Quoting lowbank (Reply 102): Again copied text not my words, only the bottom line is my text. |
perhaps but you said that you have said the same and that you agreed.
Quoting SeeTheWorld (Reply 104): I'm thinking the same thing, although not necesarily pitot tubes ... maybe something else related to situational awareness ... |
Quoting Brewfangrb (Reply 103): I'd love for you to quote a post where anyone has said this. Unless, of course, it's merely you conflating "this isn't quite as easy as make it out to be" into "people's lives are no big deal". I'm as disgusted by you impugning the thoughts and motives of posters as you are by airlines not having more sophisticated tracking. |
Quoting Kaiarahi (Reply 74): He didn't. You should read the official BEA report. |
Quote: 02:13:40 (Bonin) Mais je suis à fond à cabrer depuis tout à l'heure! But I've had the stick back the whole time! At last, Bonin tells the others the crucial fact whose import he has so grievously failed to understand himself. |
Quoting Brewfangrb (Reply 107): Looking at the first point, sure, we can rush to install some sort of satellite monitoring in a big hurry...but what would that solve if the system wasn't tested and proven to work? |
Quoting Brewfangrb (Reply 107): The fact remains even if the perfect aircraft locating/tracking system had been in place, it would not have saved the lives on board of AF447 or MH370 (assuming the latter is a crash in the South Indian Ocean and not some preposterous conspiracy theory). |
Quoting bigz (Reply 93): How about this idea to track aircraft How about hard wiring a elt into the flight control system, tied into a computer and timer. On a flight, when the main gear leaves the runway, the computer would start the timer. The computer would know how long the flight should take. For example MIA to JFK; that trip takes 2hr. & 30min. For weather delays you add another hour. So the plane has a 3hr. & 30 min. window to land at JFK. If it takes 3hr. & 31min. and no landing occurs, the computer activates the elt. and starts giving the plane's location. If elec. power stops for any reason, the elt. starts working on battery power immediately. The weather delay can be adjusted from 1 hour to 2 hours, or 4 hours; It is up to the airline. Joe Szot |
Quoting transswede (Reply 110): No, it wouldn't have saved their lives. BUT... Better tracking would give A) more information and B) make it easier to recover wreckage for analysis, thus giving more information on what should be change to make future flights ever safer. You will save FUTURE lives. |
Quoting Pihero (Reply 109): On board 158 passengers and 6 aircrews (4 FAs and 2 FD ) |
Quote: AirAsia Indonesia would like to issue a correction on the nationality breakdown of passenger and crew on board QZ8501 as follows: Nationalities of passengers:
Nationalities of crew:
Source: http://www.facebook.com/notes/airasi...as-at-654pm-gmt8/10152668456948742 |
Quoting FCAFLYBOY (Reply 9): So is it perhaps a little more certain now that this was likely a catastrophic event? No time to send a signal perhaps, or make a May Day call? |
Quoting andy33 (Reply 89): There are places less than 10 miles from my house where you wouldn't locate your phone at all because there is no cellphone coverage, and I live in another densely populated region, the United Kingdom. |
Quoting transswede (Reply 110): It's not a flight critical system, it doesn't have to be 100% bug free. |
Quoting CO953 (Reply 85): Maybe there should be. A network of floating repeating towers to provide worldwide emergency coverage in the oceans? Something like geostationary satellites. I bet it's doable if modern scientists and engineers put their minds to it.... |
Quoting Pihero (Reply 109): |
Quoting CF-CPI (Reply 118): |
Quoting F9Animal (Reply 121): One thing I don't understand is why they called off the search until daylight. I couldn't imagine how agonizing that would be for the families and loved ones waiting for word. I know, it's hard to see at night, but wouldn't it be worthwhile to still try? |
Quoting laxboeingman (Reply 124): My guess is that if the weather was still as bad as it was during the flight, that they would not want people searching in those conditions in the dark. It is hard enough during the day time. |
Quoting kanban (Reply 119): Quoting CO953 (Reply 85): Maybe there should be. A network of floating repeating towers to provide worldwide emergency coverage in the oceans? Something like geostationary satellites. I bet it's doable if modern scientists and engineers put their minds to it.... There is no problem with your idea except who would pay for it and maintain it.. cell towers are owned by carriers who make money off of cell phone usage.. why the heck would they put towers and generators to power them where there were no customers just in case.. further said towers would be subject to all the oceans and weather can throw at them.. typical "somebody should" idea without thought. |
Quoting A320FlyGuy (Reply 125): What is clear at this point is that whatever has happened, happened quickly and was catastrophic....no mayday, no 7700, no communication at all. I would be very interested however to find out if any ACARS data was transmitted (a la AF447)...(I think someone else may have mentioned this earlier as well...) |
Quoting Airspeed772 (Reply 122): Sad to say QZ 8501 and AF447 will not be the last Airbus accidents we will see, as most Airline companies forced their Pilots to operate under pressure with total disrespect for Mother Nature. When Airlines Bean Counters are hell bent on dispatching aircrafts base on their spread sheets showing positive numbers, you can bet a lot of innocent lives will be lost. |
Quoting laxboeingman (Reply 127): If there was an inflight stall, would that have provided enough time for the crew to notify the pax to brace for impact and to notify the ATC? If you think there would have been enough time, do you believe that something worse happened if it happened so quickly? Also, because your an FO, it seems that 353 knots, as the ATC radar image indicates, is too slow for what the plane was doing at the time. Would you agree or disagree with that? Thank you in advance. |
Quoting AirlineCritic (Reply 130): |
Quoting liquidair (Reply 32): So, assuming that the speed was slow (emirates flight nearby also has GS500 at the time), can we also make a jump and assume they were flying without envelope protection? If so, how or why so? Bearing in mind the A320 pitots never suffered like the A330/40 ones... |
Quoting dtw2hyd (Reply 60): Those ships are commercial just like commercial aircraft and why they are have state of the art comm equipment and subscriptions to high bandwidth data plans. |
Quoting Brewfangrb (Reply 112): You said this: "Because any piece of information helps when the next aircraft is missing. It's not a flight critical system, it doesn't have to be 100% bug free." to my post where I said this: "we can rush to install some sort of satellite monitoring in a big hurry...but what would that solve if the system wasn't tested and proven to work?" |
Quoting 29erUSA187 (Reply 135): Personally, I hope they find the plane soon. All we need is another MH370. I also hope that this is not turbulence that brought the flight down. If that's the case, every flight near a thunderstorm is at risk |
Quoting ChaosTheory (Reply 130): Not sure why there is a repeated mention of pitots. Doesn't matter if they are the Thales BA/AA pitots or the Goodrich ones. They all ice up under certain conditions and no airworthiness directive is going to change that. |
Quoting gosimeon (Reply 61): I really think you're jumping to conclusions. It's far too early to be questioning the pilot's actions or skills when we don't even have a plane yet, never mind any insight into what happened. |
Quoting [email protected] (Reply 139): Why not just wait to see what materialises? There is absolutely nothing to be gained from meaningless speculation. |
Quoting trex8 (Reply 142): |
Quoting A320FlyGuy (Reply 142): Exactly...this is an aviation discussion forum after all ....it wouldn't be much of a forum if we all kept our mouths shut and fingers bound until we had all the answers.... |
Quoting A320FlyGuy (Reply 141): Exactly...this is an aviation discussion forum after all ....it wouldn't be much of a forum if we all kept our mouths shut and fingers bound until we had all the answers.... |
Quoting laxboeingman (Reply 143): second that. The speculation is also what gets new ideas out in the open of this site and the World Wide Web. Unfiltered thoughts are sort of the heart of what this is and I am fairly sure everyone, including A and B take notice. |
Quoting A320FlyGuy (Reply 137): The danger from thunderstorms is nothing new |
Quoting giopan1975 (Reply 145): We do not know if weather was the mostly contributing factor, however there is very big indication that weather has played some role... |
Quoting StTim (Reply 128): There is no information yet as to what has heppened but some are already laying blame at Airbus - Amazing. |
Quoting A320FlyGuy (Reply 132): Regarding the the speed that the radar indicates...353 knots seems odd ... The A321 has a turbulence penetration speed of about 300 KIAS....so, 353 knots is awfully fast based on the weather that I am able to see from what has been posted online.[/quote] Hold on just a minute : these 350 kt are Ground speed Taking the weather into account - +10 kt wind component and an SAT = -39°C ---> TAS = 343 kt ---> CAS = 190 kt, well below Green Dot. But I'll wait for an official confirmation of that radar screen picture before logging it as *Fact*. Miami post #95 copies the FR24 read out... The flight remained at FL 320 till the end of the reports. If we consider that the data are refreshed every 30 seconds and that climb to FL 363 happened right after the last FR24 data, we could say that the aircraft suddenly climbed at a rate of some 8 600 ft/min from FL 320 to FL 363... and then total radio / transmission silence. Something drastic must have happened in a sudden |
Quoting laxboeingman (Reply 142): I know this was discussed in part 1, but what about a possible lightning strike? Would that have caused a system failure at the time it hits, making it impossible to communicate what happened? If that was the case, wouldn't it be a logical conclusion that the plane would have fallen right out of the sky and broke up upon impact with the ocean? |
