Quoting jfkgig (Reply 146): I doubt you have any support for that statement. Compared to BBC or CNN, I find Fox to be much more reliable and without bias. But this isn't a cite -- nor a time -- to be talking about media. |
Quoting na (Reply 145): I meant in terms of deaths. The Nairobi crash of 1974 claimed less than half as many deaths than is feared now. |
Quoting LXLucien (Reply 43): |
Quoting windshear (Reply 147): Given the rate of descent and the 400kt airspeed, could indicate that they used the spoilers for the descent |
Quoting wilco737 (Reply 87): 3000-4000 ft/min is not a normal descent, but not something which is dangerous. At high altitude with thrust at idle you can easily reach that rate of descent and it doesn't need to be an emergency. I did that myself and I have seen higher rate of descents. So please lets not jump to conclusions or any accusations. |
Quoting vlada (Reply 150): The sequence of events seams similar: steady flight, then a descent without changing the flight path/speed and finally a crash into a mountain. |
Quoting anfromme (Reply 62): According to news on German WDR2 radio just now, the pilot did set off an emergency call to ATC. |
Quoting zeke (Reply 155): This is not going to be a good outcome. |
Quoting BestWestern (Reply 160): The french PM was quick to say little chance of survivors. What does he know? |
Quoting wilco737 (Reply 162): I am really shocked... |
Quoting Delta777Jet (Reply 138): Looks like controlled flight into terrain. Pilots did not divert from route, not even tried to get out of the mountain area and descended right into the mountains. If it is true that they send a distress call right before impact, it means that they tried to get control back, but then realized they won't and send a call out. Terrible. |
Quoting SCQ83 (Reply 52): |
Quoting wilco737 (Reply 162): Every crash is a shock, but if it is your own company it is worse.. I am really shocked... wilco737 |
Quoting AirPacific747 (Reply 104): I've occasionally done up to 6000ft/min descent rate in the A320. 3-4000ft/min is not unusual in my opinion. |
Quoting wilco737 (Reply 105): Yes, me too. But I usually stay between 2500-3000 ft/min. Better for the cabin rate controller and the comfort. But 6000 is easily possible, especially if you use the speedbrake... |
Quoting MadameConcorde (Reply 168): |
Quoting travelavnut (Reply 164): |
Quoting LovesCoffee (Reply 167): Quote:"The incident was confirmed yesterday by a spokesman for the German flag carrier, which also is immersed in full strike by pilots. The spokesman also said the incident occurred in an Airbus A321 carrying 109 passengers from Loiu to the Bavarian capital in southern Germany. The apparatus was 9,000 feet high when it began to fall at a speed of 1000 meters (I added 3,000 feet) per minute. Thus, the pilots tried to stop the fall with manual controls navigation, but it proved impossible and this maneuver did not produce the expected results. They regained control avoiding the accident, finally, once they turned off the flight computer." |
Quoting aircatalonia (Reply 151): Really concerning. It seems that the crew was unable to regain control of the airplane for 10 minutes. A computer glitch? |
Quoting wilco737 (Reply 162): Every crash is a shock, but if it is your own company it is worse.. I am really shocked... |
Quoting jfkgig (Reply 146): I doubt you have any support for that statement. Compared to BBC or CNN, I find Fox to be much more reliable and without bias. But this isn't a site -- nor a time -- to be talking about media. |
Quoting garpd (Reply 84): Shades of Air Inter 148! |
Quoting JoKeR (Reply 92): structural failure |
Quoting JoKeR (Reply 92): or a deliberate act |
Quoting wilco737 (Reply 172): Makes all the other issues so unimportant... 150 people are dead wilco737 |
Quoting kaitak (Reply 154): There was a Luftwaffe Tu-154 which had a mid air collision with an American C-141 off the coast of Namibia - I think that had a higher toll, but of course it was military (inherited from the E German air force). |
Quoting IADCA (Reply 166): Not to be excessively pedantic as I suspect English is not your first language, but it can't be a "controlled flight into terrain" if the pilots "tried to get control back |
Quoting seahawk (Reply 175): Quoting LovesCoffee (Reply 167): Quote:"The incident was confirmed yesterday by a spokesman for the German flag carrier, which also is immersed in full strike by pilots. The spokesman also said the incident occurred in an Airbus A321 carrying 109 passengers from Loiu to the Bavarian capital in southern Germany. The apparatus was 9,000 feet high when it began to fall at a speed of 1000 meters (I added 3,000 feet) per minute. Thus, the pilots tried to stop the fall with manual controls navigation, but it proved impossible and this maneuver did not produce the expected results. They regained control avoiding the accident, finally, once they turned off the flight computer." And some sources said that LH was aware of the problem but did refuse to change the air data sensors |
Quoting SCQ83 (Reply 183): I was watching the Spanish TV and there was a journalist at BCN saying that there was no one from either Germanwings or Lufthansa at the airport (and they have a big operation there, BCN is not a small regional airport for them). Is this normal? |
Quoting r2rho (Reply 174): Could someone post a screenshot of the FR24 track? It seems the link or site is down. Thanks |
Quoting HPRamper (Reply 186): Additionally, news these days is focused completely on speed instead of accuracy. Journalism has turned into a cheap game of who can tweet the fastest breaking news with little regard for actual fact. It should surprise nobody that such simple things as airplane manufacturer or stock photographs are rarely correct on any major network. |
