PITrules
FedEx Airbus Falls Off The Jacks
Sat Aug 23, 2014 12:02 am
No one was hurt.
http://imgur.com/a/faJ8X
That will buff right out.
FLYi
Q
RE: FedEx Airbus Falls Off The Jacks
Sat Aug 23, 2014 12:17 am
Ohhh It is going to be toughest job hard to remove aircraft under hanger. It's impossible crane up against hanger clearance. Aircraft would be not able to repair. It looks like serious damaged and written off. Fed Ex is unhappy that day.
Q
airportugal310
Sat Aug 23, 2014 12:22 am
That is what we call an "incident" airplane
Quoting PITrules (Thread starter):
Nothing some speed tape and bondo can't fix
“They bought their tickets, they knew what they were getting into. I say, let 'em crash.”
Stitch
Sat Aug 23, 2014 12:28 am
Maybe next Thursday's Boeing O&D update will show a single 767-300F order for FedEx.
garpd
Sat Aug 23, 2014 12:41 am
Think it's a write off?
arpdesign.wordpress.com
FrmrKSEngr
Sat Aug 23, 2014 1:00 am
Quoting Q (Reply 1):
Air Bags to get dolleys under it. If they want to fixit, put shoring cradles under it. Probably not worth the effort.
Okie
Sat Aug 23, 2014 1:06 am
I suspect they should be able to lift it from the original points or with bags to get the gear back down.
Makes you wonder exactly what happened to bump the aircraft off the jacks. It looks like they were in the process of a gear swing.
Okie
JAGflyer
Sat Aug 23, 2014 1:12 am
Quoting okie (Reply 6):
The first thing that comes to mind is either weakened jacking points (damaged by being previously jacked incorrectly or perhaps corrosion) or using the wrong jack adapter for the aircraft. I hope the mechanics working that day were borrowing their uniforms from UPS.
If you flew today, thank a Flight Dispatcher!
RDUDDJI
Sat Aug 23, 2014 1:17 am
Minor damage to the Fetzer valve. It's all ball bearings these days.
Sometimes we don't realize the good times when we're in them
N747PE
Sat Aug 23, 2014 1:19 am
Next trade-a-plane. Airbus 300 for sale FedEx colors really cheap
SEPilot
Sat Aug 23, 2014 1:22 am
It does look like a lot of damage. I suppose it depends on how old and worn the plane is whether or not it will be repaired. But if the structure was not bent I think it can be fixed.
FLDude
Sat Aug 23, 2014 1:26 am
Quoting RDUDDJI (Reply 8):
Yep, makes the run to Provo every weekend.
I hope the damage is not as bad as it looks.
[Edited 2014-08-22 18:26:57]
Part147
Sat Aug 23, 2014 1:47 am
Ouch, looks bad!
Speculating that the wing rear spars are okay, only secondary structures damaged, the tail cone puncture might also be fixable unless the rear pressure bulkhead has been deformed/damaged. Engines removed means structure was light and with heavy gear and flaps flailing about, perhaps they just 'shook her off' the jacks!
Anyway, it's a great powerpoint traing presentation in the making
It's better to ask a stupid question during training, rather than make a REALLY stupid mistake later on!
jetjeanes
Sat Aug 23, 2014 2:21 am
Given the age of the plane its prob a w/o ,especially if the rear bulkhead is screwed.. thats alot of work
i can see for 80 miles
flightsimer
Sat Aug 23, 2014 2:46 am
This happened over a month ago, so I would think some info on what is happening to the aircraft should be out there. My bet, being an old converter A300 or A310 it is going to be a write off.
Commercial / Airline Pilot
TonyBurr
Sat Aug 23, 2014 2:48 am
Ouch, that hurt ! That hurt the plane and whoever was responsible for overseeing the placing of the jack.
Sat Aug 23, 2014 3:08 am
At the bottom of that link it says the photos were posted a month ago.
There are additional fuselage jacking points at frame 17 & 76, these screw onto the fuselage. You can take hanger roof panels off, use a gantry crane, air bags etc.
AndyEastMids
Sat Aug 23, 2014 3:22 am
Engines off and cowls taped up, putouts tapesd, looking rather scruffy... My guess is this is a retired A310 at Victorville, being prepped for storage or part out...
kanban
Sat Aug 23, 2014 4:10 am
while getting it back on its legs is easy, with a hole through the fuel cell and patched wing skins could be used, the repair may exceed the value.. however I believe the jack is salvageable..
not familiar with Airbus jacking points but is that one behind the jack in the next to last picture or an access panel?
HPRamper
Sat Aug 23, 2014 4:20 am
Quoting jetjeanes (Reply 13):
If it's a 310, most likely. The A300s are some of the newest trunk aircraft in the fleet.
Spacepope
Sat Aug 23, 2014 4:29 am
Doing a photo search, looks like the 310s have patched over wing emergency exits like the incident aircraft. The 300s don't by and large. I'd wager it was a 310.
Grummancat
Sat Aug 23, 2014 4:38 am
Every scenario I imagine for lifting this thing keeps sounding like something from "Raise The Titanic".
DocLightning
Sat Aug 23, 2014 4:46 am
Quoting FLDude (Reply 11):
On an aircraft that age, any damage is bad damage. Her career is done.
-Doc Lightning-
-Carl Sagan
TheRedBaron
Sat Aug 23, 2014 5:10 am
Quoting DocLightning (Reply 22):
Write off written all over the damaged wings.... sad mishap.
TRB
The best seat in a Plane is the Jumpseat.
S75752
Sat Aug 23, 2014 5:19 am
Oooh man I cringed while looking at that. Probably one of the most painful looking things I've ever seen, and Aircraft don't even bleed... aside from fuel.
CCA
Sat Aug 23, 2014 5:30 am
The fact that two of the main jacking points are aft of the engines on the rear spar and are closed up makes me think it wasn't jacked. Looks like the right gear collapsed dropping the aircraft onto the jack sitting under the wing. The fwd and aft jacks may have been carrying load or may not have but also obviously got "relocated" once the fall began.
Using the gear handle to function check certain items gone wrong is my guess.
Enthusiast
Type-Rated
Sat Aug 23, 2014 5:38 am
I'm willing to bet that this incident made a hell of a lot of noise!
Fly North Central Airlines..The route of the Northliners!
BlueShamu330s
Sat Aug 23, 2014 7:20 am
Looks like one for Joe Patroni...
Flying around India
bennett123
Sat Aug 23, 2014 9:39 am
Do we know where this happened?.
Also the side loads on the undercarriage in image 6 look bad.
Max Q
Sat Aug 23, 2014 9:43 am
They were lucky if no one was killed.
GGg
na
Sat Aug 23, 2014 10:40 am
Its an A310, but which one? Strange no registration is visible.
And as its a A310 its a write-off no doubt. This type is being phased out by Fedex with most already stored or scrapped. Almost all that remain are older than 25 years.
SpaceshipDC10
Sat Aug 23, 2014 11:01 am
Quoting na (Reply 30):
Because angles of pictures don't allow to see the purple part below tail where rego is.
This one was either already or about to be stored since it has no engines and protective foils everywhere.
yeelep
Sat Aug 23, 2014 11:33 am
I have no first/second hand info, however my theory based on the photo's is a gear removal gone wrong. First, the ram extension of the jacks makes it pretty clear to me it was jacked. Second, take a look at picture six and nine, the pallets on the floor appear to have gear parts such as side struts and down lock over center linkage. Also both gear side struts appear to be missing from the plane. I think what ultimately caused the plane to come off the jacks has something to do with that telescopic forklift behind the right main gear.
SEPilot
Sat Aug 23, 2014 11:57 am
Considering that it has no engines and it looks like the gear is being disassembled it may have been retired already, and is being dismantled for parts.
MD11Engineer
Sat Aug 23, 2014 12:20 pm
Quoting garpd (Reply 4):
If the rear spar is damaged at the jack points, even with a new plane, it will be too expensive to repair. It also looks as if the pylons got damaged as well, from the plane sitting on the #2 reverser. The area around the nose jackpoint and the tail jack point (re-inforced frames) also got damaged.
They are luvky nobody got hurt or killed.
Jan
Dalmd88
Sat Aug 23, 2014 1:31 pm
We saw these pics over a month ago at work. Our speculation was it was in for a paint visit and the engines were removed for other work. It is common on widebodies to jack the aircraft, retract the gear and then lower the aircraft back down to spray. You can then spray with all the doors closed and the belly can be done while standing on the ground. We think they did not have the aircraft high enough when they retracted the gear. The right main hit the ground as it was going up and kicked the aircraft off the jacks. Damage looks pretty bad for this old of an airframe. I doubt it was repaired.
Some here have speculated it was being scrapped and the gear removal went wrong. I doubt that. Most gear are removed from scrapped aircraft outside. Once you remove the gear the next step is cutting it up which usually involves excavators to load the scrap. Tough to do inside.
Indy
Sat Aug 23, 2014 3:17 pm
It's just a flesh wound
Indy = Indianapolis and not Independence Air
INFINITI329
Sat Aug 23, 2014 4:26 pm
Quoting Dalmd88 (Reply 35):
Do aircraft mx manuals come with a specified aircraft height for a gear swing or is that something individual airlines' mx departments come up with?
KC135Hydraulics
Sat Aug 23, 2014 4:34 pm
Quoting infiniti329 (Reply 38):
Normally when we jack aircraft, we jack them to a position that puts the main landing gear tires about two inches off the ground. However, if the gear was retracted, it would be hard to determine that height without the tires out there! Surely there's a maintenance manual that specifies the height to jack with gear retracted.... right?
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
Viscount724
Sat Aug 23, 2014 4:42 pm
Where and when did this happen?
twincessna340a
Sat Aug 23, 2014 5:25 pm
Quoting SpaceshipDC10 (Reply 31):
Picture 4 also shows the upper leading edge of the vertical stabilizer missing. I know it is some sort of antenna that has been removed, just can't remember which one. I think it is the SATCOM or HF antenna. In any case I doubt that would be removed during the painting process.
Spacepope
Sat Aug 23, 2014 5:43 pm
Quoting twincessna340a (Reply 40):
The second to last picture shows a lot of missing paint, did this bird have a tailscrape? Pretty talented to do that on an A310.
The final picture shows the wing/body fairing taped up pretty sloppily if it were in for paint. My wild guess was swapping the gear for timed out ones before towing her outside to have more parts removed.
Fedex has been retiring a number of 310s lately, including one that was ferried to VCV at low altitude (N428FE) FedEx Low Altitude Retirement Flight? (by Spacepope Dec 30 2013 in Civil Aviation)
Note: Not the airframe in question
Photo © Alessandro Lukas
7673mech
Sat Aug 23, 2014 6:27 pm
Quoting Viscount724 (Reply 39):
Quoting infiniti329 (Reply 37):
The hangar appears to be one in Victorville.
AMM and airline procedures typically tell you to raise the airplane high enough for the intended work. Gear swing - typically 2 or 3 inches.
A good rule of thumb is to place a chock underneath the wheel.
Often due to sloped floors, it takes some adjustment - as you have to keep the plane level and maintain the desired distance underneath the wheel.
So - even though the airplane is level there is more air under one wheel then the other.
fca767
Sat Aug 23, 2014 7:14 pm
http://forums.jetcareers.com/threads...t-a-little-jacked-up.203568/page-2
"Ok so, apparently, it wasn't high enough to do a gear swing. The mains pushed the airplane up off the jack and shifted it as the gear started to go up."
Aesma
Sat Aug 23, 2014 7:21 pm
Fortunate that it was an old A310, still cringe-worthy though.
DocLightning
Sat Aug 23, 2014 7:36 pm
Quoting KC135Hydraulics (Reply 38):
Question: how would be you be jacking a plane with the gear retracted? Surely the gear would have to be extended before you jacked it up, right? Otherwise, how would you get it into the hangar?
-Doc Lightning-
-Carl Sagan
SEPilot
Sat Aug 23, 2014 7:59 pm
Quoting DocLightning (Reply 45):
You levitate it in, of course.
Okie
Sat Aug 23, 2014 8:08 pm
It would be interesting to know if was having useable parts being removed before scrapping or in for a painting.
Either case I suspect there will be some insurance involvement by the contractor doing the work.
Looks like an unceremonious trip to the canning line at Pabst.
Okie
Dalmd88
Sat Aug 23, 2014 8:52 pm
It's a plane, you fly it into the hangar.
wrenchon727
Sat Aug 23, 2014 9:25 pm
The A310 in question is N411FE that was retired. It is a gear removal gone wrong, Southern California Aviation was harvesting the landing gear.
