LAXintl
China Eastern Applies For Nanjing-LAX Service
Fri Feb 13, 2015 2:33 am
China Eastern has applied with the DOT to commence service between Nanjing and Los Angeles.
Carrier states it seeks to commence the service on June 30th.
No details on schedule was provided, but was previously it rumored to be 2 or 3x weekly.
OST-2015-TBA
Service from secondary Chinese cities are sure taking off in the last year.
Miami
RE: China Eastern Applies For Nanjing-LAX Service
Fri Feb 13, 2015 2:35 am
A330-300 would be the aircaft.
Here is the application:
http://airlineinfo.com/ostpdf92/716.pdf
Aviation is proof that given, the will, we have the capacity to achieve the impossible. - Eddie Rickenbacker
a380787
Fri Feb 13, 2015 2:37 am
Very interesting they picked NKG over HGH
Now we just need someone to do CTU-LAX (should be Sichuan air but they lack nonstop equipment)
mercure1
Fri Feb 13, 2015 2:40 am
Quoting Miami (Reply 1):
To my knowledge A333 only does domestic/regional ops at MU.
Also does A333 model even have range? NKG-LAX is almost 11000km!
[Edited 2015-02-12 18:44:31]
mercure f-wtcc
LAXintl
Fri Feb 13, 2015 2:42 am
Quoting a380787 (Reply 2):
Dont worry, someone else is working on the HGH flight.
[Edited 2015-02-12 18:43:31]
a380787
Fri Feb 13, 2015 2:48 am
Quoting LAXintl (Reply 4):
CZ is busy with WUH and Xiamen air wants XMN/FOC so maybe it's Hainan ?
Miami
Fri Feb 13, 2015 3:01 am
First off, It's CTU-NKG-LAX not NKG-LAX.
Quoting mercure1 (Reply 3):
NKG-LAX is about 10,590 km. The A333 has a max range of 11,300 km.
S75752
Fri Feb 13, 2015 3:14 am
Quoting Miami (Reply 6):
I'm very skeptical of it being a 333, given that NKG-LAX is about 6580 miles, and that's longer than the longest 332 route which I believe is SEA-HKG.
a380787
Fri Feb 13, 2015 3:21 am
Of course I meant CTU-LAX nonstop. The domestic tag hardly matters.
legacyins
Fri Feb 13, 2015 3:32 am
I would venture to guess that there is a subsidy of some type from Nanjing to start service to the U.S. . Just like Wuhan subsidizes their CZ route to SFO.
S75752
Fri Feb 13, 2015 3:38 am
Quoting legacyins (Reply 9):
Possible, but I actually don't think there necessarily needs to be a subsidy at all for that route. They obviously have DL at LAX, but they also do have quite sizeable operations at NKG as a focus city, so there's comprehensive connections on both ends for it. Seems like a winner.
aaway
Fri Feb 13, 2015 3:44 am
Was discussed a bit in this thread.
If approved as proposed, schedule would be something like this:
NKG - 14:15, LAX - 11:00
LAX - 13:30, NKG - 18:45
3x p/week - Tue/Thu/Sat - is the proposed frequency
A33E (A330-200) is the aircraft type
"The greatest mistake you can make in life is to continually be afraid you will make one." - Elbert Hubbard
texan
Fri Feb 13, 2015 3:56 am
Quoting aaway (Reply 11):
The application states that it will be a -300 instead of a -200.
Texan
"I have always imagined that Paradise will be a kind of library."
aaway
Fri Feb 13, 2015 4:18 am
Quoting texan (Reply 12):
Trust me
LAX772LR
Fri Feb 13, 2015 4:20 am
Quoting S75752 (Reply 7):
DTW-NGO is the longest current A332/A330 flight.
LAXintl
Fri Feb 13, 2015 4:26 am
Unless MU is reconfiguring its A333 fleet with longhaul seat product, it will be the A330-200
Today the A333 does things like ICN, NRT and domestic hops
Add in westbound headwinds, you are adding about 1000mi/1500km to the trip. Too far for an A333 unless you want to leave lots of seats empty.
SESGDL
Fri Feb 13, 2015 4:50 am
Quoting LAX772LR (Reply 14):
DTW-PEK is actually the longest current A332 flight - at least being operated by DL.
Jeremy
[Edited 2015-02-12 20:51:02]
LAX772LR
Fri Feb 13, 2015 6:04 am
Quoting SESGDL (Reply 16):
Since when??
DTW-PEK has long been a 744, and IINM, it still is.
hoons90
Fri Feb 13, 2015 6:36 am
Quoting LAX772LR (Reply 17):
Since when??
DTW-PEK switched over from 777 to 332 at the beginning of the Winter schedule. DTW-PVG is still a 744.
The biggest mistake made by most human beings: Listening to only half, understanding just a quarter and telling double.
SESGDL
Fri Feb 13, 2015 7:15 am
Check the flight status; it's been a 332 for a while.
Jeremy
LAX772LR
Fri Feb 13, 2015 7:22 am
Ah, okay... got the two confused.
celestar
Sat Feb 14, 2015 1:28 am
As more and more Chinese airliner operator switching to direct flight to USA, it could be a threat to the traffic for CX and KA where I think they have quite some feed from PRC to HK and then to international destinations.
LAXintl
Sat Feb 14, 2015 1:42 am
Quoting celestar (Reply 21):
Based on an analysis I've seen, the China pie itself is growing so fast that there is plenty of demand to go around for all players.
Look at the CX/KA network to China, with 20 odd destinations they still offer one of the best means of access anyone has plus obviously there are big underlying O&D demand to HKG itself they service as well.
