Quoting DeltaRules (Thread starter): Simply put, how does DL typically determine how they'll use these four on a short-to-medium haul flights? I know the M90 has 11 extra seats, a little extra range, and the power for more hot-and-high operations as compared to the M88, for example, but is there any science behind the interchangeability of the four on routes such as these? |
Quoting flyorski (Reply 2): Based on my limited experience DL appears to keep the A320s and A319s on rotations that will bring them through SLC throughout rotations. The MD90s seem to rotate in ways that bring them through MSP. As for the others, the 737-800s appear to rotate pretty equally through all hubs and the MD88s tend to stick on routes that allow them to rotate via ATL down the road. |
I think the answer is inexact, so you can come up with examples of routes that don't meet the criteria I describe for a specific aircraft. There are definitely exceptions to each subfleet's typical mission.
One of the first things the combined
DL did after the merger was move the bulk of the MD90 work to
MSP and
ATL and most of the A319/320 fleet went from
MSP to...everywhere else. I don't think it's as separate a fleet as people thought, and they tend to move around a lot. The basic reasoning was that the Airbuses had better range that was not being utilized out of
MSP. The MD90s struggled to go east from
SLC, whereas they can hit pretty much anything from
MSP. Meanwhile the 320 and (more so) the 319 can hit just about everything from
SLC.
DL seems to have quite a few fleets/subfleets that they have put in the category of basic, no
BS mainline that covers their bread and butter routes, which are short, erse set of routes and it's sometimes unclear if they view the 'buses in the same light as they do the MDs. They appear on many of the same routes, but at the same time I would think the average stage length of the 319/320 is probably slightly higher compared to the MD88/90 fleets.
The 73H, 739 and some of the many different 757 subfleets are usually found on more premium routes. Routes to
LAS, for instance, are more often 73H/757 than MD90 even though as you've pointed out they have the same amount of seats. The 73Hs (with PTVs) seem to be viewed as more of a premium aircraft than the MD90 and thus they usually are often found on competitive, high stakes routes.
Like I said, I think these theories are not exact. They might only responsible for about 60-65% of actual aircraft usage. The rest is just seemingly random flights around the system before returning to their usual maintenance base.
International fleet usage is pretty straightforward comparatively speaking.
