ordpark
AA 183 Diverting?
Wed Feb 18, 2015 7:23 pm
AA flight 183, LAX/PVG appears to have just diverted to SFO....anyone know why?
flflyguy
RE: AA 183 Diverting?
Wed Feb 18, 2015 7:53 pm
Medical emergency. Showing scheduled to depart SFO at 1245.
The views expressed are my own, and not necessarily those of my employer.
as739x
Wed Feb 18, 2015 10:40 pm
Correct. Medical, and ate up most of 28L with an overweight landing. It got everyones attention rolling past T3 in full T/R. Parked at AA T-2 gates.
cathay747
Wed Feb 18, 2015 11:17 pm
yes, and I love how their FLIFO shows "pax service" as the reason...also note...the flight will not be leaving SFO
until tomorrow morning! I presume because they have to do a serious maint. check due to that overweight
landing:
AA0183/18FEB
$DTE CHNG FLT$ ORIG 18FEB
LAS 0715 D19
LAX 2 T4 48A 0827 0955 T4 41
SFO $ 1015 1030 57
PVG D81 1610
4LAS/OUT0711 OFF0728 *0928
2LAX/IN0827 *1028
4LAX/OUT0946 OFF1005 *1205
2SFO/IN1126 *1327
3SFO/ETD0915 *1528
5PVG/INTMD LNDG AT SFO ETA1115RMKS PAX SERVICE *1355*QSDWJG
2PVG/PRE1419 *1528
Try a Little VC-10derness
Maverick623
Wed Feb 18, 2015 11:34 pm
Quoting cathay747 (Reply 3):
AA codes medical diversions under passenger service. Flt 135 LHR-LAX diverted also to ORD for a medical issue and also shows up in FLIFO as pax service.
landing:
That and crew issues, although it's currently posted as a maintenance delay in DECS.
"PHX is Phoenix, PDX is the other city" -777Way
A346Dude
Wed Feb 18, 2015 11:39 pm
Gotta feel bad for AA on this one. Talk about expensive, for something they have no control over. Presumably they thought they could immediately continue on, otherwise a return to LAX probably would have made more sense?
Hopefully the passenger recovers.
You know the gear is up and locked when it takes full throttle to taxi to the terminal.
NickLAX
Thu Feb 19, 2015 2:10 am
Flew this same flight last May and 20 min after departure a pax 2 rows behind me had bad seizures. Initial plan was divert to SFO but changed quickly to go back to LAX. Expedited approach and we were on the ground 20 min after that. LAFD paramedics came on quick and removed the pax who was a bit more stack l stable. Took an hour 25 to wait on MX to verify brakes cooled enough to leave again.
Got in to PVG 3 hr late. Enough time still to make a connect to Shenzhen - or so I thought. Flight canceled. Can't blame AA for that.
MKIAZ
Thu Feb 19, 2015 4:12 pm
Quoting A346Dude (Reply 5):
This is just one of those cost of doing business things. If you have a big enough airline I'd imagine you can estimate the yearly costs of medical diversions very closely.
cathay747
Thu Feb 19, 2015 9:58 pm
Quoting Maverick623 (Reply 4):
Interesting...thank you! What is DECS?
MGASJO
Thu Feb 19, 2015 10:34 pm
Quoting cathay747 (Reply 8):
DECS is a partition of SABRE which handles most of the operational issues (flight plans, weather, weight and balance, ACARs messages, detailed flight information, delays etc).
RES is the partition which handles the passenger service, reservations and training side, amongst other things
Endless Reserve
cathay747
Fri Feb 20, 2015 2:58 pm
Quoting MGASJO (Reply 9):
I see. Thank you for the info!
