Quoting pliersinsight (Reply 1): CNN is saying the windows are frosted over. Hopefully not another Payne Stewart scenario..... |
Quoting FedExFlyerPHL (Reply 6): http://www.aopa.org/News-and-Video/A.../March/25/First-TBM-900s-delivered Looks like it was the first TBM-900 delivered earlier this year. |
Quote: A Socata TBM-700 that is based out of the Greater Rochester International Airport is registered to a limited liability company that is housed at 259 Alexander St. in Rochester. That address is the home of Buckingham Properties, which is owned by developer Larry Glazer. Attempts to reach Glazer on his cell phone were unsuccessful. A voicemail left on his phone was not immediately returned. Glazer has development projects in Naples. |
Quoting BigSaabowski (Reply 8): The problem was noticed by the pilot while in the vicinity of KINT. He was at FL280 and had asked for an immediate descent to FL180. ATC could only initially clear him to FL250 because of traffic. |
Quoting flymia (Reply 13): If there is an issue, screw ATC and 180. Declare an emergency and get down to 10,000. Odd if the pilot knew something was wrong. |
![]() Photo © Iain Marshall | ![]() Photo © Carlos Aleman - SJUAP |
Quoting BigSaabowski (Reply 8): The problem was noticed by the pilot while in the vicinity of KINT. He was at FL280 and had asked for an immediate descent to FL180. ATC could only initially clear him to FL250 because of traffic. That's where he remains to this time. He later acknowledged a descent to FL200 but never descended below FL250. His last clearance was direct TAY VOR. |
Quoting tjwgrr (Reply 20): Does Jamaica have any aircraft capable of intercept? Or I wonder if the USAF will re-intercept after clearing Cuban airspace? |
Quoting Tigerguy (Reply 19): Based on the flight path and a position over southeastern Cuba, I'd guess there's 100-200 miles to go before it runs out of fuel... |
Quoting d l x (Reply 26): When the plane descends due to fuel starvation, can a pilot awaken and at least glide and ditch the plane? |
Quoting Beefmoney (Reply 27): The pilot has been unconscious for too long at this point. He's long past the point of permanent brain damage due to oxygen starvation. He won't regain consciousness as it descends. |
Quoting GE9X (Reply 28): If the pilot suffered hypoxia due to cabin depressurization over NC as suggested, he has been dead for a while. |
Quoting evanm (Reply 36): Looks like it's gone. Tragic. |
Quoting kq747 (Reply 33): CNN as usual making up stuff... they looked at flightaware and saw the descent that the pilot requested from FL 280 and was given to FL 250 and said that "the plane dropped." SMH |
Quoting Beefmoney (Reply 25): Once the engine fails we should see a speed decrease until it slows to the point where the autopilot can no longer maintain altitude, then the autopilot will disconnect and we should see a descent that may or may not be stable or straight ahead. |
Quoting braniff722 (Reply 44): So, we in agreement it's just northeast of the island? |
