united319
Why Are There Not More 787's Doing U.L.H.routes?
Mon Apr 06, 2015 7:21 pm
I've noticed many carriers are not using the 787 to one of the key things in it's design...range. Some foreign carriers use them on short hops like ANA. UA is getting better but still the only handful of ULH routes I know of that it does are....
NRT-BOS
IAH-LOS
LAX-MEL
MEX-NRT
I do understand the shorter long haul flights for thin routes like:
NRT-SJC
KIX-SJC
NRT-SAN
LHR-PHL
But then I see carriers flying it on routes that don't make sense to me (Capacity and Range wise) like:
BOG-LIM
LHR-JFK
IAH-LHR
LAX-NRT
MEX-JFK
DEL-DXB
DOH-BLR
SCL-EZE
LHR-EWR
I can understand "breaking in" the planes like UA did when they flew them on routes like IAH-LAX IAH-SFO (still in service for repo's) , IAH-DEN (still in service). Maybe some airlines are also flying them on these odd routes to show off the plane. I know that VS had a big deal at JFK.
This is all just my humle opinion/observation.
It's Time To Fly
Sooner787
RE: Why Are There Not More 787's Doing U.L.H.routes?
Mon Apr 06, 2015 7:31 pm
EY needs something to jump start their DFW service.
Can a 789 make it from AUH - DFW with a decent payload?
tortugamon
Mon Apr 06, 2015 7:37 pm
Quoting united319 (Thread starter):
NRT-BOS
IAH-LOS
LAX-MEL
MEX-NRT
IAD-ADD
YYZ-ADD
AUH-IAD
SFO-CTU
NRT-JFK
PEK-BOS
MTY-NRT
787 Routes #9 (Revamped!) (by hkcanadaexpat Sep 26 2014 in Civil Aviation)
I personally do not understand this feeling that the 787 is not being used on long routes.
tortugamon
flyiguy
Mon Apr 06, 2015 7:38 pm
EY serves AUH - IAD with 787-9
ET serves ADD -IAD with 787-8
FLY
The opinions I post are of mine and mine alone, not of the airline I work for.
chrisnh
Mon Apr 06, 2015 7:40 pm
I think one of the more curious 'short' routes is BOS-LHR with the 787-9. We like seeing it at Logan and a favorite for spotters, but goes against the grain you speak of.
jetblue1965
BOG-LIM
LHR-JFK
IAH-LHR
LAX-NRT
MEX-JFK
DEL-DXB
DOH-BLR
SCL-EZE
LHR-EWR
Not every long and ultra-long haul flight fit perfectly time wise (esp when accounting for connections), so cycling the plane through another hub or a regional trunk route can provide excellent downtime utilization. And if you listen to Boeing's pitch that 787 is a 767 replacement, and then look at existing 767 services globally, you'll find tons of examples of short-to-mid haul flights.
UA is using the 787 on LAX-NRT for yield-improvement purposes (sure a 763 can do it but a 788/789 can do it with much much lower CASM).
I wonder if the 788s that ANA are using domestically are paper-derated just to lower the landing fees ...
seabosdca
Mon Apr 06, 2015 7:42 pm
The 787 is not really a ULH aircraft. It's a normal long-haul aircraft that can be expected to fly the same mix of routes as any other long-haul aircraft. Yes, the -9 has 8300 nm nominal range, but the MZFW range is closer to 5500 nm. That's roughly the same as the 777-200ER, 777-300ER, and A340-300.
One consequence of better fuel efficiency is that payload-range curves get shallower.
Polot
Mon Apr 06, 2015 7:43 pm
The key thing of the 787 design is efficiency. Boeing gave it the range to operate basically wherever a 777ER can so it can supplement the 777 in airline's fleets, but that doesn't mean that every airline needs the 787 for its range. QR, for example, doesn't have crew rests on them so they can't fly them longer than 10 hours or something like that- the 787s were ordered for a regional role.
Quoting tortugamon (Reply 2):
Especially since there are only ~250 in service. Its not like every 787 is going to be a very long haul route.
747megatop
Mon Apr 06, 2015 7:45 pm
NRT-BOS
IAH-LOS
LAX-MEL
MEX-NRT
Add DEL - SYD/MEL by AI to the list.
747megatop
Mon Apr 06, 2015 7:58 pm
Interesting flightglobal analysis on Boeing 787 route network
http://www.flightglobal.com/news/art...787-been-a-network-changer-406458/
I think it will give a different perspective in the context of this thread's topic.
glbltrvlr
Mon Apr 06, 2015 8:03 pm
Quoting 747megatop (Reply 9):
Article is behind a paywall - can you summarize?
B777LRF
Mon Apr 06, 2015 8:04 pm
The 787 is a modern and efficient 767, with a bit more space and range added, or it's a more modern and efficient 777 with a bit less space. It is therefore little wonder, that the type is seen on services previously and presently operated by the 767 and 777. This is the bread and butter of long-haul, and where the bucks are most easily made. ULHs are notoriously difficult to make financially viable, and whilst the 787 makes that job a bit easier, it's still a tough nut to crack.
Signature. You just read one.
Mortyman
Mon Apr 06, 2015 8:11 pm
Norwegian is using their B787-8's on routes from Scandinavia / Europe to
* Bangkok,
* Los Angeles,
* Oakland,
* Orlando,
* New York
* Fort Lauderdale.
New long haul routes will proabaly be announced shortly.
[Edited 2015-04-06 13:24:09]
adamh8297
Mon Apr 06, 2015 8:14 pm
NRT-SJC
KIX-SJC
NRT-SAN
LHR-PHL
Add LHR-AUS to that list.
Airlines flown: A3, AA, AC, AF, AM, BA, B6, CA, CO, CX, DL, EA, EL, IB, LH, MI, MQ, NH, NW, NZ, OU, PE, QF, S4, SQ, TP, UA, US, VS, WE, WN
avek00
Mon Apr 06, 2015 8:18 pm
The 787 is too small to make most ULH options economically viable -- those will continue to be the near-exclusive province of larger 77L, 77W, 388, and eventually 777X/350 aircraft.
Live life to the fullest.
tortugamon
Mon Apr 06, 2015 8:19 pm
Quoting seabosdca (Reply 6):
I personally think ULH means 12+ hours of flying and there are more than a handful of those flights being operated by the 787. But I agree that it is not the in the same category as the 77L/A345.
Quoting Polot (Reply 7):
Not the only one: Scoot, Jetstar, most of ANA's, Virgin right now....lots of operators are using them regionally.
Good point. Still 25% of new routes opened since the 787 entered service were operated by the 787. Its pretty substantial.
Quoting glbltrvlr (Reply 10):
Its not behind a paywall. You just have to register. Its worth it, good article.
We don't know what they are carrying in their bellies: there are dozens of flights that are longer than the range at MZFW where these could be pushing the limits of 787 capability. There are more LD3 spaces on these aircraft than similarly sized aircraft.
tortugamon
seabosdca
Mon Apr 06, 2015 8:21 pm
Quoting tortugamon (Reply 15):
Fair enough, although I would define it as 14+ hours. That is the mission profile where the 77L and 345, the two original ULH aircraft, start to make economic sense compared with their larger siblings.
BoeingGuy
Mon Apr 06, 2015 8:27 pm
KIX-SJC
There's no KIX-SJC. Did you mean SJC-PEK?
LAX772LR
Mon Apr 06, 2015 8:33 pm
Easy get-around: just Google the article's title, then access it via Google's link.
Will get you past a paywall 99% of the time.
That's a rather loose definition, seeing as it only amounts to about 5000-5500nm worth of flying, westbound.
We've seen 767s scheduled on flights like that (e.g. VKO-LAX, TLV-MIA, etc) and they're hardly ULH aircraft.
cha747
Mon Apr 06, 2015 8:43 pm
NRT-SJC
KIX-SJC
NRT-SAN
LHR-PHL
Is LHR-PHL considered a thin route? With now 5 flights a day between the two cities, I'd think that it is more of a "thick" route.
Piedmontgirl was always right
par13del
Mon Apr 06, 2015 8:50 pm
Copy the article header into google search and away you go.
The link below is one of a few that comes up
http://www.flightglobal.com/news/art...vice-how-is-787-performing-405814/
Cipango
Mon Apr 06, 2015 8:51 pm
Quoting BoeingGuy (Reply 17):
More than likely NRT-SJC.
This is still operated by a 787, right?
Let's fly! Unless it's on a CRJ 200, then I'll stay down here.
747megatop
Mon Apr 06, 2015 8:58 pm
Not sure how to summarize this interesting article. Let me make an attempt by pasting a key paragraph from it -
"The 24 airlines operating the 787 operate a total of 585 long-haul routes (>5,000km). They have started a total of 55 new 787 routes over the last three years. All new routes are of course long-haul, and it means a 10% increase over the last three years due to the 787."
You will have to read the article yourself because it has some interesting route maps and graphs as well. The link works for me. If it still doesn't come up for you then please try registering first in flightglobal.com
jetblue1965
Mon Apr 06, 2015 9:04 pm
Quoting Cipango (Reply 21):
Still is. Actually NRT-SJC (NH), KIX-SFO (UA), and future PEK-SJC (HU) will all be 787.
Flighty
Mon Apr 06, 2015 9:13 pm
About JFK-LHR and LAX-NRT, the 787 can fight off stiff competition by using its incredible fuel efficiency. This is good for smaller players.
anstar
Mon Apr 06, 2015 9:16 pm
Quoting adamh8297 (Reply 13):
Who flies the 787 on this route? BA were thinking about it , but as far as I know its still a 772ER route
PM
Mon Apr 06, 2015 9:18 pm
There just aren't that many ULH routes. At least not many that are profitable. I suspect the demand simply isn't there. I've flown Europe to Australia. I've flown East Africa to Mexico. I'd rather fly for 10/12 hours and go to a hotel before continuing than fly for ~16 hours nonstop. Don't blame the airframe. People simply don't want to be canned for that long. I don't.
Mortyman
Mon Apr 06, 2015 9:26 pm
Norwegian has said they are considering to fly to Hawaii. If that is Scandinavia - Hawaii we are looking at I guess around 16-17 hours ?
Cipango
Mon Apr 06, 2015 9:36 pm
Quoting anstar (Reply 25):
BA have operated it for a year or two now. It wasn't ever operated by a 772 but they announced an up gauge recently to a 772 from 787. That was quietly reverted it now remains a 787 route.
It has been very successful for BA according to many on A.net.
It has been a prime example of an airline using a 787 to test a new route.
Cipango
Mon Apr 06, 2015 9:41 pm
Quoting Mortyman (Reply 27):
More 13-14 hours. A long route for low yielding traffic.
Its comparable to London-Singapore, Tokyo-Atlanta and Istanbul-Los Angeles distance wise.
Mortyman
Mon Apr 06, 2015 9:49 pm
Quoting Cipango (Reply 29):
More 13-14 hours.
You're sure ? I was pritty sure it was a longer time than that from Scandinavia ...
jetblue1965
Mon Apr 06, 2015 9:50 pm
Which is completely fine for Norwegian's business model. Afterall, they excel at Scandinavia to BKK.
seabosdca
Mon Apr 06, 2015 9:59 pm
Quoting Mortyman (Reply 30):
You're sure ?
Yep. It's almost exactly the same distance as JFK-NRT.
tortugamon
Mon Apr 06, 2015 10:04 pm
I actually think the merits of the 787 are evident by the fact that its operating the 19th longest route in operation (MEL-LAX) but still efficient enough to be a short haul Japanese domestic flier. It certainly is not a 77L but it isn't that same liability on short haul either.
Quoting avek00 (Reply 14):
The 789 is roughly the same cabin length at the 77L that you mention.
Quoting seabosdca (Reply 16):
You could be more popular there. I just choose long haul to already be a big bucket of 6.5-12 hours so I try to get a more normal distribution. I see your point.
Quoting LAX772LR (Reply 18):
I know its not the common definition on here and I do have wiki on my side but it isn't much of a consolation.
More 13-14 hours.
You're sure ?
I am! http://www.gcmap.com/mapui?P=osl-hnl...in%0D%0Anrt-atl%0D%0A&MS=wls&DU=nm
LAX-IST has been coming in at less than 13 hours and occassionally under 12 hours
http://flightaware.com/live/flight/THY10
tortugamon
SANFan
Mon Apr 06, 2015 10:13 pm
Quoting Cipango (Reply 28):
   The route has op'd for just a touch over 1 year now (started 3/31/14 at 5x/wk, then daily beginning May 5.)
Was the u/g to a 772 actually (officially) announced, or just rumored? If the route continues to do well, it would seem a good candidate for at least a 787-9 when they join BA's fleet.
bb
jfk777
BOG-LIM
LHR-JFK
IAH-LHR
LAX-NRT
MEX-JFK
DEL-DXB
DOH-BLR
SCL-EZE
LHR-EWR
BOG to LIma, MEX to JFK, are using the plane when it would sit on the ground between long flights. MEX to JFK also provides a very high level of service for AeroMexico on a four hour flight, lots of premium passengers fly to JFK and may be they sell the large J class cabin on the 787.
BiggerJetsPlz
Mon Apr 06, 2015 10:18 pm
Another ULH flown by China Southern 787s, http://flightaware.com/live/flight/CSN660, almost 14 hours. And line 34 flies this one occasionally (same from the line 20-35 block, early frames known to have some extra weight)
Cipango
Mon Apr 06, 2015 10:57 pm
Quoting SANFan (Reply 34):
AFAIK it was confirmed and loaded into the reservation system.
sunrisevalley
Mon Apr 06, 2015 11:42 pm
Quoting Sooner787 (Reply 1):
About the same flight time as LAX-MEL so the answer has to be yes.
[Edited 2015-04-06 16:45:43]
dcaviation
Mon Apr 06, 2015 11:49 pm
Quoting flyiguy (Reply 3):
There is no ADD - IAD, its FCO - IAD
ET flies IAD - ADD
sunrisevalley
Mon Apr 06, 2015 11:51 pm
A 789 with the same payload and flight time as a 77E burns >21% less fuel.
astuteman
Tue Apr 07, 2015 1:20 am
Perhaps worthy of note that all of the top 10 longest sectors being flown belong to the 77W and A380 ......
BiggerJetsPlz
Tue Apr 07, 2015 1:36 am
I see three of the top ten longest routes being on the 772LR (atlanta-johanesburg, and abu dhabi to LA and Dallas)
astuteman
Tue Apr 07, 2015 7:42 am
Quoting BiggerJetsPlz (Reply 42):
Yep. My bad - posted in haste, as I realised afterwards.
Either way an interesting commentary on how the "ULH" market actually pans out in practice..
GCT64
Tue Apr 07, 2015 8:15 am
Quoting B777LRF (Reply 11):
That's pretty much it and as we see them become more and more common around the world, inevitably only a relatively small proportion will do ULH flights for the simple reason that very few ULH flights make commercial sense.
BTW - on the "becoming more and more common" theme, as my flight at LHR taxied out yesterday there were three 787s in a line on the taxiway behind us (BA to CTU, VS to EWR and RJ to AMM) so they are already becoming pretty commonplace.
Flown in: A20N,A21N,A30B,A306,A310,A319,A320,A321,A332,A333,A343,A346,A359,A388,BA11,BU31,(..56 more types..),VC10,WESX
jfk777
Tue Apr 07, 2015 1:52 pm
While many airlines are using 787-8 to replace A340 and 767 with some new flights like JAL to Boston. More ULH will happen when the 787-9 becomes more common, United's flight from LAX to MEL. Air Canada is the first airline showing us how they plan to us the 787-9 to Dubai and India nonstop from Toronto. AC is also replacing 777 on their YYZ to Haneda route but who knows AC could continue to surprise us with a route to say Johannesburg.
frmrCapCadet
Tue Apr 07, 2015 2:00 pm
Until 400+ 787/350s are in the air I don't think we will begin to see the real impact of this class of planes.
scbriml
Tue Apr 07, 2015 2:25 pm
In order to analyse the use of the 787 on 'ULH routes' you first need to define what constitutes ULH. In reality, very few of the World's routes are true ULH - just look at the total sales figures for the two specialist ULH planes (A345 & 77L). ULH is a niche market at best.
The 787 is not a ULH plane. Most widebody flights are less than 4,000nm.
It's not a paywall, it's just free registration. However, use the old Internet standard - simply Google the articles headline...
anstar
Tue Apr 07, 2015 4:29 pm
Oops... I got it the wrong way round! Thanks for clarifying for me.
seabosdca
Tue Apr 07, 2015 4:41 pm
Quoting astuteman (Reply 41):
I should have used the past tense.
I think when the 777-8X shows up we will see ULH sectors being flown by ULH aircraft again. Until then... the 77W and A380 have become just capable enough to warrant "abuse" on ULH.
[Edited 2015-04-07 09:41:57]
