Quoting jfklganyc (Thread starter): The better way would be to extend to the west (towards Manhattan instead of away from it) to the N/Q train |
Quoting jfklganyc (Thread starter): The better way would be to extend to the west (towards Manhattan instead of away from it) to the N/Q train and have a one seat ride to Manhattan. |
Quoting commavia (Reply 3): All I can say is ... about time! |
Quoting OB1504 (Reply 6): attempts to build either an AirTrain or subway extension between LGA and Astoria Blvd or Jackson Heights-Roosevelt Avenue have been unsuccessful due to opposition from local residents. |
Quoting wjcandee (Reply 8): You will be the only one. |
Quoting wjcandee (Reply 7): |
Quoting planemannyc (Reply 5): First connect to Willets Point. Then extend westward to Ditmars Blvd connecting to N/R. Then extend from Willets Point to Jamaica (JFK AirTrain). Then one day - maybe in a hundred years - extend the Ditmars stop to Manhattan. Voila - one seat ride to not only LGA, but JFK too! |
Quoting OB1504 (Reply 6): An AirTrain to Willets Point does go in the opposite direction of Manhattan, but it may be the only way to get such a link built. At least it'll offer both subway and LIRR connectivity. |
Quoting LAX772LR (Reply 9): No he won't, at all. |
Quoting jfklganyc (Reply 12): I think we are being to hard on Cuomo here. This is the path of least resistance. |
Quoting jfklganyc (Reply 12): No residents to deal with No environmentalists to deal with No political support needed to win over THIS IS PRICELESS IN NEW YORK |
Quoting jetmatt777 (Reply 15): Even if it won't work well for local in Manhattan, tourists and visitors are very likely to use it. If it means I sit on a train for a total of 45 minutes, versus 30 minutes in a cab and saving $30, I won't complain. |
Quoting planeguy727 (Reply 13): he M60 is a much better option for those going to uptown Manhattan/Bronx |
Quoting jfklganyc (Reply 12): This is the path of least resistance. |
Quoting werdywerd (Reply 19): Actually, this is |
Quoting jfklganyc (Reply 20): That was the original plan except with the N train running it in the late 90s. Supposed to cost $600 million then. |
Quoting infiniti329 (Reply 21): I think the LGA Airtrain should be routed through Jamaica, it would end up following GCP right into LGA. Same rail connections afforded by the JFK Airtrain |
Quoting jfklganyc (Reply 12): THIS IS PRICELESS IN NEW YORK |
Quoting jfklganyc (Thread starter): The better way would be to extend to the west (towards Manhattan instead of away from it) to the N/Q train and have a one seat ride to Manhattan |
Quoting jfkgig (Reply 1): take the #7 to Jackson Heights and grab the Express Bus |
Quoting jfkgig (Reply 1): This seems like a perfect plan to wind up with a useless pink elephant, which would be of absolutely no use to anybody in Manhattan. Why would anybody in Manhattan go all the way out to Shea Stadium, so that they can backtrack back to LGA with this new train? |
Quoting jfkgig (Reply 1): This makes total sense, so of course it can't happen. A good number of LGA workers live in Astoria. |
Quoting curiousflyer (Reply 10): I guess digging a tunnel from Grand Central to LGA is too expensive. Too bad. |
Quoting jfklganyc (Reply 12): Oh and that Citi Field owner Fred Wilpon building the huge mall there...I bet he likes the link too You can bet the USTA and that giant Tennis Center at that stop like the airport link too |
Quoting werdywerd (Reply 19): Actually, this is Link: http://i.imgur.com/FAaHQ7f.jpg The entire AirTrain would run along the Grand Central Parkway. |
Quoting curiousflyer (Reply 10): connecting at Woodside would have been better. |
Quoting STT757 (Reply 25): The LIRR station at Willets is also a nice hefty walk towards the Billie Jean King Tennis Center. It's also not a pleasant walk. It's literally a bridge of wooden planks. It's not smooth. If it's hot, it's hella hot. If it's raining, it's miserable. If it's cold outside, you freeze. The LIRR station is also not covered. No way in hell will you want to do this with luggage. Does this AirTrain plan include redoing this walk, covering it, providing heating/air conditioning/shelter and some restrooms? Otherwise, no thanks. |
Quoting HKG212 (Reply 28): Of course it has to include that, and much more. I am not too familiar with the site, but it looks spacious enough to accommodate an Airtrain terminus between the Number 7 and LIRR stations, of course with comfortable link bridges, which one hopes will be weather controlled, equipped with moving walkways, etc. |
Quoting jfklganyc (Thread starter): Another AirTrain for NYC! LGA. It would connect to the #7 train and LIRR at Willets Point/LIRR |
Quoting jfklganyc (Reply 32): There is plenty of space there to do whatever is needed. |
Quoting thekorean (Reply 33): There are multiple tracks at Willets Point. Maybe LIRR should think about running LGA express trains from Grand Central and Penn. |
Quoting jfkgig (Reply 1): This seems like a perfect plan to wind up with a useless pink elephant, which would be of absolutely no use to anybody in Manhattan. |
Quoting jfkgig (Reply 1): It would be much easier, cheaper, and faster to extend the #7 or the N to LGA, but that wouldn't present as many opportunities for graft, particularly after Cuomo went to so much trouble to abolish the anti-corruption commission that would oversee such a project |
Quoting planemannyc (Reply 5): I know it won't be cheap (and funding for this line was not very clearly identified). |
Quoting OB1504 (Reply 6): In Cuomo's defense, attempts to build either an AirTrain or subway extension between LGA and Astoria Blvd or Jackson Heights-Roosevelt Avenue have been unsuccessful due to opposition from local residents. |
Quoting spacecadet (Reply 18): But the 7 stops in Times Square and the LIRR stops at Penn Station. A lot of people *are* going to places nearby those terminals. |
Quoting planeguy727 (Reply 13): The M60 is a much better option for those going to uptown Manhattan/Bronx, especially since it became a select bus service. |
Quoting jetmatt777 (Reply 15): Even if it won't work well for local in Manhattan, tourists and visitors are very likely to use it. |
Quoting jetmatt777 (Reply 15): If it means I sit on a train for a total of 45 minutes, versus 30 minutes in a cab and saving $30, I won't complain. That extra 15 minutes can be made up easily by reading an extra news article or opinion piece on the smartphone or tablet. Not the end of the world, really. |
Quoting infiniti329 (Reply 17): does the plan call for connecting into the JFK airtrain? That would be worth its weight in gold. There are so many upsides to this |
Quoting spacecadet (Reply 18): This is the only proposal for a rail link to LGA that actually has a chance of being built. |
Quoting spacecadet (Reply 18): Who would take this? Someone who doesn't want to pay $40 for a taxi. |
Quoting werdywerd (Reply 19): The entire AirTrain would run along the Grand Central Parkway. I think this is the far better route to go, but I have a feeling , like you said, that the plan is to purposely have folks landing in LGA to have a very easy way to get to CitiField for events, concerts, games, etc. Tennis, Malls etc.... |
Quoting stlgph (Reply 34): Grand Central, possible, depending on if the work ever gets done. |
Quoting spacecadet (Reply 18): This is the only proposal for a rail link to LGA that actually has a chance of being built. It may not be perfect, but neither are the EWR or JFK AirTrains |
Quoting werdywerd (Reply 19): I have a feeling , like you said, that the plan is to purposely have folks landing in LGA to have a very easy way to get to CitiField for events, concerts, games, etc. Tennis, Malls etc.... |
Quoting stlgph (Reply 26): Quoting jfkgig (Reply 1): take the #7 to Jackson Heights and grab the Express Bus wow. you're suggesting that's quicker? let's all chuckle together. |
Quoting Mir (Reply 37): But is it worth all that money? At least the EWR and JFK AirTrains connect to large rail lines. This goes to nowhere. |
Quoting Mir (Reply 37): It would be far better for all involved if they took a fraction of that money and put it toward express buses |
Quoting N1120A (Reply 36): East Side Access should happen reasonably soon. Its actually a key part of the Penn/Moynihan Station project. |
Quoting thekorean (Reply 39): By the time Airtrain to LGA opens Grand Central will have access to LIRR. The tunnel to the Grand Central is almost finished, hard part is over. |
Quoting N1120A (Reply 38): The 7 train goes to Times Square and Grand Central, both huge transport hubs and dense hotel/business areas. The LIRR goes to Penn, another major hub. |
Quoting N1120A (Reply 38): People don't take buses. |
Quoting Mir (Reply 41): |
Quoting thekorean (Reply 43): If we factor in delays on AirTrain construction I say I am still most likely to be correct. Airtrain to LGA would not be operational until LIRR has access to Grand Central. |
Quoting stlgph (Reply 42): However, I, along with a large number of other folks, prefer the cabs or the black car services. They pull up, I put my bag in, get in, check my emails, do my phone calls, etc. on the ride, get to the terminal, get out, get my bags handed to me and walk right into the terminal. Hauling suitcases across the 7 train network??? .. I'd rather take a bath of acid. |
Quoting thekorean (Reply 46): |
