Quoting Rara (Reply 2): Try holding your breath for 30 seconds, see if you die.
Sea level pressure is not the same. At 38,000ft, loss of consciousness is less then a minute, and depending on the individual, loss of reason and clarity is much quicker then that.
Quoting bueb0g (Reply 43): Quoting bgm (Reply 11):You're missing the point he was trying to make, and that is the body can survive without oxygen for 30 seconds.
Not at altitude. |
First one becomes befuddled, the ability to think clearly is lost rapidly at that altitude, like you are getting progressively drunk with each passing second. And it just gets worse till unconsciousness hits, unless oxygen is provided. When I went through altitude chamber training at Beale AFB, you could see who were the violent drunks, and those who you would party with.
Quoting bueb0g (Reply 43): Quoting Rara (Reply 29):His assertion was that all passengers and crew were dead within 30 seconds from asphyxation. Living room or not, that's just medically non-sensical.
Dead, no. But the essence of his point was correct. |
30-60 seconds window to get things sorted before it is too late. Yes, death takes longer then loss of consciousness which in turn is much later then the onset of clouded reasoning and judgement. And each person has a different threshold, but it will still get you.
Had a 10 question quiz we were to answer after taking off our O2 masks in the altitude chamber. The last question, was how far could a person run into a forest before that person started to run out of that forest. Tried to write 'halfway', but it came out as 'middle of the trees', and my pencil trailed off towards the bottom of the form as I lost consciousness.
At 30 seconds, you should still be alive, but unconscious. Not a good thing in a aircraft.
