jfk777
GOL Flights To MIA On 737.
Wed Apr 08, 2015 11:48 am
What is the point of GOL flying to Miami with 737-800 when the market from Brazil is well flown by AA, TAM and Azul to Florida ? If GOL wants to be truly competitive then they should fly nonstop, if that means they need 757 then so be it. 757 should be able to handle Rio and Sao Paulo to MIA.
luv2fly
RE: GOL Flights To MIA On 737.
Wed Apr 08, 2015 11:55 am
I don't understand why it has to be a 757 or a wide body? I mean Copa makes the trek from Panama down to EZE on a 737! Just cause other airlines fly widebodies on routes that means every airline should?
C010T3
Wed Apr 08, 2015 12:12 pm
Well, 757 do not have the range to fly to the Southern Cone nonstop from MIA.
If AA, Azul and TAM were truly covering the market, Copa would have no chance. Gol is only mimicking Copa, but their struggle in the market is an issue whose roots can be traced back to their culture, brand and market positioning.
SCL767
Wed Apr 08, 2015 12:23 pm
Quoting jfk777 (Thread starter):
After GOL acquired Varig in 2007 GOL did operate scheduled 767 flights to MIA. However it was a complete disaster for the airline and within a year it grounded its entire fleet of 767s and only used them for certain charter operations. GOL resumed operations to MIA and MCO in order to diversify its network and its offering for its customers. GOL's strategy of using the D.R. as an intermediate stop does not seem to be working well for the carrier. GOL recently ditched its scissor hub at SDQ and transferred over to PUJ. G3 currently offers only six weekly flights to MIA via PUJ: VCP-PUJ-MIA 3x weekly and GIG-PUJ-MIA 3x weekly.
frostyj
Wed Apr 08, 2015 12:24 pm
I don't understand how a 737 could be flown from Miami to Rio??
[url=http://m.maploco.com/details/5f34zxvq][img]http://www.maploco.com/vmap/s/8395334.png[/img][/url]
LimaFoxTango
Wed Apr 08, 2015 12:51 pm
Quoting frostyj (Reply 4):
Easy, they stop in SDQ and PUJ.
You are said to be a good pilot when your take-off's equal your landings.
airbazar
Wed Apr 08, 2015 1:01 pm
TAM didn't seem to have a problem operating the A320 to MIA for many years.
SCL767
Wed Apr 08, 2015 1:20 pm
Quoting airbazar (Reply 6):
AA doesn't seem to have a problem operating the A319 to Brazil from MIA.
Rafabozzolla
Wed Apr 08, 2015 2:00 pm
Quoting SCL767 (Reply 7):
Those flights were/are from MAO, MAO-MIA is 2402mi, well within the reach. GRU-MIA, on the other hand is 4072mi.
jfk777
Wed Apr 08, 2015 2:04 pm
Quoting luv2fly (Reply 1):
Panama is within range of GRU with a 737, a 737 from Miami is not possible unless is an all J class trip with only 40 passengers.like the SAS from IAH to Norway.
Manaaus to MIA is 5 hours different then GRU to MIA.
Reply 6):TAM didn't seem to have a problem operating the A320 to MIA for many years.
where does AA fl a A319 ? Manaus ?
The TAM A320 was from Manaus, it a 5 hour flightf rom Northwest Brazil very different then the GRU to Miami trip.
SCL767
Wed Apr 08, 2015 2:21 pm
Quoting Rafabozzolla (Reply 8):
The TAM A320 flight used to continue onwards to other cities in Brazil via MAO. GOL could use MAO or even BEL as a scissor hub for its flights to MIA/MCO if they wanted too. Do you think that GOL is in the position to acquire wide-body a/c at this time to operate non-stop flights from GRU to MIA and MCO?
jetblue1965
Wed Apr 08, 2015 2:28 pm
The GOL flights are thoroughly uncompetitive except for the most price sensitive folks. GRU+VCP to MIA+FLL is very well served on nonstop services, many of which have flat bed in J.
Copa is a different story because they're focused on using PTY as a low cost scissor hub between the Americas, serving city pairs that lack nonstop service to begin with. Any GRU-PTY-MIA traffic they capture is just icing on the cake.
jr1914
Wed Apr 08, 2015 6:54 pm
SCL767, Gol have identities crisis but they clearly have in mind to keep operating 737's
roseflyer
Wed Apr 08, 2015 7:20 pm
No one really thought the GOL service to Florida would work, but it has lasted a few years now.
http://centreforaviation.com/analysi...l-us-market-faces-challenges-92302
rg787
Wed Apr 08, 2015 8:04 pm
One should note that COPA has a real shopping mall in PTY, while Gol doesn't on either PUJ or SDQ. If they could do a hub like PTY in Belem or something then probably it would work better. I don't even know if passengers are able to leave the aircraft on G3 flights to the US, but they sure don't have many options at the airport.
wedgetail737
Thu Apr 09, 2015 3:15 am
Doesn't GOL fly 737-800's to MCO as well?
SJOtoLIR
Thu Apr 09, 2015 3:27 am
Quoting SCL767 (Reply 10):
G3 used to fly MIA-MAO-BEL-FOR on a daily basis with 320 around 2007.
"Goin' up to the spirit in the sky"
LipeGIG
Thu Apr 09, 2015 3:35 am
The idea was to cover the growing traffic generated by the stronger BRL in 2009-2010 when thousands decided to visit Florida and buy every piece of stuff they could.
Now with a stronger USD, that's a different story.
Quoting C010T3 (Reply 2):
I believe the main issue is that CM runs a hub in a growing market (Panama) where they are the dominant player while Gol just run 4 flights (considering the 2 legs) from a place where they are just a minor player.
New York + Rio de Janeiro = One of the best combinations !
richierich
Thu Apr 09, 2015 2:29 pm
Quoting LimaFoxTango (Reply 5):
You do mean OR right? Please tell me Gol does not fly MIA-SDQ-PUJ-GRU.
Gol needs bigger planes, or at least ones with a longer range, if they want to make this kind of route work. They have fallen behind their competitors.
None shall pass!!!!
jr1914
Thu Apr 09, 2015 3:06 pm
By 2018 they will recieve MAX8 with enough range for a non stop GRUMIA not sure on the way back with N extra bags of each passenger
Rafabozzolla
Thu Apr 09, 2015 5:08 pm
Quoting SJOtoLIR (Reply 16):
G3 has never operated Airbus planes.
dfwjim1
Thu Apr 09, 2015 6:44 pm
I live in the South Florida and I have never seen GOL do any advertising around here.
jfk777
Thu Apr 09, 2015 7:36 pm
Quoting SCL767 (Reply 3):
Why was GOL's Varig experience so bad ? was the plane a 767 ? Varig people telling GOL " they know" how to operate an international airline or the reverse "GOL telling RG people we know how to do it " ? TAM filling the role of Brazil's Flag airline ? While the 767 may not have been the perfect plane for RG to revive itself it should have been good enough for GRI to MIA, JFK and Europe.
roseflyer
Thu Apr 09, 2015 9:25 pm
Quoting dfwjim1 (Reply 21):
I assume that is because they cater to brazilians going on Miami shopping trips. With how outrageous prices are in brazil, there are tour companies that actually arrange shopping trips to Miami outlet malls.
incitatus
Fri Apr 10, 2015 2:07 pm
Like it was said earlier, not clear why a 737 is worse than a 757 from a passenger perspective. DL had 757s from ATL to BSB until recently.
That said, with Brazilians buying anything from Grandma's underwear to the kitchen sink in Florida, I wonder if space for bags is an issue for GOL's 737s. That might be the real catch.
I do not consume Murdoch products including the Wall Street Journal
SJOtoLIR
Sat Apr 11, 2015 2:14 pm
Quoting Rafabozzolla (Reply 20):
My mistake.
The FOR-BEL-MAO-MIA sector was indeed operated by TAM with 320 aircraft.
Once Copa Airlines began PTY-MAO in 2006, TAM as a response launched that route, in order to catch traffic to Miami.
JJ launched later the dedicated MIA-MAO service with 767.
Regards.
SJOtoLIR
Sat Apr 11, 2015 8:37 pm
Quoting richierich (Reply 18):
G3 GIG-PUJ-MIA, 738
G3 VCP-PUJ-MIA, 738
SDQ was substituted by PUJ since March 2015.
They also operate G3 GRU-PUJ-MCO.
Quoting jetblue1965 (Reply 11):
It's unfair the comparison between G3 [Brazil-PUJ-USA] and CM [Brazil-PTY-USA].
G3 is basically a 737 airline operating under the low cost model.
The long-haul equipment doesn't fit into their business model.
The intermediate stop in Punta Cana indicate us that they're not competing with JJ GRU-MCO, AA GRU-MIA, JJ GRU-MIA, AA MIA-GIG or JJ GIG-MIA.
Regards.
C010T3
Sat Apr 11, 2015 10:16 pm
Quoting SJOtoLIR (Reply 26):
Actually, their brand makes makes it impossible to have the business model expanded. They are currently having financial performance problems because they drifted from they low-cost model and became a network carrier, but being unable to charge a premium for that, since the flying public doesn't see them as such.
Gol would only be successful if they created a hub at MAO from which they could serve several destinations in the Eastern United States, Caribbean and Central America. They would be able to stay true to their model that way, since their brand is not flexible like Azul, which can market itself as a hybrid carrier.
The whole issue is MAO as an airport. It's incapable of handling such an endeavour. One most immediate problems is the duty free shop on arrival. It's incredible, but it is part of Brazilian itinerary decision making. Not too long ago, TAP almost axed VCP, because the competitive disadvantage was the lack of a duty free shop, not the airline, not its service, not its network.
LipeGIG
Mon Apr 13, 2015 2:27 am
Quoting jfk777 (Reply 22):
THe list is not long but it is impressive:
* Decision to use older and cheaper 763 instead of something better and comfortable for their customers
* Decision to fight for the Sao Paulo market with a bad product
* Wrong decision as for the network (focused entirely on Europe in a moment that Brazilians begin to look to the United States)
* Lack of Code-share agreements. Took too long to fight to stay on *A
In the end they burn cash during more than a year in such venture
As for JJ filling the gap ? In Sao Paulo, yes. But still is an airline with very slow decisions as for new long haul destinations. Brazil needs more, and we need airlines focusing not only where Brazilians go, but who wants to visit Brazil.
Don't get me wrong but in general, Brazilian airlines will be limited by something very hard.... Brazilian as individuals and as for Investments, are too much domestic oriented. We need that to change to have bigger and stronger airlines !
2travel2know2
Mon Apr 13, 2015 5:04 pm
Seems that G3 will go into the CCS-MIA market, its CCS-PUJ will connect with PUJ-MIA/MCO flights.
I'm not on CM's payroll.
LipeGIG
Mon Apr 13, 2015 11:00 pm
Quoting 2travel2know2 (Reply 29):
They already have millions blocked. I can't see the point to focus more on CCS.
2travel2know2
Tue Apr 14, 2015 1:26 am
Quoting LipeGIG (Reply 30):
MCO/MIA to CCS traffic, fares sold outside Venezuela.
Doubt G3 will look for CCS-Florida traffic in Venezuela.
