Leej
VS43 LGW-LAS In Trouble?
Mon Dec 29, 2014 2:24 pm
Just noticed on FR24
http://www.flightradar24.com/VIR43E/526ac78
Surely too low to be dumping?
WesternFlyer
RE: VS43 LGW-LAS In Trouble?
Mon Dec 29, 2014 2:30 pm
Rumors say there might be issues with the landing gear.
More sources say that the right wing landing gear is not down. Emergency landing is probably coming up.
[Edited 2014-12-29 06:35:54]
slinky09
Mon Dec 29, 2014 2:37 pm
Seems to be coming into land, a V-Flyer has seen it flying overhead with landing gear down, perhaps not locked in place until now?
Edit: Same person has observed the place circling an reports the outer starboard landing gear appears stuck in with the doors partially open. Hope all is OK.
[Edited 2014-12-29 06:40:35]
Flymichael21
Mon Dec 29, 2014 2:40 pm
Instagram page GeminiJets55, has a photo of the aircraft circling with one part of the main landing gear retracted, with the other parts down.
jlager2
Just seen it circling overhead with landing gear lowered. Been that way for some time but now heading for the airport
KarelXWB
Someone captured a photo of the aircraft, you can clearly see that the main landing gear is not fully locked:
http://pbs.twimg.com/media/B6B6dM4IUAAe5zj.jpg:large
http://twitter.com/LloydAves/status/549575272144846848
slinky09
Mon Dec 29, 2014 2:42 pm
Appears to be overflying the airport, possible for ground engineers to do a visual?
KarelXWB
Mon Dec 29, 2014 2:44 pm
First landing attempt at Gatwick has failed, going around now.
PlymSpotter
Mon Dec 29, 2014 2:46 pm
Saw this one fly overhead the South West earlier after holding above the Bristol Channel. It was a little into the distance but I'm not sure there were four contrails, and I have heard it has engine as well as hydraulic issues.
Hoping for a safe outcome here, this seems to be a genuinely very serious situation.
Dan
slinky09
Mon Dec 29, 2014 2:47 pm
Now reported in the media
aa1818
Mon Dec 29, 2014 2:49 pm
It's climbing now. Would they have retracted the gear or left it down?
LGW is a single runway airport correct? Where would the other aircraft divert to should this 747 have to make a landing with compromised gear, assuming that they would have to shut down the runway after?
Hoping for a safe end to this incident.
Would they coat the runway in foam or anything for a landing if the main gear is not locked in place?
AA1818
“The moment you doubt whether you can fly, you cease for ever to be able to do it.” J.M. Barrie (Peter Pan)
slinky09
Mon Dec 29, 2014 2:51 pm
Quoting AA1818 (Reply 10):
Gatwick actually has two functional runways, only one is used, the other is the north side taxiway but it is wide and long enough to use in emergency.
Apparently the most recent flypast included a wing waggle, which hasn't dislodged the landing gear. I wonder what next?
KarelXWB
Mon Dec 29, 2014 2:53 pm
The jet is now flying above the English Channel.
aa1818
Mon Dec 29, 2014 2:54 pm
Quoting slinky09 (Reply 11):
Cheers for the info! So technically the airport can continue to operate other flights.
Hoping and praying for a safe outcome. Anyone at Gatwick currently? Any sign of emergency crews being activated etc?
AA1818
KarelXWB
Mon Dec 29, 2014 2:55 pm
According to an observer in the area, the crew are trying to lock the gear with some maneuvers. Give it a good swing.
[Edited 2014-12-29 06:56:10]
jlager2
Mon Dec 29, 2014 2:58 pm
I'm under the regular flightpath on approach to Gatwick and there is some increased activity in the area with police coming past but nothing else as the Airport is well equipped to handle an incident with its own fire crews. If it comes over again I'll post a picture
SamH123
Mon Dec 29, 2014 3:00 pm
This plane was meant to be flying all the way to Las Vegas though,
If the landing gear didn't retract correctly after take off is that not something they would try and troubleshoot in the next 10+ hours of flight rather than turning back immediately?
eclipz
Mon Dec 29, 2014 3:04 pm
Quoting SamH123 (Reply 16):
I'm no expert, but you might want to have plenty of time (hence plenty of fuel) to try a few things calmly without the pressure of running out of fuel. And they have extensive maintenance crew in the area, when they land.
Plus, they may have excessive drag which may increase fuel flow...
[Edited 2014-12-29 07:06:43]
readytotaxi
Mon Dec 29, 2014 3:05 pm
Lets have a good out come from this situation pls !
[Edited 2014-12-29 07:11:53]
Growing older, but not up.
longhauler
Not if it wouldn't retract .... you wouldn't get much past Newfoundland with the increased drag.
PlymSpotter
Mon Dec 29, 2014 3:06 pm
Indeed, it's a practically unique situation. Two runways, but they can never be used simultaneously, thus meaning LGW only ever has one runway for use.
Quoting AA1818 (Reply 13):
No, as they will not have sufficient fire cover and most likely fire-fighting media available whilst any emergency with this flight is ongoing.
Most likely - the Virgin A340-300 emergency landing at LHR back in 1997, with one main gear retracted, is a valid precedent:
https://www.youtube.com/watch?v=NprTbTVl1Uk
Dan
e195
Heading out to the channel
Fuel dumping?
Nikon D90 & D50 Sigma 70-300mm, 50-500 mm Lens :) oh yea Baby!
MIAspotter
Mon Dec 29, 2014 3:08 pm
Well, having the landing gear not properly retracted would create a lot of drag, compromising fuel consumption, it would also hamper the aircraft performance as it would have to fly lower and slower, plus you will put a lot of stress on the exposed gear components.
And I guess VS would like to solve this emergency in LGW where they have maintenance facilities and means to sort out the stranded PAX.
MIAspotter.
Nos vamos de Vueling?
gordonsmall
Quoting E195 (Reply 21):
Fuel dumping?
Not in the hold at Seaford VOR its not.
Statistically, people who have had the most birthdays tend to live the longest.
pvjin
Mon Dec 29, 2014 3:09 pm
Let's hope they'll manage to get the gear down and locked. Interesting to follow such a situation from FR24.
[Edited 2014-12-29 07:09:49]
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that." - Martin Luther King Jr
Aesma
Mon Dec 29, 2014 3:11 pm
A Gimli glider style emergency maybe, otherwise you don't use a taxiway to land, even if it used to be a runway.
Too much drag to continue the flight, and if you get a second problem over the Atlantic (engine shut down, say), then you're really in trouble and could have avoided it.
audidudi
Mon Dec 29, 2014 3:12 pm
With the landing gear down, it would take a lot longer than the scheduled 10+ hours to fly to LAS at the maximum speed that the aircraft could fly at. Better to have it land back at home base, or at an RAF airfield like Brize Norton nearby perhaps?
scarebus03
It looks like the r/h wing gear hasn't extended. The good news seems to be that the nose, body gears and l/h wing gear have extended. I hope they'll be ok.
Fingers crossed
No faults found......................
PlymSpotter
Mon Dec 29, 2014 3:14 pm
Quoting Aesma (Reply 25):
Indeed, although the landing gear did retract correctly and the aircraft flew several patterns at 35,000ft.
Dan
kbmiflyer
Nightfall will be coming before too long, won't it?
SamH123
Quoting longhauler (Reply 19):
Ah yeah, makes sense thanks
SamH123
Mon Dec 29, 2014 3:17 pm
Quoting kbmiflyer (Reply 29):
Sunset in London is in about 45 minutes
KarelXWB
Mon Dec 29, 2014 3:18 pm
Sunset at 4pm, about 45 minutes left.
mcr
Mon Dec 29, 2014 3:19 pm
Yes - sunset 16:01 GMT today, it will be dark at LGW within the hour.
KarelXWB
Mon Dec 29, 2014 3:20 pm
Close-up of the main landing gear:
https://pbs.twimg.com/media/B6CDIG3CMAAqLLC.jpg:large
http://twitter.com/SamPilcher/status/549583356011479040
One wheel set is stuck it seems.
lugie
Do you think they'll try to perform an emergency landing while there's still daylight or are they rather going to concentrate on dumping/burning as much fuel as possible?
Q400 E175 E190 CRJ7 CRJ9 CRJX MD88 A319 A320 A321 A332 A333 A359 B733 B73G B738 B739 B748 B764 B772 B77W B788 B789
FRA STR HAM TXL MUC ZRH ACE BRU BLL DUB MAN ARN MAD OPO LIS FNC AMS PHL RDU LGA CLT EWR ORD ATL SFO MDW IAD YYZ SJO PTY
e195
Mon Dec 29, 2014 3:23 pm
on the BBC now with an 'expert' SIGH
777Dad
Mon Dec 29, 2014 3:24 pm
Is there any other means to get the gear down besides the standard way and what are the Pilots options?
"I love to fly,I just don't do it enough"
slinky09
Virgin reports the plane is readying for a 'non-standard' landing - be great to hear from those who can provide more detail on this. Separately, local fire and emergency services have confirmed they're on standby, I hope they're not needed. It can't be very happy on board some 4 hours into the flight now.
e195
would it not be sensible to send it somewhere like BOH if its an emergency landing, without risking the LGW runway operation?
Airplanepics
Mon Dec 29, 2014 3:26 pm
The runway is way too small for BOH - VS have a dedicated maintenance base at LGW.
Simon - London-Aviation.com
P206
Manual gear release is an option?
scarebus03
Thanks for the close up. It looks like an emergency gear extension judging by the fact that the l/g doors are still open and didn't close after gear extension. The jumbo is very robust. I imagine if possible after dumping fuel they will manually transfer fuel to the left side to keep the weight on the deployed gears.
e195
Mon Dec 29, 2014 3:28 pm
Quoting Airplanepics (Reply 40):
true, but if there is a collapse (big if) does it not risk a lot more than going to a quieter airport?
Airplanepics
Mon Dec 29, 2014 3:30 pm
Quoting E195 (Reply 43):
I'd rather disrupt a couple of thousand passengers than risk losing people.
Once it's all over they can most probably (depending on the final resting position) use 26R.
mmo
Mon Dec 29, 2014 3:31 pm
Quoting P206 (Reply 41):
Quoting 777Dad (Reply 37):
There is an alternate gear extension that opens the latches and the gear door should open allowing the gear to free fall into the locked position. If the Alternate extension does not work, then there is no other option. The 747 family has demonstrated the ability to land on all body gear only or all wing gear only. It's not a real big deal to be honest.
mmo
Mon Dec 29, 2014 3:32 pm
Quoting scarebus03 (Reply 42):
There is no normal way to transfer fuel in the 747 family. The only real options are to use crossfeeds and boost pumps to create an imbalance.
slinky09
Mon Dec 29, 2014 3:33 pm
VS43 has broken the latest hold and appears to be heading in to attempt landing ...
KarelXWB
The aircraft just left the holding pattern above the channel and is heading for runway 26L.
P206
it looks like it's heading back to LGW now
