Quoting heyjoojoo: How long would that particular model jet stay afloat? |
Quoting bigz (Reply 4): In my world when I add up the facts it screams CONSPIRACY, COVER-UP, WAR CRIME!!! |
Quoting savethequads (Reply 8): I find it hard to believe in 2015 we can't program a gps autopilot when conventional methods fail. |
Quoting savethequads (Reply 8): An upward altitude deviation could be detected quickly and compensated for automatically regardless of what the heck gyros and pitot tubes are doing. |
Quoting savethequads (Reply 8): Do most modern aircraft not have an absolute electronic GPS system that does not rely on any inertial data, acclerometers or air entering a tube? |
Quoting savethequads (Reply 8): I find it hard to believe in 2015 we can't program a gps autopilot when conventional methods fail. An upward altitude deviation could be detected quickly and compensated for automatically regardless of what the heck gyros and pitot tubes are doing. |
Quoting savethequads (Reply 8): It's just one button close to where your fingers are placed anyway, then talk, you are already on the frequency. I think pilots pride gets in the way of communicating an immedeate emergency to ATC. |
Quoting savethequads (Reply 8): I met many pilots with a scary mentality of don't ever tell anyone if you make a mistake. And if you make a mistake cover it up and lie about what really happened. They used to tell eachother make sure whatever the issue is that it dosen't go out over the radios. These guys then go on to civillian airlines. |
Quoting savethequads (Reply 8): Also, I'm tired of the tired argument that pilots are too busy to radio to ATC to make them aware of what is going on. It's just one button close to where your fingers are placed anyway, then talk, you are already on the frequency. I think pilots pride gets in the way of communicating an immedeate emergency to ATC. |
Quoting bigz (Reply 4): How long after the CVR and FDR from QZ-8501 are recovered, do you think it will be before we hear what's on the tapes. I'm guessing 48 hours no more then 72 hours. That shows you what a conspiracy has to be going on were MH-17 is concerned. We saw the separatist turn the MH-17 "black boxes" over on TV to the British and OSCE people, some time in July. Five months later not one word on the airways from the tapes. In my world when I add up the facts it screams CONSPIRACY, COVER-UP, WAR CRIME!!! |
Quoting savethequads (Reply 8): LTC8K6 I understand why the autopilot disconnects, but in today's modern age the aircraft should be able to be programmed to work off of gps data when one of the inertial systems becomes unreliable. The pilots of AF 3575 stated they suffered sensory illusions and had a hard time reading anything, is that any better, is it any better to have a young first officer pulling back on the stick for 2 minutes? |
Quoting airspeed772 (Reply 6): I can,t seem to find any information of events or incidents of Boeing, Douglas, Lookheed' or any US build commercial aircrafts entering into unrecovered unusual attitudes while flying in the vicinity or thunder storms . |
Quoting jpetekyxmd80 (Reply 15): That shows you what a conspiracy has to be going on were MH-17 is concerned. |
Quoting jpetekyxmd80 (Reply 15): In my world... |
Quoting airspeed772 (Reply 6): can,t seem to find any information of events or incidents of Boeing, Douglas, Lookheed' or any US build commercial aircrafts entering into unrecovered unusual attitudes while flying in the vicinity or thunder storms |
Quoting anfromme (Reply 17): Thanks for doing all that valuable research on behalf of everyone here. Moving on... |
Quoting litz (Reply 2): Bill Palmer, an A330 pilot in the US, writing on CNN.com about what's similar, and what isn't, between QZ8501 and AF447 |
Quoting anfromme (Reply 17): Quoting airspeed772 (Reply 6): I can,t seem to find any information of events or incidents of Boeing, Douglas, Lookheed' or any US build commercial aircrafts entering into unrecovered unusual attitudes while flying in the vicinity or thunder storms . Thanks for doing all that valuable research on behalf of everyone here. Moving on... |
Quoting lnglive1011yyz (Reply 231): I think the problem with the idea that I'm suggesting is that the Professionals here are making an assumption that the plane will be able to be saved. I'm specifically talking about instances where it's VERY unlikely that the aircraft is able to be saved. |
Quoting enzo011 (Reply 23): I would think that it is better that the pilots do everything, up to the last few feet, to try and save the plane. To just give up and let the plane crash doesn't seem like the correct thing for me. I doubt pilots really know there is nothing they can do until the very end when there is only seconds left in any case. |
Quoting savethequads (Reply 8): Also, I'm tired of the tired argument that pilots are too busy to radio to ATC to make them aware of what is going on. It's just one button close to where your fingers are placed anyway, then talk, you are already on the frequency. I think pilots pride gets in the way of communicating an immedeate emergency to ATC. The frame of mind is. I'm a pilot with tons of hours and I can't let anyone know I'm in trouble especially if I failed in my duties (in this case monitoring airspeed, possibly), plus I can't let anyone think I don't have the situation under control. |
Quoting CF-CPI (Reply 22): |
Quoting litz (Reply 2): Very likely, any attempted ditching would have resulted in aircraft breakup, which would have sunk very quickly. |
Quoting CF-CPI (Reply 22): I think everyone should consider Northwest flight 705, a Boeing 720, which was skirting thunderstorms after takeoff from MIA in February 1963. The flight's rate of climb reached as much as 9,000 fpm, and the aircraft was subjected to vertical accelerations from 1G to - 2.8G during portions of the turbulence. The aircraft broke up during the dive into the Everglades. All four engines separated, and the vertical stabilizer failed. |
Quoting airspeed772 (Reply 27): So if I ready you correctly, the last time a U.S. made aircraft suffered such an event was in 1963. Just around the infancy of commercial aircrafts high altitude flying around Thunder Storms? |
Quoting AR385 (Reply 30): To clarify, while weather was a contributing factor, the over controlling of the plane on the part of the PF was what in the end caused the structural failure. |
Quoting maxpower1954 (Reply 32): Quoting airspeed772 (Reply 27): So if I ready you correctly, the last time a U.S. made aircraft suffered such an event was in 1963. Just around the infancy of commercial aircrafts high altitude flying around Thunder Storms? Here's another Boeing struck by lightning and destroyed in 1976 - http://aviation-safety.net/database/record.php?id=19760509-0 Non- U.S. jetliners lost in thunderstorms: Braniff 1-11, 1966 NLM City Hopper F-28, 1981 |
Quoting hb88 (Reply 37): I think airspeed772s trolling didn't get the response he was looking for. To suggest that non-US airliners are inherently more dangerous seems a long shot even for the more ham -fisted A vs B poster-boys. |
Quoting aerodog (Reply 40): Sully Sullenberger on CNN today: Very few airline pilots have stalled a (modern) airliner. He did, in Tolouse with a heavily instrumented A/C with a test pilot in the left seat. The implication left was that yes, you can recover a stalled airliner. Sully, at what altitude did you perform the stall? Probably 18,000 ft at most! Did you try it in the mid-30s? Or have you ever tried recovering an airliner from an upset maneuver? |
Quoting 32andBelow (Reply 43): I am almost positive all airline pilots have done stalls in the SIM. |
Quoting hb88 (Reply 42): I'm not sure (apart from cost/custom) why commercial pilots wouldn't do stalls as part of training at least in a sim |
Quoting aerodog (Reply 44): 32andbelow Don't confuse full aerodynamic stall with pusher/shaker activation. |
Quoting hb88 (Reply 46): I don't see any reason though why even a fully developed stall in a modern jet a/c would be such a daring thing. |
