Quoting zululima (Reply 216): Any other route would be throwing money down a hole, since (as we currently understand it) this aircraft has ZERO cargo capacity. |
Quoting tommy1808 (Reply 2): If you expect your passengers to check 280-300 bags, then the A321NLR would have zero cargo capacity. In all more realistic cases they still have 2-3 LD3 available for cargo. |
Quoting r2rho (Reply 3): It's not so much a matter of volume. |
Quoting S75752 (Reply 5): But now, it sounds as though its MTOW is coming up short. So what is it? |
Quoting tommy1808 (Reply 6): The A321NLR has a T/W ratio of 0.33 at MTOW, the 757 has 0.34 at MTOW... With the strongest available engine, that wasn't exactly the best seller. |
Quoting S75752 (Reply 7): What's the supposed problem then that some are bringing up? Did the 757 also have the issues that are being described above, with its powerful engines? |
Quoting Pacific (Reply 8): However, on a low-density transatlantic long-range configuration of 165 passengers (TATL 757s only fly 175 pax), you will only be lifting around 15t of payload (165 x 90 = 14,850kg). This means you either have a range of 4,300nm (3,800nm real-world) with zero freight, or 4,000nm (3,500nm real-world) with 3.5t of freight (or fish). This is a significant range improvement over the 757. |
Quoting Pacific (Reply 8): Let's go through several possible scenarios. According to the marketing payload-range chart, the A321LR will have 18,500-19,000kg of payload available at max fuel. This means zero freight at 206 (206 x 90kg = 18,540kg) passengers, and if you cram the aircraft up to the limit of 240 passengers (240 x 90kg = 21,600kg), you have to offload fuel, giving a max range of approx 3,300nm on the payload-range chart. However, on a low-density transatlantic long-range configuration of 165 passengers (TATL 757s only fly 175 pax), you will only be lifting around 15t of payload (165 x 90 = 14,850kg). This means you either have a range of 4,200nm (3,700nm real-world) with zero freight, or 4,000nm (3,500nm real-world) with 3.5t of freight (or fish). This is a significant range improvement over the 757. The A321LR won't manage TATL on with 240 passengers and typical baggage, BUT if luggage weight is significantly lighter on LCCs due to high check-in fees, say average weight of 85kg instead of 90kg giving a payload of 20,400kg, the A321LR will have a marketing range of 3,700nm, allowing UK - East Coast. |
Quoting Roseflyer (Reply 11): |
Quoting Pacific (Reply 12): The interesting thing about the 110kg assumption is that, the A321 will not be viable for more than 215 passengers (23,650kg). The marketing chart shows max payload at a touch below 24,000kg! For some reason, Airbus still bothered to raise the max certified capacity from 220 to 240 passengers for the NEO so the plot thickens. |
Quoting S75752 (Reply 5): The last time I brought up matching the 752's thrust my statement was quickly knocked down
There isn't one. The LR's MTOW went up by 3 1/2 t specifically to accommodate the 2 1/2t extra fuel without having to trade off payload. [quote=Roseflyer,reply=11]You also have to factor in catering weight, headwinds, ETOPS or holding fuel (maybe), so the range numbers come down a bit. |
Quoting Pacific (Reply 12): Quoting Roseflyer (Reply 11): In part 1, several users noted that 90kg was standard but obviously this is debatable! At 110kg x 165, you will have 18,150kg payload so it is basically the zero cargo assumption of 4,000nm marketing or 3,500nm real-world range after headwinds etc. AFAIK, the longest current 757 TATL is EWR-TXL at 3,458nm. The interesting thing about the 110kg assumption is that, the A321 will not be viable for more than 215 passengers (23,650kg). The marketing chart shows max payload at a touch below 24,000kg! For some reason, Airbus still bothered to raise the max certified capacity from 220 to 240 passengers for the NEO so the plot thickens. |
Quoting speedbored (Reply 14): It shows average adult passenger weight including carry-on baggage as between 80kg and 87kg |
Quoting tommy1808 (Reply 15): |
Quoting astuteman (Reply 16): That is true of every range/payload chart. Not one of them factors in headwinds or catering weight (for example) |
Quoting Roseflyer (Reply 17): The Brazilian government mandates 2 free 70lbs bags for each passenger and airlines expect 30kg or more per passenger on southbound routes |
Quoting tommy1808 (Reply 15): Quoting Pacific (Reply 12): The interesting thing about the 110kg assumption is that, the A321 will not be viable for more than 215 passengers (23,650kg). The marketing chart shows max payload at a touch below 24,000kg! For some reason, Airbus still bothered to raise the max certified capacity from 220 to 240 passengers for the NEO so the plot thickens. 2. The US ain't everywhere, other places may have different weight assumptions due to different statistics. |
Quoting Roseflyer (Reply 11): The FAA mandates 195lbs per passenger in weight and balance calculations (in winter) which translates to 90kg |
Quoting tommy1808 (Reply 4): The A321s cargo hauling will be impeded by volume much more than weight. |
Quoting speedbored (Reply 22): Looks to me like Airbus have got it right with this one. |
Quoting Pacific (Reply 18): Also a very valid point for certain markets. I dread to think of how many kg of balikbayan boxes get loaded into Philippine Airlines over Christmas! |
![]() Photo © Mohit S. Purswani - AHKGAP | ![]() Photo © Andrew Hunt |
Quoting Devilfish (Reply 28): Since it's a short puddle jump from HKG-MNL, the bog standard A321 should handle the 20kg/Y and 30kg/J FBA per passenger, no problem... ... |
Quoting Pacific (Reply 29): Ohh, but what about the excess, overweight baggage...I mean boxes! |
![]() Photo © Douglas Wong | ![]() Photo © Wuweican |
Quoting Pacific (Reply 29): Way to treat an 80 year old, PAL customer service - it should have been delivered to her house for free. |
Quoting Pacific (Reply 29): Therefore, that extra hold space that the ACT takes up might pose a unique issue for PAL when it comes to a direct flight to Australia beyond Darwin. |
![]() Photo © Tim Hillier | ![]() Photo © Xing Stanley Li |
Quoting KarelXWB (Reply 30): A321LR analysis by Leeham: http://leehamnews.com/2015/01/15/air...here/ |
Quoting KarelXWB (Reply 30): |
Quoting mjoelnir (Reply 32): |
Quoting lightsaber (Reply 33): I expect with the 78J, A35J, and 779 cargo yields will drop and the airlines flying narrow bodies 3000nm+ won't worry about cargo. |
Quoting Boeing778X (Reply 34): |
Quoting Boeing778X (Reply 34): Of course, the 78J, A35J and 779 won't fly 3000nm routes, and cargo yields on those aircraft will be just fine, the way I see it. |
Quoting Devilfish (Reply 31): Although deplorable, this should remind passengers of the hassles of flying with excess baggage . |
Quoting Pacific (Reply 38): I'm sure balikbayan cargo is a good source of revenue for PAL and therefore I have doubts about the A321LR being a massive benefit to the airline due to unique, local circumstances! |
Quoting Pacific (Reply 38): Therefore as you say, other equipment is more suitable! |
Quoting lightsaber (Reply 35): I expect all, in particular the 78J, to fly the TATL ranges we're discussing. |
Quoting Pacific (Reply 8): Let's go through several possible scenarios. |
Quoting mjoelnir (Reply 36): And they will fly those routes very economical with 150 passengers on average./ |
Quoting Devilfish (Reply 39): The A321LR may not be massively beneficial to PR but it could spell the difference between having a direct service, a one-stop service or no service at all for communities looking to them for air transportation to the old country and back. |
Quoting lightsaber (Reply 41): What struck me is you are comparing a 115.6T airframe with much less efficient 38k engines to a new 97t airframe with much more efficient 35k thrust engines. |
Quoting Boeing778X (Reply 34): Of course, the 78J, A35J and 779 won't fly 3000nm routes |
Quoting eaa3 (Reply 37): Cargo doesn't care about flying direct. |
Quoting KarelXWB (Reply 44): You will be surprised to learn that 55% of all 777 flights are no longer than 3,000 nm. |
