Quoting enilria (Thread starter): OCT 33% NOV 34% |
Quoting enilria (Thread starter): The DL LAX-HND is 25 points fuller. I don't see this lasting. |
Quoting enilria (Thread starter): Load Factors: HND-SEA 2013 JUN 56% JUL 72% AUG 74% SEP 62% OCT 33% NOV 34% DEC 61% 2014 JAN 66% FEB 52% |
Quoting Prost (Reply 5): DL is trying to get the US/Japan to have full open skies agreements so that they can have any flight/any time operating from HND or NRT. |
Quoting MAH4546 (Reply 2): But DL quietly applied with DOT to make the authority non-gateway restrictive so that LAXHND could become HNLHNL. I think DL would consolidate and make SEAHND stronger before dropping it. |
Quoting CV880 (Reply 3): Maybe a little premature to call it a failure in that connectivity via SEA has improved quite a bit since March 2014. |
Quoting 32andBelow (Reply 4): Wasn't their code share connectivity through AS? |
Quoting Roseflyer (Reply 7): Well I think it is certainly getting better. |
Quoting Roseflyer (Reply 7): October, November and February usually have relatively low load factors for leisure travel. Business travel remains, but leisure travel numbers are way off. It looks like the route took some time to pick up. |
Quoting Prost (Reply 5): to have full open skies agreements |
Quoting LAXintl (Reply 11): |
Quoting Prost (Reply 5): at least our airports are open to all carriers, foreign or domestic. |
Quoting enilria (Reply 8): Given that LAX is way better than SEA, I don't think that would make much sense to do. |
Quoting andy33 (Reply 12): is a significantly more open response than JAL or ANA would get if they wanted to fly from LGA or DCA |
Quoting ADent (Reply 14): What are HAs load factors? |
Quoting SANFan (Reply 10): Hey, I know what DL needs: more domestic feed at SEA to help fill these new Asian flights! |
Quoting LAXintl (Reply 11): Japan and the U.S. do have full open-skies. |
Quoting Cubsrule (Reply 16): Sorry, but telling US carriers that they cannot compete in the open market for slots at your busiest international airport (NRT) and shutting out US carriers from slots 16 hours of the day at your second-busiest international airport (HND) isn't full open skies. |
Quoting mercure1 (Reply 17): Don't confuse air-service agreement rights and slots as single issue. They are entirely different. |
Quoting mercure1 (Reply 17): And its not a Japan only issue. Airlines cannot expect to show up and in a place like Heathrow, Sao Paulo, or even US airports either where slots are rare. |
Quoting slcdeltarumd11 (Reply 23): I wouldn't say lax would stay over sea. delta was trying to get lax switched to hnl so clearly its bleeding money also. Sea is the Asian gateway focus you could make an argument to strengthen it. I think delta should just pack up and leave hnd totally both flights, its been bad since day1. |
Quoting MAH4546 (Reply 2): DL quietly applied with DOT to make the authority non-gateway restrictive so that LAXHND could become HNLHNL. |
Quoting EA CO AS (Reply 25): HNLHNL sounds like a terrible idea. |
Quoting dc9er (Reply 26): DAL will subsidize the low LFs with other routes to keep the slot, if they consider it valuable. |
Quoting jfklganyc (Reply 28): If HND is so sought after, why have all these flights been flops since they were added? |
Quoting enilria (Reply 31): As for the other carriers, i don't think they have done much to educate people either, but it is true that the slots are terrible. |
