Quoting maxpower1954 (Reply 221 from thread 9): Are you talking about the TWA 707 that was bombed over the Ionian Sea in September 1974? Because the sudden climb and out of control descent is very similar. |
Quoting LovesCoffee (Reply 1): Partially true. Except the steep climb was caused by stretched control cables, as quoted from here. Quote:'It was determined that the detonation of an explosive device in the aft cargo compartment buckled and damaged the cabin floor in such a manner that one or more of the elevator and rudder system control cables was stretched and, perhaps, broken. The resultant displacement of control surfaces caused a violent pitch up and yaw and made the aircraft uncontrollable.' The 320 is a FBW (I think the first) AC and would have had no such issue. |
Quoting maxpower1954 (Reply 2): The A320 series has mechanical backup of the rudder and horizontal stabilizer trim, in case of total electrical failure. It allows the pilot to maintain aircraft control until electrical power is recovered. The mechanical back up system is direct control cables from the pedals to the rudder and from the trim wheel to the HS trim hydraulic actuators. |
Quoting LovesCoffee (Reply 3): This may be a silly question |
Quoting maxpower1954 (Reply 2): |
Quoting 777Jet (Reply 4): Are their any commercial FBW aircraft that do not have the said mechanical backups? |
Quoting md80fanatic (Reply 12): So what was it that was said to be 10m x 4m x 1.2m, and how was it moved/lifted/made to go POOF allowing the divers to finally retrieve the boxes? |
Quoting md80fanatic (Reply 12): So what was it that was said to be 10m x 4m x 1.2m |
Quoting md80fanatic (Reply 12): I can't even find a news article that goes into anything but "recorders found!" |
Quoting spacecadet (Reply 14): 3km away from the flight recorders and tail section, if accurate. That would be... odd. |
Quoting lancelot07 (Reply 20): and 3 km from at least a large part of a wing, the part under which the boxes were found. Yes, odd, for the moment at least. |
Quoting mandala499 (Reply 21): speculation warning |
Quoting mandala499 (Reply 21): 1 FA found strapped to his seat, indicates that those onboard were anticipating something. |
Quoting md80fanatic (Reply 19): Still a great deal of obfuscation going on and it seems to me that one of the most important things still unfound in this accident is absolute truth. |
Quoting mandala499 (Reply 21): |
Quoting spacecadet (Reply 23): It still sounds like in-flight upset of some sort is the most likely culprit, with overstress during the descent possibly leading to breakup before the plane hit the water. |
Quoting western727 (Reply 22): If what you speculate is true, that's quite an inflight breakup. |
Quoting pvjin (Reply 24): If that's what happened I guess this wasn't just a simple stall like AF447 as in that kind of a flight condition there shouldn't be high enough forces to damage the aircraft so badly... |
Quoting mandala499 (Reply 28): Seems that the load factor protection of the FBW had failed |
Quoting mandala499 (Reply 21): *trying to keep my sanity* |
Quoting whiteguy (Reply 30): Yeah, anticipating turbulence while flying through a line of thunder storms.... |
Quoting hivue (Reply 31): Does this normally degrade with degraded flight control law (normal to alternate to etc.) or is it supposed to always be present? |
Quoting hivue (Reply 31): Hang in there. |
Quoting mandala499 (Reply 32): The sad thing is the minister of transportation is dishing out silly and reactive policies at the moment which can kill the industry... and I (with a couple of other people) would have to face him off on national TV in 18 hours... wish me luck! |
Quoting western727 (Reply 22): If it's true the HS separated from the rear fuselage which separated from the rest of the aircraft at FL220, then that's huge. |
Quoting mandala499 (Reply 32): wish me luck! |
Quoting lowbank (Reply 35): That got me thinking as the very early data Mandala gave us was that the aircraft was in a left turn throughout until right near the end. |
Quoting hivue (Reply 31): Quoting mandala499 (Reply 28):Seems that the load factor protection of the FBW had failed Does this normally degrade with degraded flight control law (normal to alternate to etc.) or is it supposed to always be present? |
Quoting hivue (Reply 40): load factor protection is normally available in every flight control law but Direct. |
Quoting mandala499 (Reply 21): I am getting it appears that the horizontal stabilizer had separated from the rear fuselage... |
Quoting mandala499 (Reply 21): ... which separated from the rest of the aircraft, at around FL220 |
Quoting mandala499 (Reply 28): -20000fpm, and the last recorded valid barometric info (I just received the info) on the ADS-B, was at FL235, with -15,681.25fpm, at the beginning of a tight left turn. |
Quoting mandala499 (Reply 32): If it goes to ALT with reduced protection ...If it goes to ALT with reduced protection then go into an upset, this needs opening the books |
Quoting mandala499 (Reply 36): I have seen the data and there was a wide left 180 (with a stall in the middle) followed by... a tight left orbit before the data stopped. |
Quoting hivue (Reply 40): If I am reading this correctly (and if it's correct information): http://www.airbusdriver.net/airbus_fltlaws.htm load factor protection is normally available in every flight control law but Direct. (The site doesn't say whether this info applies to all AB FBW models.) |
Quoting mandala499 (Reply 21): From the description I am getting it appears that the horizontal stabilizer had separated from the rear fuselage, which separated from the rest of the aircraft, at around FL220 (where the recorded ADSB altitude is only GEO alt, and no more barometric). From the description of the SAR team, it is unclear if the FDR was found on the sea floor below the horizontal stabilizer or the aircraft wing. |
