KarelXWB
Lufthansa Releases 4-class A380 Seat Map
Thu Feb 19, 2015 8:21 am
Later this year Lufthansa will deploy Premium Economy across its A380 fleet. The carrier now revealed the seat map of the new four-class cabin configuration.
- 8 First
- 78 Business
- 52 Premium Economy
- 371 Economy
http://oi57.tinypic.com/e0pjco.jpg
http://oi60.tinypic.com/2lo3hvc.jpg
[Edited 2015-02-19 00:21:53]
330lover
RE: Lufthansa Releases 4-class A380 Seat Map
Thu Feb 19, 2015 8:36 am
Britten Norman Islander VP-FBR on Falkland Islands. THAT'S FLYING!
migair54
Thu Feb 19, 2015 9:09 am
it´s a very high yield plane, where are they currently flying the A380?? I see one usually all the day in JNB for the red eyes both ways, so they must be doing very good to have a plane sitting in JNB for the full day almost.
I hope we can see some pics of the new Economy comfort installed in the planes soon, and some trip reports.
LTH
Thu Feb 19, 2015 9:22 am
Interesting development. Let's see if they'll stick with two different configurations.
LTH
330lover
Thu Feb 19, 2015 9:32 am
Quoting migair54 (Reply 2):
SIN
PVG
DEL
JNB
MIA
IAH
SFO
[Edited 2015-02-19 01:32:49]
SCQ83
Thu Feb 19, 2015 9:33 am
That economy section in the upper deck looks interesting. I wonder if it is worth to pay for Premium Economy if you can catch an emergency exit on the side seats up there.
aviationaware
Thu Feb 19, 2015 10:25 am
Quoting 330lover (Reply 1):
actually, they have 2 configs on their website
8F/92C/52E/336M:
http://www.lufthansa.com/mediapool/p...2092%20C%2F%2052%20E%2F%20336%20M)
8F/78C/52E/371M:
http://www.lufthansa.com/mediapool/p...2078%20C%2F%2052%20E%2F%20371%20M)
The Economy section in the rear of the upper deck is a quick change section, so the two configurations can be interchanged fast and easily.
330lover
Thu Feb 19, 2015 10:53 am
Quoting AviationAware (Reply 6):
ok, thanks for the info.
When you say 'quick change section', you mean quick as in '4 hours' or as in '1 day'?
Just curious how fast they can change it. I suppose they won't change it for just a few flights, and then change it back?
Flyglobal
Thu Feb 19, 2015 11:22 am
For what its worth,
between LHs economy class and the premium economy is a huge difference for larger guys like me with 1,93m.
Also the width with 8 accross instead of 10 in the lower deck is good.
I just experienced LH' premium eco in the 748i from HN to FRA and it was great.
Could be one of my standards if I refuse to pay LH's prohibitive charges for their Business class when I have to book on shorter notice.
Flyglobal
Motorhussy
Thu Feb 19, 2015 11:24 am
Quoting SCQ83 (Reply 5):
Presumably one would have to board on the main deck and get to the upper deck Y-class seats via the rear stairs. Think I'd rather be in the spacious main cabin. Or better still, pay for Y+ at the front of the main deck. Presumably Y+ will have better food and booze, and higher w/c to pax ratio as well as more spacious seats?!
come visit the south pacific
aviationaware
Thu Feb 19, 2015 12:05 pm
Quoting 330lover (Reply 7):
If the 747 fleet is and indicator, it will take around 6 hours to reconfigure it. It is mainly thought as a tool to manage capacity on a seasonal basis, not on a flight-to-flight. The A380 used to be an oddball in the Lufthansa long haul fleet as it was the only one that did not change configurations seasonally at least in a part of the fleet.
jfk777
Thu Feb 19, 2015 12:59 pm
The Premium Economy section has the best real estate on the A380, they should put First Class or some Business on the first floor and the Y+ on the rear upper deck.
aviationaware
Thu Feb 19, 2015 1:58 pm
Quoting jfk777 (Reply 11):
Why? What makes that section so much better than any other?
First and Business are upstairs for a reason, the upstairs is narrower than the main deck. They can't go more abreast in those classes, so any additional width would go into the aisles while losing Economy seats. Makes no sense at all.
Also makes no sense. Takes away flexibility. Also, with the configuration as it is, the Y+ can deplane before the normal Y passengers, just as it is supposed to be.
jfklganyc
Thu Feb 19, 2015 2:28 pm
What other airlines seasonally reconfigure their fleets?
jfk777
Thu Feb 19, 2015 2:38 pm
Quoting AviationAware (Reply 12):
Quoting jfk777 (Reply 11):The Premium Economy section has the best real estate on the A380
Since many operators place their First Class suits there, that is what is so special about zone A. Singapore, Qantas, Air France to name 3.
Quoting jfk777 (Reply 11):they should put First Class or some Business on the first floor
Zone A is more premium space then the rear of the upper deck so it should have a higher class. J class is better on the upper deck if zone a on the lower is used for First Class but a small J cabin( along with more J class upstairs) is better in zone A then Y +.
Quoting jfk777 (Reply 11):and the Y+ on the rear upper deck.
BA, AF, LH, Qantas and now Singapore have Y+ and all except LH place the Y+ on the rear upper deck. LH may discover having a split J class cabin is better then the whole length of the upper deck.
Someone83
Thu Feb 19, 2015 2:49 pm
Quoting jfklganyc (Reply 13):
I think Finnair is doing it on some of their long haul aircraft as well
LTH
Thu Feb 19, 2015 3:38 pm
I'm sure LH and all the other airlines put a lot of thought into their specific configuration. I don't think that one is better or one is worse. They're different to cater the airlines specific needs (what ever they may be).
Same with Air China putting their new First Class between door 1 and 2 instead of the nose or upper deck section on their new 748s.
LTH
Flighty
Thu Feb 19, 2015 3:57 pm
With 509 total seats, this is one of the higher density A380 configs. It also appears to tolerate lots of premium demand. Good use of space.
JAAlbert
Thu Feb 19, 2015 4:38 pm
It's astonishing to me that an airline can fill so many premium seats on a consistent basis. Although I realize the first and business class may not go out full on every flight, still an airline doesn't install more seats than it thinks it can reasonably fill. LH must make a killing on a flight when its premium classes go out full.
galleypower
Thu Feb 19, 2015 5:08 pm
Quoting LTH (Reply 16):
FWD UD is by far the quietest place on the plane, so FC there makes most sense. Also LH has put in additional noise insulationan in that zone. It is REALLY quiet. Due to FC U1L door is the first one to open, so it makes sens to place the next most valuable pax, CC, next to it to provide fast deboarding. Also. in FRA, termianal facilities are set up to board UD straight from the lounges. U wont see any changes here. Next door to open is M1L, PY will be the first to deplane MD. Due to the uncompliceted config change opportunity, MD FWD was the most probable spot to place PY.
Selecting process was quite detailed with all the pros and cons evaluated. This made the most sense.
jfk777
Thu Feb 19, 2015 6:19 pm
Air China did this on their 744 too, the only airline to put First between L1 and L2 doors.
aviationaware
Thu Feb 19, 2015 10:02 pm
Quoting jfk777 (Reply 14):
Reasoning by analogy. Completely lacking any logic. Just that others place their First Class there doesn't make it the universally best spot to place it and has no implication on other carriers choices in itself.
Reverse reasoning. What makes it more premium? Is that your personal opinion or a fact?
A conclusion derived from completely screwed up reasoning. Try reasoning from first principles next time instead of looking at what others are doing.
The way Lufthansa has chosen to place the classes in the A380 is the most efficient way for them. As I have pointed out above, their F an J seat configurations would waste a lot of space on the main deck and thus reduce the overall seat count and revenue potential of the plane.
You can put 2-4-2 Premium Economy on the main deck but only 2-3-2 on the upper deck, but you can only put 2-2-2 in Business Class on either, so what makes more sense? It's really a no brainer.
MarcoPoloWorld
Fri Feb 20, 2015 3:41 am
Quoting AviationAware (Reply 21):
We have been given good advice here to "take the high road and others will follow". May I suggest you at least consider that as an option?
Quoting KarelXWB (Thread starter):
At least one of those seat maps have been out for awhile - including bookable seat maps on the LH site - but this is great info nonetheless.
I myself have grabbed a premium economy seat for a flight this spring from SFO to Europe, and look forward to trying the new product in the superjumbo configuration. Based on my recent experience of premium economy on a couple of other airlines, this p.e. product should be a winner for Lufthansa as well.
TWA772LR
Fri Feb 20, 2015 3:44 am
When should this config be rolled out?
[Edited 2015-02-19 19:45:30]
When wasn't America great?
DocLightning
Fri Feb 20, 2015 4:43 am
52 Premium Economy
On an AF A340 there are three rows of Premium Y. On the A380 there are 4 plus a middle for 31 seats. I wonder why LH has so many...
-Doc Lightning-
-Carl Sagan
Someone83
Fri Feb 20, 2015 7:53 am
Quoting DocLightning (Reply 24):
Different markeds, differemt demands
tommy1808
Fri Feb 20, 2015 8:04 am
Quoting galleypower (Reply 19):
Well, according to Boeings Marketing the A380 is too quiet. Lufthansa only addresses that now by putting the best seats where the noise level is just at the right premium level.
Maybe as simple a reason as the A340 being about right or a little low on capacity as to what they like and can consistently fill, while the A380 is a bit big and "wasting" space on a large Y+ hits just a different yield/m2 point with better margin/m2.
best regards
Thomas
This Singature is a safe space......
N1120A
Fri Feb 20, 2015 10:26 am
Same situation in JNB as in South America. In order to maximize proper connections and appropriate flight times, given the little to no time difference, you have to "waste" the plane.
How fast and easily? I must admit, this interests me, because these new C class seats are not exactly uncomplicated.
I think BA does.
Who cares what they do?
How is it? I think the premium space is where the better food and seats are.
jfk777
Fri Feb 20, 2015 2:05 pm
Quoting N1120A (Reply 27):
Quoting jfk777 (Reply 14):Zone A is more premium space then the rear of the upper deck so it should have a higher class.
By that reasoning every airline should put First Class in the rear and Business Class in front of that and coach in the front. Gee that would really work ? NOT
N1120A
Fri Feb 20, 2015 4:51 pm
Quoting jfk777 (Reply 28):
It would if it was the most viable way of doing it. As noted, CA has put F between L1 and L2 on the 747 for years.
In this case, LH is making the most efficient use of space that allows for a very premium product.
Viscount724
Sun Feb 22, 2015 12:03 am
Quoting Someone83 (Reply 25):
It's probably a good indication that LH carriers more premium traffic than AF. LH also has a significantly higher percentage of widebodies with F class than AF.
galleypower
Sun Feb 22, 2015 2:02 pm
Quoting N1120A (Reply 29):
The trick is to balance use of space and exclusivness of your premium product. Depending on which direction you let it swing, you will end up with a diffrent layout. LH favors the exclusivnes. Same product, small cabin, 8 seats on evey a/c, very exclusive and hard to get to product, no private travel for staff unless senior managment level. You know, if you got in, you made it. That is just one approach. The other is good product, better use of space, fairly easy access (miles or other upgrade policy) to burn up all those FTL miles, etc. Just pick either one and your layout will look different.
olle
Sun Feb 22, 2015 3:54 pm
This is a full A340 with premium seats.
What a money printer when full.
jfk777
Sun Feb 22, 2015 8:55 pm
Then let put First Class in row 99 and coach in row 1. Never heard such a ridiculous idea.
antoniemey
Mon Feb 23, 2015 2:47 am
Quoting jfk777 (Reply 33):
I think that would work as well as any other arrangement.
Make something Idiot-proof, and the Universe will make a more inept idiot.
galleypower
Mon Feb 23, 2015 3:01 pm
What you mean is premium service! Coincidentally one finds that at premium space areas, which are as far forward as you can get, less noise, less turbulence and prime spot for a fast deplaning.
