musang
Rumour: L1011 VCV To Palmdale
Mon Nov 17, 2014 10:30 am
Good Day All
At Victorville a few days ago I was told (by a long serving employee) of a plan to tow N729DA to Palmdale, for installation in a museum. The idea was hatched several years ago and obviously hasn't happened yet, but the aircraft has been fitted with two additional main gear legs between and forward of the originals.
Anyone know anything about this scheme? Was he winding me up?
Regards - musang
SpaceshipDC10
Mon Nov 17, 2014 10:53 am
Quoting musang (Thread starter):
Any source or link to that?
What?    What for?
mwhcvt
RE: Rumour: L1011 VCV To Palmdale
Mon Nov 17, 2014 11:36 am
Quoting SpaceshipDC10 (Reply 1):
If true Tarmac loading would be my guess, as normal roads would not have the structural strength to take the weight of the aircraft on its stock footprint....however it seems a little far fetched as it's not like the structure of the aircraft would be suitable to add extra gear I'd love to see how and to what they have been attached to
Must think up a new one soon, slow moving brain trying to get into gear ;)
SpaceshipDC10
Mon Nov 17, 2014 12:22 pm
Quoting mwhcvt (Reply 2):
Before your reply I thought it would go there by air, but then I found out that both locations are quite close.
jetwet1
Mon Nov 17, 2014 12:44 pm
Quoting SpaceshipDC10 (Reply 3):
They are close, the problem with this whole plan is which route to take, the Palmdale road is the most direct and easiest, pretty much a straight shot, however, it's narrow and at places there are power lines that would have to be moved.
The 138 is wider, however, you have small towns to go through and there is a section just before Little Rock that has some nasty (but fun at high speed, not that I have ever done it....Honest Officer) undulations, which honestly, I am not 100% sure would give enough clearance.
Polot
Mon Nov 17, 2014 1:41 pm
It's always possible for them to cut the aircraft up (remove wings and tail) for easier transport and then reassemble it at the museum. It's not like the plane will be flying again anyways. KLM did that for a 747 they sent to a museum.
United_fan
Mon Nov 17, 2014 2:31 pm
Is that the L1011 that was going to be used for some African airline ?
"Suspicion is a matter of opinion"
musang
Mon Nov 17, 2014 3:07 pm
Only the employee at VCV. I've since found a mention in an earlier thread (4490753) on here, which gives the cost ($250K) as the reason it didn't happen.
An ugly tubular steel structure externally, didn't get close enough to see what it attaches to internally, and as it was dusk my pics don't show much detail.
Regards - musang
whisperjet
Mon Nov 17, 2014 5:18 pm
The construction can be seen on this picture from our image database.
Photo © Szabo Gabor
Nobody is perfect - not even a perfect fool.
longhauler
Mon Nov 17, 2014 6:13 pm
What? What for?
My guess would be for towing on a road.
The main gear are pretty far apart on an L1011 and may not fit on a regular road.
trnswrld
Mon Nov 17, 2014 6:25 pm
Almost looks like based on that picture that they intend to remove the original main landing gear and transport it using the new temporary center mounted ones. I assume for narrow roads because of how wide the mains are on an L1011 as mentioned above.
goosebayguy
Mon Nov 17, 2014 6:33 pm
Moving an L1011 by road has been done before in Riyadh. It now sits next to the main highway at the National air Museum.
L1011dal
Tue Nov 18, 2014 3:15 am
Heard about this 4-5 years ago but nothing ever happened. Now looking at the photos online the extra main gear installed is in photos from 2010 so the question now is was this something that "was" planned or is this something now moving forward since it was evident in 2010?
Viscount724
Tue Nov 18, 2014 3:29 am
Quoting longhauler (Reply 9):
36 feet between the centers of the main gear so it would be a few feet more between the outer wheels.
