Here the link to part 7 again:
Germanwings A320 Crashed Enroute BCN-DUS - Part 7 (by bnatraveler Mar 25 2015 in Civil Aviation)
wilco737
Quoting CXfirst (Reply 177): Where they reporting A320 hours, or total hours? |
Quoting Istanbuler83 (Reply 184): -if the pilot does not unlock the door. you can enter the emergency code (which is different than the regular one) and the door get automatically unlocked only after 5 MINUTES for only 30 SECONDS. So, the question is, what is about the remaining 3 minutes? |
Quoting curlyheadboy (Reply 1): Is there a procedure for if the pilot is alone in the cockpit and feels suddenly very sick, and is descending to a lower altitude part of it? |
Quoting curlyheadboy (Reply 1): I understand the pilot should not be alone in the first place, but I still was wondering... |
Quoting racko (Reply 2): We don't know when the Captain (do we actually know it was the captain who was locked out?) returned |
Quoting wilco737 (Reply 4): Well, we have physical needs as well and we don't have a toilette in every airplane cockpit. (the BOeing 747-8 has a lavatory in the cockpit). |
Quoting curlyheadboy (Reply 1): Question for pilots and experts: Is there a procedure for if the pilot is alone in the cockpit and feels suddenly very sick, and is descending to a lower altitude part of it? I understand the pilot should not be alone in the first place, but I still was wondering... |
Quoting curlyheadboy (Reply 6): I know even if I'm not an aviation expert bout I understand (correct me if I'm wrong), a flight attendant should be in the cockpit during the pilot's bio-breack |
Quoting curlyheadboy (Reply 6): correct me if I'm wrong |
Quoting wilco737 (Reply 8): Nope, I just get up and to the toilette and return asap. But no FA needs to be in the cockpit during that time. |
Quoting tailskid (Reply 9): You're wrong. In the US that's the rule, but not elsewhere. |
Quoting aw70 (Reply 15): I don't understand why so many people here seem to be focused on foul play having occurred. |
Quoting tim73 (Reply 13): Now there are two similar air quality-gone-bad incidents for the same airliner and this looks like another one, only with dire consequences. Unless this is a suicide |
Quoting tim73 (Reply 13): Then hit with huge lawsuits and recalls of millions of cars and reputation taking a big hit. |
Quoting tim73 (Reply 19): |
Quoting wilco737 (Reply 14): I pull out of the discussion. |
Quoting racko (Reply 2): And it has been implied by people familiar with the door mechanism that if you do not want someone to enter, they can't enter, period. The locking mechanism wasn't designed to protect the plane from people inside the cockpit but outside it. |
Quoting LTBEWR (Reply 25): That the NY Times, considered to be leading and respected newspaper in the USA, published this allegation also shows a huge flaw in their editorial management, likely done to get more people to buy their paper or their subscription fee website. |
Quoting racko (Reply 10): That apparently depends on the airline, some require to always have 2 people in the cockpit, some don't. LH doesn't. |
Quoting aw70 (Reply 15): I don't understand why so many people here seem to be focused on foul play having occurred. All it would have taken for this to happen is for the remaining pilot in the cockpit to suffer a massive stroke or aneurysm while the other one was in the lavatory. When suffering the stroke, the pilot accidentally pressed some buttons, or pushed the stick forward. |
Quoting Delta777Jet (Reply 31): Quoting aw70 (Reply 15): I don't understand why so many people here seem to be focused on foul play having occurred. All it would have taken for this to happen is for the remaining pilot in the cockpit to suffer a massive stroke or aneurysm while the other one was in the lavatory. When suffering the stroke, the pilot accidentally pressed some buttons, or pushed the stick forward. Yes that could happen, but the other pilot would have been back and normally get through the door by entering the emergency access code. It's very hard to believe that the ill pilot would bend himself over the lock cockpit door button in such event. |
Quoting travelavnut (Reply 28): Please stay Wilco, your input is highly appreciated. I know it's difficult, but please ignore the idiots. |
Quoting tim73 (Reply 26): Quoting tailskid (Reply 22): I'm pressing the suggest deletion button on you. You are out of touch and over the top. That is the preciously the attitude in safety issues which causes accidents. Somebody suggesting a little bit controversial must be put down immediately! Tell me, what exactly in my reasoning is wrong? This looks like that "one in a million car acceleration" problem to me. Very difficult to find but it is there. |
Quoting KarelXWB (Reply 29): And here's the switch in the cockpit: |
Quoting tim73 (Reply 19): That is hiding behind numbers. Preciously, what the car industry in the US did. What are the changes the SAME airliner was hit with TWO similar incidents? |
Quoting s5daw (Reply 41): Holy mother of good... do I see correctly it's in the middle console, just waiting for the left pilot to collapse and switch it to lock as his hand falls down? |
Quoting Mastropiero (Reply 39): We haven't heard from military what the interceptive fighter jet saw or witnessed, or did I miss it? |
Quoting TheSonntag (Reply 43): Highly premature. But if you look on how the CVR looked, you can imagine what you would regarding bodies, not even speaking of mobile phones. |
Quoting peterk (Reply 37): Are the mobile phones of the passengers examined? Maybe they took pictures or videos of what happened? |
Quoting flyingturtle (Reply 48): I think they are. It's not a big problem for somebody with a BSc degree in electronic engineering from a University of Applied Sciences to build a device that reads data from bent, mangled but still working SD card. |
Quoting aw70 (Reply 15): All it would have taken for this to happen is for the remaining pilot in the cockpit to suffer a massive stroke or aneurysm while the other one was in the lavatory. |
Quoting pvjin (Reply 27): The problem with fumes sometimes entering cabin exists on all airlines, with possible exception of B787. It has something to do with the way how most modern airliners take their air through engines. Try google for aerotoxic swyndrome for more info. |
Quoting capri (Reply 38): We haven't heard from military what the interceptive fighter jet saw or witnessed, or did I miss it? |
Quoting LTBEWR (Reply 24): That the NY Times, considered to be leading and respected newspaper in the USA, published this allegation also shows a huge flaw in their editorial management, likely done to get more people to buy their paper or their subscription fee website. |
Quoting LXLucien (Reply 51): It would have been an almost improbable coincidence that the arm of the captain (who has to sit very far back with his seat) hit the switch at the exact angle to get it triggered. |
Quoting capri (Reply 37): We haven't heard from military what the interceptive fighter jet saw or witnessed, or did I miss it? |
