Quoting PassedV1 (Reply 5): some failure scenarios in turbo-props lead to some negative training as far as flipping switches down low. |
Quoting LTC8K6 (Reply 2): They were dropping fast when they went past that building. |
Quoting PassedV1 (Reply 5): I guess my point is that while a jet pilot is trained to climb and then start throwing switches, some failure scenarios in turbo-props lead to some negative training as far as flipping switches down low. |
Quoting migair54 (Reply 3): The message is ENG 1 FLAME OUT or ENG 2 FLAME OUT. difficult to misinterpret but we see what we think sometimes |
Quoting zeke (Reply 9): GE235 flight received take off clearance from SongShan tower at 1051:13, after took off, at 1052:33.8 ATC controller requested the crew to contact Taipei approach. After 5 seconds, (1052:38.3), master warning sounded in the cockpit associated with right engine(2) flame out procedure message on display unit. The crew called it out. At 1053:04.0 the recorded parameters indicated that the left engine power lever(1) was progressively retarded to flight idle. At 1053:24, the left engine condition lever(1) was set to fuel shutoff position resulting in left engine(1) shutdown. Between 1053:12.6 to 1053:18.8, several stall warnings sounded. Flight crew declared an emergency at 1053:34.9 and reported an engine flame out. At 1054:09.2, flight crew called several time for engine restart. At 1054:20 the recorded parameters indicates a restart of the left engine(1). At 1054:34.4, master warning sounded, 0.4 seconds later, CVR recorded unidentified sound. Both recorders stopped recording at 1054:36. |
Quoting flylku (Reply 11): Am I interpreting this correctly? They have a problem on #2 and retard power on #1 and then shut it down? |
Quoting xdlx (Reply 10): Back to ME school 101.... Eng OUT.... 1) MAX PWR 2) Identify 3) VERIFY 4) Feather |
Quoting tailskid (Reply 4): It appears that the PF was intentionally flying down the river valley, avoiding high ground on the left and right. That's if there was a PF - there were three Captains on the FD, all three may have been managing the restart of #1. |
Quoting xdlx (Reply 13): 3 Capt in the cockpit....... ! WTF |
Quoting TheRedBaron (Reply 15): in emergency situation sometimes having more personnel on the cockpit is down right dangerous |
Quoting Kaiarahi (Reply 17): According to the report, there was a flameout warning for no. 2, but the engine had not actually flamed out. The engine autofeathered nevertheless. |
Quoting TheRedBaron (Reply 15): because the CRM goes out the window and most of the time the extra pilots give more input/distract/act and make things confusing. Amsterdam, AF447, Aeroflot, etc etc etc... |
Quoting Kaiarahi (Reply 17): Interesting report in the Taipei Times citing the ASC, which suggests some systems issues: http://www.taipeitimes.com/News/front/archives/2015/02/07/2003610992 According to the report, there was a flameout warning for no. 2, but the engine had not actually flamed out. The engine autofeathered nevertheless. |
Quoting Kaiarahi (Reply 17): but the engine had not actually flamed out. |
Quoting whiteguy (Reply 20): Seems like it was an in commanded auto feather situation. |
Quoting zeke (Reply 22): Quoting whiteguy (Reply 20): Seems like it was an in commanded auto feather situation. #2 flame out with, with low ITT, N, and no FF on #2 would not indicate a false positive in my book. We are addicted to our thoughts. We cannot change anything if we cannot change our thinking – Santosh Kalwar |
Quoting cuban8 (Reply 25): According to the approximate "unofficial" event chart posted by rcair (thread 2 post 171); |
Quoting cuban8 (Reply 25): Any facts pointing in the direction of an actual dual engine failure or any other combination of failures? |
Quoting whiteguy (Reply 20): |
Quoting zeke (Reply 22): #2 flame out with, with low ITT, N, and no FF on #2 would not indicate a false positive in my book. |
Quoting JoeCanuck (Reply 31): That doesn't mean one should just do nothing, but it can give people in command enough time to figure out what the right thing actually is. |
Quoting TheRedBaron (Reply 15): when in emergency situation sometimes having more personnel on the cockpit is down right dangerous, and we have seen it so many times because the CRM goes out the window and most of the time the extra pilots give more input/distract/act and make things confusing. Amsterdam, AF447, Aeroflot, etc etc etc... |
Quoting namezero111111 (Reply 16): I'm gonna be rebutting this with UA232. |
Quoting zeke (Reply 18): It is not correct. |
Quoting Aesma (Reply 183): **Previous thread** Unless the story of the whistleblower is correct and, let's assume, engine 1 was was acting up on the previous flight. The pilot might have assumed that same engine is now broken and without checking anything shuts it down. |
Quoting ComeAndGo (Reply 8): Unless the story of the whistleblower is correct and, let's assume, engine 1 was was acting up on the previous flight. The pilot might have assumed that same engine is now broken and without checking anything shuts it down. |
Quoting bueb0g (Reply 19): AF447: when they lost control, there were only two pilots on the flightdeck. |
Quoting bueb0g (Reply 19): THY 737 at AMS: I don't think the observer pilots made any actions or distracting comments during the accident sequence. |
Quoting LTC8K6 (Reply 30): What is the threshold for the flameout warning? |
Quoting LTC8K6 (Reply 30): Does the flameout warning literally mean the flame is out? |
Quoting PW100 (Reply 34): Based on the prelim FDR data graph released, I find it hard to understand how there was a flame out on engine #2, for several reasons: Looking at #2 engine parameters: * ITT starts to drop 1.5 - 3 seconds AFTER the Master Warning: ENG 2 Flame-Out; * ITT drops and stabilizes at around 400C. This is inconsistent with a flame-out condition (should have been lower, and continuously dropping until impact due cooling effect from windmilling and unburned fuel vapourizing- fuel flow did not stop); * NH, NL and WF only start dropping 1.5 - 3 seconds AFTER the Master Warning; * NH was around 95% (the scale is not accurate enough to reed within 1%) which seems to correspond with normal take-off power. NH drops to around 80%, and stabilizes there. To me, it seems very extremely unlikely that NH could stay anywhere near 80% in an engine flame out event. 80% NH would be around Flight Idle (FI) power . . . * Engine oil pressure was normal throughout the event until impact (oil pumps are driven by NH spool). Looking at the #2 engine parameters, all parameters suggest a rollback of power to FI at the start of the event, consistent with an MFCU (Fuel Control) commanded power reduction. There is nothing in these parameters that suggest any internal engine problem; no hot section problem (like turbine blade failure), no compressor problem (like birdstrike), no stall, no icing, nothing. The important engine parameters behave as in a normal power reduction sequence. |
Quoting LTC8K6 (Reply 32): |
Quoting PW100 (Reply 34): So what was it that commanded the power rollback on #2? Something apparently triggered the ENG 2 Flame-out warning logic. To me, that something was not the actual engine performance (based on the released FDR data graph). I suspect that the answer should be found in the ENG Flame-out logic. |
Quoting Kaiarahi (Reply 14): The ATR72-600 is equipped with ATPCS (automatic takeoff power configuration system) which is armed when power management is in TO mode. ATPCS provides automatic feathering of a dead engine, torque uptrim of the good engine to 100%, and auto rudder trim to counter asymmetric power. My understanding is that power management would normally be switched to CLB at around 400-500 feet, at which point ATPCS protections are automatically disarmed. |
Quoting LTC8K6 (Reply 32): Looks like they actually took about 46 seconds to decide to shut off #1? 22 seconds after the warning, they decide to reduce power to #1 24 seconds later, they decide to shut off #1 |
Quoting TheRedBaron (Reply 36): Also Correct, but the extra personnel in the cockpit "probably" changed the outcome, |
Quoting TheRedBaron (Reply 36): In the end as most accidents, they are a long chain of mistakes that together form a tragedy. |
Quoting AirlineCritic (Reply 39): |
Quoting zeke (Reply 37): The PW127M is a 3 shaft design, it could also mean a failure of the third shaft which couples the power turbine to the reduction gearbox for the prop |
Quoting PW100 (Reply 42): And to my eyes, the FDR graph is pretty clear; no signs of internal failure. |
Quoting zeke (Reply 43): I still cannot figure out how the shut the wrong engine down, surely the beta would have given enough yaw to tell them which side is not generating power. |
Quoting PW100 (Reply 44): I was contemplating to what extent the auto rudder trim would possibly remove some of the natural cognitive clues of engine failure yawing? |
Quoting zeke (Reply 43): surely the beta would have given enough yaw to tell them which side is not generating power. |
Quoting vfw614 (Reply 48): |
