Quoting N1120A (Reply 7): This is why I ALWAYS keep my seatbelt on when seated. Its insane not to - especially when crossing the Pacific. |
Quoting SOBHI51 (Reply 13): reported injured as plane hits severe turbulence over Pacific Ocean Boeing 747-200 |
Quoting gdg9 (Reply 19): On a related topic, when did Fl. 280 switch numbers? Thought it started as 27/28? |
Quoting AABB777 (Reply 4): I'm hearing they are 'minor' injuries. |
Quoting hoons90 (Reply 25): Here's a video taken from the cabin: http://www.youtube.com/watch?v=V21eV22fYxI |
Quoting jetblue1965 (Reply 8): |
Quoting bristolflyer (Reply 30): Many of those comments are downright mean. |
Quoting FCAFLYBOY (Reply 27): Quoting jetblue1965 (Reply 8): To answer that, in addition to the very strong jet stream, at this time of year, the other major factor is topography. Japan is a very mountainous country with around 90% or so elevated far above sea level. This in turn disrupts wind flow when factoring some of the high and often volcanic mountain ranges. That also in turn has a much more minor effect, however when releasing super-heated air and vapour that's all adds to the mix to help create very heavy, turbulent air up in the sky. |
Quoting FlyPIJets (Reply 33): Serious question What are the operating procedures when an event like this happens. (both cabin crew and flight crew)? |
Quoting FCAFLYBOY (Reply 27): To answer that, in addition to the very strong jet stream, at this time of year, the other major factor is topography. Japan is a very mountainous country with around 90% or so elevated far above sea level. This in turn disrupts wind flow when factoring some of the high and often volcanic mountain ranges. That also in turn has a much more minor effect, however when releasing super-heated air and vapour that's all adds to the mix to help create very heavy, turbulent air up in the sky. |
Quoting pasu129 (Reply 32): Agreed. Due to Japan's mountainous terrain, during the winter months turbulence is especially severe during the region. I have returned from HKG to LAX last month and over Japan we were met with extreme turbulence, meal service stopped immediately and all FAs returned to seats. Turbulence didn't stop until we were over Siberia. |
Quoting CRJ900 (Reply 28): A lot of unsympathetic replies on that youtube video further up. |
Quoting D L X (Reply 31): Well... it's the internet. Don't read the comments and you'll live a longer, happier life. |
Quoting Luftfahrer (Reply 37): |
Quoting pasu129 (Reply 39): So strap down, put your seats up and tray table stowed. Personal items under seat in front of you. They don't make this drill up for no reason. |
Quoting ozark1 (Reply 38): Should the captain have come on the PA after the first severe part? Just to reassure? |
Quoting aerdingus (Reply 36): |
Quoting pasu129 (Reply 32): Agreed. Due to Japan's mountainous terrain, during the winter months turbulence is especially severe around the region. |
