Quoting B747400ERF (Reply 1): Of course it cannot fly nonstop. |
Quoting gemuser (Reply 2): Its an LR and if lightly loaded its not impossible! Impressive, but. Gemuser |
Quoting Flighty (Reply 6): It is about 1000 mi further than SYD-DFW which is flown on a much less capable airplane. |
Quoting gemuser (Reply 8): The A380 is less capable than a B77L? |
Quoting gemuser (Reply 8): Quoting Flighty (Reply 6): It is about 1000 mi further than SYD-DFW which is flown on a much less capable airplane. The A380 is less capable than a B77L? PROVE IT!!! Gemuser |
Quoting B747400ERF (Reply 7): Why do such a thing? That is a big waste of tax payer dollars. |
Quoting N415XJ (Reply 13): Well, the A380 has a range of 8,500nm while the 777-200LR has a range of 9,395nm. Of course, the A380 is a much larger aircraft, but it's range is ultimately less. |
Quoting B747400ERF (Reply 15): Would this be a possible route in the future? East coast America to Australia? I know the winds are favorable going west so is the reverse route not possible? |
Quoting B747400ERF (Reply 15): I know the winds are favorable going west so is the reverse route not possible? |
Quoting 29erUSA187 (Reply 21): Quoting 777Jet (Reply 17): People have been dreaming about a route like SYD-JFK for years I wonder if the 777-8X will open up this route. Isn't it supposed to have like 10,000 nm range or something ridiculous? |
Quoting gemuser (Reply 14): Happy to concede the range, but the A380 will lift a lot more over its max range. |
Quoting B747400ERF (Reply 7): I stand corrected. It must have carried 50 people max. Why do such a thing? That is a big waste of tax payer dollars |
Quoting 29erUSA187 (Reply 21): I wonder if the 777-8X will open up this route. Isn't it supposed to have like 10,000 nm range or something ridiculous? |
Quoting LAX772LR (Reply 23): A big reason that the no airline desired a freighter based on the A380 frame, was because the payload-density over its range sucked... such that it would only be of use to low density parcel carriers (e.g. FX and 5X), and even they ultimately didn't want it |
Quoting zeke (Reply 25): What you are looking at with such a light load is a ferry range, not the range you quoted. |
Quoting zeke (Reply 25): There is absolutely no reason Airbus would be prevented for installing additional tanks in the A380 either. |
Quoting zeke (Reply 25): That is what the Boeing bashers on a.net said. |
Quoting LAX772LR (Reply 26): Such would apply to both aircraft in question, not just one... so it's not as if the comparative situation would change. |
Quoting LAX772LR (Reply 26): Indeed, there sure isn't, but since that 1) hasn't happened nor 2) isn't being offered and thus 3) won't be in the air any time soon..... we should probably stick to the reality of the model as it currently stands, and not some "OMG, what if!" scenario. |
Quoting LAX772LR (Reply 26): ...though it does make one wonder if there's some merit to that, considering that nothing but parcel carriers wanted anything to do with the model, even when it did have orders |
Quoting B747400ERF (Reply 7): That is a big waste of tax payer dollars. |
Quoting zeke (Reply 27): Airbus does offer the A380 with an additional centre tank of 41,700 liters, around another 1000 nm in range, the tank is the center wing box. Probably the reason they are not being used on the the normal passengers A380s now is it can do the commercial routes without needing them. All A380s have the additional tank, they are just not activated, like the A330-300. |
Quoting zeke (Reply 27): Wonder away, |
Quoting zeke (Reply 27): still does not make it a factual. |
Quoting factsonly (Reply 30): 14-Nov-2014 B772/L RGN - BNE 9hrs13min. 08-Nov-2014 B772/L KADW - PEK 13hrs08min. |
Quoting LAX772LR (Reply 29): I remember it well, during the NTSB's freak-out over Airbus' choice to not inert, despite the fact that A/C packs wouldn't run underneath where a center tank would be were there one available; which they (at least at the time) only expected to see on a freighter or HGW bird. And even back then, the max tank capacity was the same 320k L that Airbus is advertising today. |
Quoting LAX772LR (Reply 31): Quoting factsonly (Reply 30): 14-Nov-2014 B772/L RGN - BNE 9hrs13min. 08-Nov-2014 B772/L KADW - PEK 13hrs08min. Nice. Curious as to what she did/where she went, between these two dates and destinations. Any idea? |
Quoting LAX772LR (Reply 29): So again, when was this option added, and why doesn't Airbus make it apparent? |
Quoting LAX772LR (Reply 29): Granted, I haven't bothered looking for myself, but do you have any corroboration to that effect? |
Quoting Max Q (Thread starter): Looks like a Delta triple 7 and that's over 8200 NM, impressive. |
Quoting DeltaB717 (Reply 4): It's actually an ER (N864DA) and it's certainly doing it's damndest... halfway across the States at the moment. It also flew westbound nonstop from Andrews to PEK. |
Quoting usflyguy (Reply 12): The chartered flights aren't paid for by the government, they are paid for by the news organizations that send staff on the flights. |
Quoting tymnbalewne (Reply 5): BA flew a lightly loaded 777 from BRU to MEL. The aircraft carried then-PM Tony Blair to the Commonwealth games. |
Quoting mpdpilot (Reply 3): Boeing did a record setting flight of 11,664nm and the pilots indicated they had fuel to go further |
Quoting 777Jet (Reply 11): Given that it was a 777-200ER that is flying the flight, Flighty would be arguing that the A380 is less capable than a 777-200ER! We know what the LR is capable of... 14:40 out of 16:22 duration flown so far and it's still going! Not bad for an ER - but a lighlty loaded LR could eat such a route... |
Quoting gemuser (Reply 8): The A380 is less capable than a B77L? PROVE IT!!! |
Quoting LAX772LR (Reply 10): What's to prove? There's no question who has the better range, by far. The 772LR at max fuel option, has nearly 900nm more range than the A388. |
Quoting Stitch (Reply 44): The Type Certificate Data Sheets have never shown a center fuel tank option or value and to my knowledge Airbus never certified the option once the freighter model was put on hiatus. They may very well put the tank inside each frame (since it's not something you can add later), but I believe Airbus would need to test and certify it before any customer could activate it. |
Quoting B747400ERF (Reply 45): Do media companies also have to pay if their reporters are on the Presidential plane? |
Quoting PW100 (Reply 43): What would the A380 range be, when loaded with the load of a 777-200LR (as loaded for its 9395nm). You may decide for yourself if you want to use the additional centre tank of 41,700 liters. I'll be betting that it won't be required to beat the 77L. So yes, the A380 would most likely be the more capable plane |
Quoting zeke (Reply 46): It is a fruitless argument to say the A380 does not have it when Airbus is doing that very same process on the A330-300 right now. |
