Quoting blueshamu330s (Reply 2): How ironic then that NATS have just lost the bid to continue providing Air Traffic Services at LGW. |
Quoting TS-IOR (Reply 1): It must be amazing and at the end, when everything went well, funny and don't forget the curfew which seems to be considered in the figures above mentioned |
Quoting Dogbreath (Reply 3): Quoting blueshamu330s (Reply 2): How ironic then that NATS have just lost the bid to continue providing Air Traffic Services at LGW. Do you have a reliable 'source' for this statement? |
Quoting evomutant (Reply 8): Of course, even with the change in provider it will be mostly the same controllers- they will be TUPED over. |
Quoting VV701 (Reply 9): It is interesting to compare the up to 55 Air Traffic Movements per hour at the mixed mode operation at LGW with the 38 to 46 ATMs per hour achieved at LHR with single mode operation. |
Quoting fcogafa (Reply 11): I presume Heathrow does the best it can with the vastly different mix of traffic compared to Gatwick |
Quoting RyanairGuru (Reply 12): LHR is ham-strung with single operations which, by their nature, are less efficient. There is no reason that LHR couldn't shift 50 an hour on each runway, other than some good old NIMBYism. |
Quoting G-CIVP (Reply 13): |
Quoting Mortyman (Thread starter): 906 movements equating to a take off or landing every 63 seconds. |
Quoting timz (Reply 16): So the 906 movements were in 15+ hours? Does LGW have a curfew? |
Quoting Vasu (Reply 17): Yes it does... Not sure of the specifics |
Quoting blueshamu330s (Reply 6): Do keep up Dogbreath. |
Quoting G-CIVP (Reply 14): Stating the obvious, fewer big jets, e.g. B747's, B777's, to contend with and therefore less separation. |
Quoting fcogafa (Reply 21): Unless you get it right all the time,which isn't possible, mixed mode at LHR could actually reduce movements, think Terminal position, runway crossing, SID direction, vortex spacing etc etc etc. It is not a simple answer. |
