Quoting tp1040 (Thread starter): I guess this makes it official. They have finally presented the plans to the city council. CLT is proceeding with plans for the 4th parallel runway and expansion. For sometime, the master plan has included the runway. After much wrangling of who controls the airport, I guess that behind the scenes, CLT has been told that the city will maintain control. (this is just speculation on my part) Also, AA must have encouraged the airport to move ahead. |
Quoting Cipango (Reply 1): Mergers can be messy. Lets hope AA don't drop CLT in the not too distant future. AA please don't turn CLT into a MEM, CVG or CLE... |
Quoting bond007 (Reply 2): Yep, I see another St. Louis happening here .... Let's hope their forecasts are correct! |
Quoting commavia (Reply 4): I don't think there is any chance of that happening - CLT is a far better, stronger hub than MEM, CVG, CLE or STL. I continue to find the suggestions of AA fully dehubbing CLT to be highly unlikely. |
Quoting N1120A (Reply 5): PHX is far more likely to CLE'd than CLT is. |
Quoting airbazar (Reply 10): ATL disagrees with this statement, greatly |
Quoting slcdeltarumd11 (Reply 6): I think there is 0% risk of AA leaving the hub but right sized seems likely IMHO they do have MIA now for the Caribbean flights and less Europe with JFK much closer. It will become more domestically focused, but its location is excellent for that. I REALLY hope we don't have another STL in the works here. I think they should put these plans on hold. I guess the best defense just to do it, is the price is pretty low, STL spent $1.1 billion for a runway they totally don't need. If the price can be this low and delays can be minimized I guess theres an argument you can make. |
Quoting bond007 (Reply 7): Quoting commavia (Reply 4): I don't think there is any chance of that happening - CLT is a far better, stronger hub than MEM, CVG, CLE or STL. I continue to find the suggestions of AA fully dehubbing CLT to be highly unlikely. I'm certain that most of the experts said similar things about STL at the time. This industry is brutal, and mostly unpredictable. |
Quoting LAX772LR (Reply 12): Contrary to popular belief, ATL actually has one of the higher O&D to total pax ratios, among the major hubs. Not only have the numbers been posted several times here over the years, but common sense should sorta tell you that: it's the sole gateway to a 6million person CSA, and has no older/smaller airport to zap the O&D. Hubs like MIA/IAH/DFW/ORD/etc all "suffer" from that effect, due to FLL/HOU/DAL/MDW respectively; so it's no surprise that ATL is actually rather strong in its O&D, despite the massive amount of cnnx pax. |
Quoting LAX772LR (Reply 12): Contrary to popular belief, ATL actually has one of the higher O&D to total pax ratios, among the major hubs. |
Quoting slcdeltarumd11 (Reply 6): STL spent $1.1 billion for a runway they totally don't need. |
Quoting AVLAirlineFreq (Reply 19): Does anyone know if closing runway 5/23 and converting it into a taxiway is a part of this plan? |
Quoting airbazar (Reply 10): ATL disagrees with this statement, greatly. And so does DXB while we're at it. |
Quoting airbazar (Reply 17): I have a very hard time believing that. Using this thread from only 1.5 years ago, ATL is not even in the top-10 for O&D markets. But it's the busiest airport in the nation by passenger numbers. Those 2 facts don't line up to create "one of the higher O&D to total pax ratios" Top US O&D Airports (by LAXintl Jun 19 2013 in Civil Aviation) |
Quoting CV880 (Reply 20): With extreme summer temps in the CLT area, just as a safety factor for longhaul takeoffs, one of the runways should probably be at least 12,000'. |
Quoting tp1040 (Reply 25): Quoting AVLAirlineFreq (Reply 19):Does anyone know if closing runway 5/23 and converting it into a taxiway is a part of this plan? I would assume so, back when the FAA shut down 5/23 for the first time, it pushed the airport consider alternatives. If CLT is going to grow, the need to be able to safely handle the traffic. |
Quoting thenoflyzone (Reply 23): There wont be that many long haul flights left in a few years ! |
Quoting thenoflyzone (Reply 23): |
Quoting AFCJETS (Reply 26): MIA has nowhere near the domestic feed CLT has for connections to the Caribbean so if they were to eliminate nonstop from CLT to the Caribbean, it would mean double connections via either one of their other hubs and MIA for many US cities. |
Quoting slcdeltarumd11 (Reply 30): Right size the CLT to Caribbean flying that is exactly what i think will happen. |
Quoting LAX772LR (Reply 9): PHX is plagued with WN, and doesn't really offer anything that LAX+DFW can't easily replicate or do better, except PacNW to Mexico flows... and with WN beginning/ramping up shorthaul int'l services, how long would the yield on such services be worthwhile? |
Quoting AFCJETS (Reply 27): Why did the FAA shut down 5/23 before and when? |
Quoting Moose135 (Reply 34): There were several incidents with aircraft going missed approach from 23 conflicting with departures from 18C. |
Quoting AFCJETS (Reply 35): Why was this not an issue during the first 30 years? |
Quoting Moose135 (Reply 34): When they resumed regular use of 23, they put new procedures in place to better sequence aircraft - now, they will not clear an 18C departure if an aircraft inbound to 23 is within a certain distance of the runway, instead waiting until it lands. |
Quoting AFCJETS (Reply 38): Wouldn't the same procedure need to be in place for the new 18R too? A runway 23 bound jet making a go around would be in the path of a jet departing from either 18R or 18C. I read once 18R is primarily used for landings, but IMO there should still be an official policy in place prohibiting simultaneously landings of 23 and both 18C and 18R takeoffs. |
Quoting cathay747 (Reply 32): OMG, here we go again about PHX being de-hubbed, or likely to be...this is getting as bad as conspiracy theories about who shot JFK! |
Quoting cathay747 (Reply 32): I mean no disrespect to anyone but...PHX is a profitable hub, which has been pointed out ad-nauseum in countless other threads. PHX might be right-sized a bit in order to increase the profitability and fine-tune the network, but it's not going to be de-hubbed. No airline in their right mind is going to de-hub a profitable hub. Period. Next topic please. |
Quoting thenoflyzone (Reply 23): Correct me if i'm wrong, but isn't that ratio at 30% ? 30 million O&D vs 90 + million handled. That's not high at all ! |
Quoting Moose135 (Reply 40): I've been down here almost three years, and I've never seen an 18R departure - if either 18L or C are open, there's no reason to taxi all the way to 18R to takeoff |
Quoting AFCJETS (Reply 43): I've been down here almost three years, and I've never seen an 18R departure - if either 18L or C are open, there's no reason to taxi all the way to 18R to takeoff |
Quoting Mainliner (Reply 42): Quoting Moose135 (Reply 40): I've been down here almost three years, and I've never seen an 18R departure It was pretty common about 3-4 years ago during the resurfacing of 18C. |
Quoting AFCJETS (Reply 44): If anyone has witnessed a takeoff from runway 5 since 1979, I would love to hear about it! If so it must have been between midnight and 630a. I know there are some 6am departures so maybe it happens all the time at that hour ? |
Quoting FLYjoe (Reply 46): We took off on 5 a few months ago. I was on a 6am departure. It was a neat change of pace from the 18/36 departures. I have landed on 5 on a red eye arrival. I couldn't figure out where I was until I saw the US hangar on approach |
Quoting N1120A (Reply 41): |
Quoting Sevensixtyseven (Reply 48): Lies. They don't have that many operational delays in the summer..they did have to delay RJ flights after it topped 117 degrees. The nice thing is T4 is easy to connect through, with excessive empty space compared to LAX. Might I remind you for 20+ years America West built up Phoenix as a hub and happened to make some semblance of money there. 20 million or so passengers departed/arrived in PHX in 2013, as opposed to connecting passengers, which totaled another 20 million, a higher number than LAS or IAH. It may not be the best airport compared to some, but it's hardly a terrible place to have a connection, or fly in and out of. |
