Quoting SYDSpotter (Reply 48): Wrong on both counts, they offered QF ticket holders discounted fares and tried to put on additional services to assist stranded passengers: |
Can we not allow a troll to hijack an otherwise interesting thread?
Quoting Sydscott (Reply 50): Can we not allow a troll to hijack an otherwise interesting thread? |
Quoting Enobar (Reply 51): In other news, I was at the Melbourne airport the other day and was surprised to see Jetstar A320s with winglets - I thought they all had wingtip fences - are these a new retro fit or have the come from Airbus? I completely missed that change.. I feel like I should have airplane nerd points deducted from me... |
Quoting SYDSpotter (Reply 48): Wrong on both counts |
Quoting Sydscott (Reply 55): N.B. SYDSpotter I wasn't calling you the troll. Just to clarify in case anyone was in doubt! |
Quoting Sydscott (Reply 55): Also in some other news, and further to the discussion on airlift capability Australia has confirmed its purchase of 2 more C-17's. |
Quoting TN486 (Reply 58): Australian Aviation is reporting QF Link 717 heavy maintenance to be based in Canberra from later this year. They will be using the hanger that was financed by the ACT Government for Impulse. Anyone know why the change - does this signal a possible further relationship change with Cobham? |
Quoting Sydscott (Reply 55): Also in some other news, and further to the discussion on airlift capability Australia has confirmed its purchase of 2 more C-17's. http://www.smh.com.au/federal-politi....html |
Quoting TruemanQLD (Reply 59): Where is it currently done |
Quoting QF29 (Reply 61): I was at MEL the other day and i noticed a QF 747 parked at the domestic gates. I thought all Perth flights were using A330s and they had discontinued 747's on domestic routes. What route did they sub the 747 onto? Cheers |
Quoting zkncj (Reply 53): Quoting Enobar (Reply 51): In other news, I was at the Melbourne airport the other day and was surprised to see Jetstar A320s with winglets - I thought they all had wingtip fences - are these a new retro fit or have the come from Airbus? I completely missed that change.. I feel like I should have airplane nerd points deducted from me... They we're meant for Jetstar HK/JP, but due to them not being needed that disposed some of their older aussie based A320s |
Quoting TruemanQLD (Reply 59): Quoting TN486 (Reply 58): Australian Aviation is reporting QF Link 717 heavy maintenance to be based in Canberra from later this year. They will be using the hanger that was financed by the ACT Government for Impulse. Anyone know why the change - does this signal a possible further relationship change with Cobham? Where is it currently done? Good news for Canberra and probably makes sense given the high concentration of 717 flights there |
Quoting AJ (Reply 65): The Sharklets as fitted to Jetstar A320 deliveries from VH-VFN onwards are not necessarily HK or JP orders, in fact I believe that only VFT and VFY fit in that bracket. Additionally Jetstar has retrofitted VH-VFL and XSJ with Sharklets. |
Quoting 777Jet (Reply 60): IMHO this purchase is a good decision. I wonder if it was a 'Captains Call' ??? |
Quoting Sydscott (Reply 67): but was hurried along by Boeing ceasing production of the C-17 |
Quoting qf789 (Reply 68): QF581 operating SYD-PER returned to SYD today due to an indicator light for rear cargo door. Operates by A332 VH-EBA. media is quoting its being operated by A380. |
Quoting 777ER (Reply 69): What other military transport aircraft does Boeing make? |
Quoting SYDSpotter (Reply 70): Quoting 777ER (Reply 69):What other military transport aircraft does Boeing make? None of comparable lift/range/weight to the C-17. |
Quoting SYDSpotter (Reply 70): They were close, not too much difference between a A330 and A380 PER doesn't have a an A380 capable gate yet. |
Quoting SYDSpotter (Reply 70): None of comparable lift/range/weight to the C-17. |
Quoting Sydscott (Reply 72): As SYDSpotter said, the C-17 was the biggest one in terms of cargo that Boeing had under production. In terms of military transports the only others are variants of the Boeing BBJ / 737 family as the C-40 class of transports and the KC-46 Pegasus, which is based off of the 767 airframe, but that is a tanker. They also have the AEWAC's aircraft which is based off the 737 frame but that isn't a transport. |
Quoting Qf2220 (Reply 71): I think the C17 was a remnant of the MD lineup no? |
Quoting SYDSpotter (Reply 70): PER doesn't have a an A380 capable gate yet. |
Quoting Razza74 (Reply 75): Bay 51 at T1 is A380 capable and hopefully as of the 1st of May will be used daily by an EK A380 |
Quoting FlyboyOz (Reply 73): |
Quoting SYDSpotter (Reply 74): Quoting Qf2220 (Reply 71):I think the C17 was a remnant of the MD lineup no? According to Wikipedia, yes |
Quoting TN486 (Reply 58): Anyone know why the change - does this signal a possible further relationship change with Cobham? |
Quote: Timing: Mid 2015 to mid-2017 Plans are underway to build a new $20 million Regional Satellite Terminal at the northern end of the Domestic Terminal Building (DTB), part of an overall $100m expansion of the precinct. The work is a direct result of the continuing growth in regional Queensland and Australia, as well as the increasing demands of low-cost carrier airline operations. The satellite terminal will be built as a standalone building approximately 300m away from the existing DTB, with passengers initially transferred by bus until a ground level walkway is constructed. The satellite terminal will have 16 new boarding gates, as well as 2,000 square metres of space including passenger lounge areas, food, beverage, retail tenancies, amenities, service areas and offices. |
Quoting QF175 (Reply 82): Yet another expansion project planned for Brisbane Airport: DOMESTIC REGIONAL SATELLITE TERMINAL |
Quoting SYDSpotter (Reply 83): So does this mean both VA and QF will get to use it or just QF (as they take up the Northern end of the domestic terminal)? |
Quoting bunumuring (Reply 85): PS: I caught in passing a report on Channel Seven (Sydney) news last night about Lion Air 'flying to many Australian cities in the near future'... And then that VietJet also wants to fly to Australia. Anyone see the report in full? It seemed to be some kind of review by a male reporter of five LCCs (Scoot, Cebu Pacific, Air Asia, Lion Air, VietJet) who fly into Australia or 'want to fly' into Australia.... I was at a relative's place having dinner and couldn't be rude to run through into the media room when I heard the reporter speak... |
Quoting bunumuring (Reply 85): However, a certain PM apparently 'said' a while ago that two more would be ordered for the RAAF, taking our 'extra' order from two to four, making a final fleet of ten of these extraordinary aircraft. Now apparently, with the above mentioned announcement, it seems the RAAF's fleet will stall at eight aircraft... |
Quoting bunumuring (Reply 85): And what about the sixth A330MRTT for the RAAF: the so-called 'Air Force One' with the VIP suite? |
Quoting qf789 (Reply 86): Australian aviation is reporting that the Department of Infrastructure and Regional development has called on the ACCC to reverse course and give Qantas and China Eastern proposed alliance the green light. |
Quoting Sydscott (Reply 87): The Gillard Govt, stupidly in my opinion, extended the lease on the RAAF Boeing BBJ fleet so the acquisition of aditional A330 / KC-30's will be covered as part of the defence white paper process. Australia had to act on the C-17's lest it missed out however there is no rush on the A330's. |
Quoting bunumuring (Reply 88): That's actually wrong. The extended lease on the BBJs was one of the last acts of Kevin Rudd as PM. |
Quoting bunumuring (Reply 88): As for the 9th and 10th C-17, it was definitely something publicly discussed by Government, and behind closed doors in Defence and the RAAF. It was not definite, unlike the 7th and 8th C-17s, but it is still disappointing that the RAAF fleet will stall at eight and not ten. With the closing of the production line, there goes our chance to relatively easily extend the lives of the fleet by spreading out the 'use' of the planes over a larger fleet. It has been suggested to me that one reason the Government stalled on the 9th and 10th C-17s was that with the limited supply of whitetails, and high interest from the likes of India, the UAE, Canada and possibly even Britain and Qatar, Boeing could hold the price high and let the customers fight over the last few unsold. |
Quoting Sydscott (Reply 67): Quoting 777Jet (Reply 60): IMHO this purchase is a good decision. I wonder if it was a 'Captains Call' ??? LOL No it wasn't. |
Quoting Sydscott (Reply 67): It's been in the pipeline for some time but was hurried along by Boeing ceasing production of the C-17. But what Boeing did do before they ceased production was to build about a dozen extra one's in anticipation that countries like Australia would probably buy more. We needed to get in quick before they were gone and I'm glad we have! |
Quoting Sydscott (Reply 87): Quoting bunumuring (Reply 85): However, a certain PM apparently 'said' a while ago that two more would be ordered for the RAAF, taking our 'extra' order from two to four, making a final fleet of ten of these extraordinary aircraft. Now apparently, with the above mentioned announcement, it seems the RAAF's fleet will stall at eight aircraft... I don't believe it was ever intended for the RAAF to get 10 of them. The initial order was for a batch of 4 with 2 lots of 2 aircraft ordered in addition. It was my understanding that ultimately the RAAF would receive 8 of them and that the were happy with that number. See link below. |
Quoting Sydscott (Reply 89): dud Labour PM's |
Quoting 777Jet (Reply 90): How many does Boeing have left to get rid of? |
Quoting TN486 (Reply 81): The Cobham website outlines the contract and the services provided under that contract. For the life of me I cannot understand why this change of heavy maintenance has occurred. Its ok people, I won't lose any sleep over it, i am just feeling a little perplexed over this, tis all. |
Quoting bunumuring (Reply 88): RAAF pilots will tell you how 'outdated' the comms suite on the BBJs is alone, and that the planes simply do not have the space nor range needed for Australia's PM now that we seem to be more of a global player. |
Quoting Sydscott (Reply 89): If the PM has to travel then he, or she, needs to be connected and able to travel with the journalists etc that cover politics. |
Quoting undertheradar (Reply 92): |
Quoting undertheradar (Reply 92): c'mon guys...this is a CIVIL aviation forum...yes...the original topic involved QF and other civilian airlines....but now all the 'talk' is military a/c centric. I think it's time to 'move on' from this topic....the CIVIL aviation aspect of this topic has disappeared. I expect the CIVIL aviation thread to focus on CIVIL aviation matters. If you wish to continue the discussion on this topic...maybe move it over to the 'Military Aviation Space' forum Just my opinion...from a CIVIL aviation geek |
Quoting qf002 (Reply 93): Only for the big trips. The vast majority of what the BBJs do is very low key shuttling around of senior ministers, where the capability of the MRTT would be a complete and utter waste. What they've started doing in the last couple of years is sending an MRTT as a support aircraft with additional staff and media on board, with the PM and immediate entourage continuing to use the BBJ. That arrangement seems to work quite well, though the BBJs sound like they need a comprehensive upgrade then replacement with a new aircraft (presumably based on the MAX) as soon as that is available. |
Quoting jrfspa320 (Reply 96): |
Quoting DeltaB717 (Reply 97): our 3K would have to be an A320 which admittedly could probably (without knowing what procedures and alternates 3K has in place) divert to KGI or similar if PER and Pearce were both beyond the aircraft's limits. That's a whole extra hour or more of fuel for the diversion on top of 5+ for the trip plus reserves and contingencies for both destination and alternate, which may be pushing it for an A320. |
Quoting DeltaB717 (Reply 97): The QF Club and compensation issues are separate and, unhelpful as it is, that possibly is the downside of choosing a LCC. |
