG-BSB and have O6 take care of any further destinations. |
Quoting adicool (Thread starter): As for now, the only international routes ex BSB are |
Quoting 2travel2know2 (Reply 2): The lack of lights between BSB and LIM/BOG may have more to do with frequency restrictions on the respective bilateral than if there's a demand. |
Quoting SCQ83 (Reply 4): Brazil is now a Oneworld fortress |
Quoting VC10er (Reply 8): How long is the flight from MIA or ATL to BSB? What equipment is used? Can a 757 make it? |
Quoting SCQ83 (Reply 4): I guess IB flying MAD-BSB when they get their A359s would make the most sense next. Brazil is now a Oneworld fortress yet the two only European non-stops are Skyteam and Star Alliance. |
Quoting adicool (Thread starter): possibly AMS (if AF does well). |
Quoting migair54 (Reply 10): I also think that IB will serve BSB, but i´m not sure when, however it could be also as as triangular route, first I think SSA, REC or FOR could get the new flights but one of them could work with BSB also initially. |
Quoting jetblastdubai (Reply 9): Quoting VC10er (Reply 8): How long is the flight from MIA or ATL to BSB? What equipment is used? Can a 757 make it? http://www.gcmap.com/mapui?P=iah-bsb,+iad-bsb,+mia-bsb I don't think the 757 has legs for these non-MIA fights. |
Quoting SCL767 (Reply 3): LATAM wants to resume LIM-BSB; however the flight could be operated by either LP or JJ... |
Quoting RAGAZZO777 (Reply 15): Yet JJ is only deploying a "small" A320 to LIM from GRU these days. Pretty pathetic for an airline that has 767s and 777s in its fleet.. |
Quoting bjorn14 (Reply 17): I am a bit surprised no NYC or LON flights? |
Quoting adicool (Thread starter): I was wondering if there will be some more flights to the cities like LIM, SCL, ASU, BOG or even MAD and FRA |
Quoting migair54 (Reply 10): it could be also as as triangular route, first I think SSA, REC or FOR could get the new flights but one of them could work with BSB also initially |
Quoting SCL767 (Reply 3): AV found a way to get around that by having TA operate SJO-BOG-BSB. |
Quoting SJOtoLIR (Reply 21): LP LIM-BSB thrice a week with 319 was shelved in 2011. Brasilia didn't work for both Bogota and Lima. However, CM PTY-BSB 4x weekly started in 2011 and it's 11x weekly nowadays. Where's the difference? |
Quoting rg787 (Reply 22): CM is pretty good for connections to the US. |
Quoting rg787 (Reply 22): BSB isn't capable of being an international HUB. North of GRU is almost always the same travel time or less going thru BSB instead of GRU. When going from everything south of bolivia to Europe, BSB would also be a good connection point. |
Quoting Viscount724 (Reply 19): The fact that Brazil has very weak ties to most South American countries also explains why BSB has limited international service. |
Quoting migair54 (Reply 10): Quoting adicool (Thread starter): possibly AMS (if AF does well). No chance at all, because AF is already there, so unless the place is a gold mine you will never see KLM starting the route. |
Quoting rg787 (Reply 7): BSB is the biggest domestic hub in number of flights from what I've heard. LIM somehow didn't work but maybe the reason is that it was started by two companies almost at the same time and if I remember correctly it was quite a busy time in BSB for starting international routes. Would someone care to search for the loads on BSB? I would do it myself but I don't even know where to start. |
Quoting adicool (Reply 25): The CDG-BSB route has just been introduced, and I am assuming nothing will happen before AF would go daily on the route |
Quoting PDPsol (Reply 24): Brazil is a top trade destination for several nations in South America |
Quoting C010T3 (Reply 29): Unfortunately Brazil is still an island within South America and Brazilians are oblivious to Spanish American countries. |
Quote: Surely you can argue that the relationship and integration have evolved in the last few years, but the rhythm is really slow. |
Quoting adicool (Thread starter): DL - ATL |
Quoting MesaFlyGuy (Reply 14): Delta currently flies the 757-200 from ATL to BSB. |
Quoting BNAOWB (Reply 31): How critical are G3 connections at BSB for DL for the success of this ATL-BSB nonstop? And, which G3 destinations would typically have a decent number of connecting passengers to this DL flight? |
Quoting Viscount724 (Reply 28): That's not my quote. |
Quoting C010T3 (Reply 29): Unfortunately Brazil is still an island within South America and Brazilians are oblivious to Spanish American countries. Surely you can argue that the relationship and integration have evolved in the last few years, but the rhythm is really slow. |
