Quoting AA767400 (Reply 1): Hopefully, this will open up more LAX-Latin America. |
Quoting N1120A (Reply 4): Seems like a pretty long turn for the plane, however. |
Quoting as739x (Reply 5): I think what he means is the DFW aircraft would otherwise RON in GDL. This uses the aircraft to LAX. And the inbound LAX redeye would in turn depart in the morning to DFW, on what was the DFW RON. Essentially eliminating the RON in GDL and keeps the plane flying and making money. |
Quoting N1120A (Reply 7): Maybe, but where does the A319 that operates the Tecolote to GDL come from? |
Quoting Mah4546 (Reply 9): And any quicker turn would bring the plane into GDL way too early, where it would just have to sit and wait to get to Dallas. |
Quoting Mah4546 (Reply 9): In context it is not a long turn given that it probably will have to be towed from TBIT. |
Quoting N1120A (Reply 10): Of course, though they could use a different aircraft to operate the flight to GDL and turn this plane somewhere else in the network. |
Quoting N1120A (Reply 10): So, has the T4 FIS closed completely? Also, once they move into the 4 preferential gates, they really would only need an hour turn. |
Quoting Mah4546 (Reply 11): Two problems with that are that there is no A319 base at LAX, and that the A319 would have to do a redeye trans-con turn, and AA isn't using the A319s on trans-cons. |
Quoting Mah4546 (Reply 11): Okay, but that would get the plane into GDL way too early. So either it leaves GDL later, or it makes a redeye on a newer route that is a longer distance, like SAL. |
Quoting AR385 (Reply 14): I suppose if any airline has a chance for MTY-MIA to work that would be AA. However, won´t it cannibalize its MTY-DFW feed? |
Quoting Mah4546 (Thread starter): Proposed schedules effective June 4, 2015: AA 903 LAX 0030-0540 GDL Daily A319 AA 985 GDL 1955-2120 LAX Daily A319 AA 231 MIA 1655-1915 MTY Daily A319 AA 319 MTY 0715-1110 MIA Daily A319 Both of these are old AA routes, LAX-GDL last operated in the early 2000s and MIA-MTY in the late 1990s. |
Quoting Mah4546 (Thread starter): The LAX-GDL route simply makes use of an A319 that would otherwise RON in Guadalajara between Dallas turns. |
Quoting AA767400 (Reply 1): Great utilization of the 319! About time AA jumps back on LAX-GDL. |
Quoting Mah4546 (Reply 3): I wouldn't be shocked to see a combination of LAX-SJO/MGA/SAL/GUA. |
Quoting Mah4546 (Reply 11): AA isn't using the A319s on trans-cons. |
Quoting LDVAviation (Reply 15): Effectively, AA has already moved in. |
Quoting MaverickM11 (Reply 18): LAXGDL is so cheap and so local it really does nothing for the network but I guess AA can find out first hand now, even if it's utilization. |
Quoting MaverickM11 (Reply 18): 319 seems awfully big for MIAMTY... |
Quoting Mah4546 (Reply 19): While I agree an ERJ-175 is better for the local market at 45 PDEW, it is likely high fares and probably decent connection flows to Europe/Caribbean given the wealth/stability of Monterrey. And it's easily going to stimulate as much as 100% local market fairly quickly. |
Quoting mhkansan (Reply 22): That LAX arrival seems really late. What connection opportunities are there in LAX at that hour, especially after going through TBIT customs, besides East Coast redeyes? |
Quoting LAXintl (Reply 25): Flight is a play for the large local market - the 2nd largest US-Mexico city-pair as of YE2013. |
Quoting commavia (Reply 24): Nonetheless, it doesn't really matter - this O&D market is so large that the plane can likely be filled - at what fare, TBD - on that basis alone. |
Quoting LAXdude1023 (Reply 20): Historically there has been a lot of wealth in Monterrey, but I wouldnt call it stable. Its one of the cartels favorite playgrounds in recent years. Close to the US border and a large amount of money. |
Quoting Mah4546 (Thread starter): AA 903 LAX 0030-0540 GDL Daily A319 AA 985 GDL 1955-2120 LAX Daily A319 |
Quoting LAXdude1023 (Reply 8): I keep hoping for a DFW-MGA/TGU to complete DFW's Central America portfolio to go along with this! |
Quoting ericm2031 (Reply 33): And is there still a connector planned from T1 to T2 as part of the renovation at LAX for Southwest? I seem to see lots of rumors but no confirmations. |
Quoting SkyBird77 (Reply 32): Me too. However; I think it might be something like DFW-TGU-SAP-DFW (due to runway limitations at TGU) using the A319, and DFW-MGA-DFW. |
Quoting airliner371 (Reply 31): Kind of surprised Southwest didn't jump on this while an authority was available. They haven't tried any international from LAX which surprises me. |
Quoting 32andBelow (Reply 27): I wonder if AS will bleed any of the LAXGDL traffic. |
Quoting LAXintl (Reply 35): |
Quoting Mah4546 (Reply 11): wo problems with that are that there is no A319 base at LAX, and that the A319 would have to do a redeye trans-con turn, and AA isn't using the A319s on trans-cons. |
Quoting LAXintl (Reply 35): Simply a rumor. No such plans incorporated in either the T-1 or T-2 refresh projects. |
Quoting SWADawg (Reply 38): Not a rumor. There will eventually be a connector built. Gate 2 in T1 has been permanently closed in order to accommodate it. |
Quoting Aacun (Reply 43): There's also another city in Colombia that will be announced shortly along with some more DFW-Central America service. As far as I know it will be all A319 service |
Quoting Aacun (Reply 45): Yeah. It's one of those cities in Colombia you mentioned. |
