Quoting LHCVG (Reply 1): Not exactly an answer to your question, but worth noting that some RJ's don't HAVE a true R1 door, just a mini "service door" for galley cart loading and etc. So that shows how strong the L1 thing is that some planes are designed without even the ability to do R1 boarding. |
Quoting Boeing778X (Reply 2): I also know MD-80/-90s have tiny service R1 doors too. |
Quoting AA737-823 (Reply 3): As well as all 6000+ 737's. They're not as tiny as the DC-9 family or the RJ's, but you still must duck to get in or out of them. Most people don't realize that fact, until they're in the midst of an evacuation...! |
Quoting Boeing778X (Reply 4): Fair enough. Now, loading through the REAR of the aircraft! Now there's a topic of discussion. |
![]() Photo © George Canciani | ![]() Photo © George Canciani |
Quoting skywaymanaz (Reply 9): I boarded a TWA L-1011 at the old Sundrome T6 from the R1 door |
Quoting skywaymanaz (Reply 9): I boarded a TWA L-1011 at the old Sundrome T6 from the R1 door. |
Quoting warreng24 (Reply 18): IIRC Gate 4 at PHX Terminal 2 had a R1 jet bridge. There's that vintage photo of a TW L10 at Gate 4 floating around somewhere... |
Quoting Boeing778X (Reply 4): Now, loading through the REAR of the aircraft! Now there's a topic of discussion. |
Quoting Boeing778X (Reply 2): That's true about RJs. I also know MD-80/-90s have tiny service R1 doors too. |
Quoting SKAirbus (Reply 25): |
Quoting cloudboy (Reply 27): Is there any benefit from using doors on both sides? |
Quoting antoniemey (Reply 28): well, on a widebody with two aisles, you have the passengers sitting on the right side of the plane board through the right door and the passengers sitting on the left board through the left door. The middle section could board through either side. |
Quoting CALPSAFltSkeds (Reply 29): Before ORD built the "new" C Concourse, there was a "Y" area at the end of the B/C international concourse where 2 747s could park, both using the R1 or R2 doors. Originally, CO used to park all their 747s (to DEN and LAX) at those gates, which was quite a hike from the ticket counter. At first 1 aircraft used door 1R, and the second aircraft was tugged into the gate area and made a right turn so the L1 door could be used with both aircraft being sort of nose to nose. This took quite a bit of time and someone came up with the new scheme, where that aircraft came straight in and used door 1R. |
Quoting Boeing778X (Reply 4): |
Quoting xero9 (Reply 37): This will blow your mind https://www.youtube.com/watch?v=Nxd5d7iFRBM#t=60 |
Quoting global2 (Reply 38): I wonder if they've calculated how much time is saved boarding/de-boarding using two jetbridges, and therefore how much faster a turnaround is, how much more flying time can be gained, etc. Of course, all that has to be weighed against the additional cost of having additional staff to operate the 2nd jetbridge. Regardless, from a passenger's point of view this must be perceived as a huge improvement! |
Quoting phatfarmlines (Reply 34): Quoting CALPSAFltSkeds (Reply 29): Before ORD built the "new" C Concourse, there was a "Y" area at the end of the B/C international concourse where 2 747s could park, both using the R1 or R2 doors. Originally, CO used to park all their 747s (to DEN and LAX) at those gates, which was quite a hike from the ticket counter. At first 1 aircraft used door 1R, and the second aircraft was tugged into the gate area and made a right turn so the L1 door could be used with both aircraft being sort of nose to nose. This took quite a bit of time and someone came up with the new scheme, where that aircraft came straight in and used door 1R. CALPSAFltSkeds, are the gates where the NW DC-10 is parked are the gates you are describing? ORD Old Int'l Concourse There's another photo floating around showing a National 747 at Terminal 6 JFK using the R1 boarding door. Seems this was quite common in the 70's when airports where trying to accommodate the "widebody rush" at terminals not quite designed for widebodies. |
Quoting longhauler (Reply 47): Early in B747 operations, AC used to use both the L1 and R1 door at YVR. |
