byronicle6
NZ announce AKL-IAH from December
Wed Apr 15, 2015 4:29 pm
"Mayor Parker and Aviation director to make major announcement concerning new air service at George Bush Intercontinental Airport"
http://www.houstongovnewsroom.org/go/doc/2155/2491438/
This ties in perfectly with NZ making their announcement of a new mainland USA destination on Thursday morning (NZ time) 16/04 with the potential destinations being IAH, ORD or LAS.
"Air New Zealand is to announce a new mainland United States destination tomorrow morning"
http://www.nzherald.co.nz/business/n...ticle.cfm?c_id=3&objectid=11432607
If it is, i'm glad to see this one finally come to fruition after countless years of speculation. First the route was proposed by CO, then dropped. Then more recently rumoured for NZ to fly it.
[Edited 2015-04-15 09:37:35]
Travel is my thing
IAHflyer97
Wed Apr 15, 2015 4:57 pm
While I wanna say it's 100% going to be NZ, there's always that slight chance that IAH and NZ just so happen to have similar announcement times and neither one have to do with the other. But expect NZ at about 2:30 today
A man is only as big as the amount of strings on his guitar.
Miami
It's obviously going to be Air New Zealand.
Both article point the obvious. One is saying Houston is getting new air service while the other says Air New Zealand is going to announce a new US city. Which NZ had 3 in mind. IAH, ORD, LAS.
Congrats to IAH and NZ! Makes sense since IAH is a Star Alliance hub.
Aviation is proof that given, the will, we have the capacity to achieve the impossible. - Eddie Rickenbacker
miaintl
Wed Apr 15, 2015 4:58 pm
IAH does not have the infrastructure to accommodate new intl service. Terminal D is packed at all times, most of the long-hauls go on hard stands departing from that terminal.
Miami
Wed Apr 15, 2015 5:02 pm
Quoting miaintl (Reply 3):
I'm sure IAH knows what to do.
OA412
Wed Apr 15, 2015 5:03 pm
UA didn't think it was worth going through with this route. It'll be interesting to see, if this is indeed the announcement that will be made, how this route pans out.
Quoting byronicle6 (Thread starter):
I still don't understand LAS, since they fly to LAX, which is so close. Service to DEN to tie in with the UA hub would make infinitely more sense.
Hughes Airwest - Top Banana In The West
IAHflyer97
Wed Apr 15, 2015 5:05 pm
So assuming it is NZ (which I believe all of us are fairly sure that it is), that'll make IAH one of only 5 airports on the planet to serve all 6 continents nonstop correct? IIRC, it's DXB, DOH, AUH, and JNB correct?
jetblue1965
Wed Apr 15, 2015 5:16 pm
This route just makes total sense. And at only 7400mi, the payload penalty is much lower on the westbound leg compared to QF's similar service.
jetblastdubai
Wed Apr 15, 2015 5:19 pm
If it is actually new NZ service, the terminal space might not be an issue since most South Pacific flights operate at traditionally non-peak hours. With a late evening departure, they might even use a UA gate in E to make connections a bit easier and have access to a *A lounge/Club close by.
76794p
Wed Apr 15, 2015 5:23 pm
Quoting jetblastdubai (Reply 8):
The terminal E United Club is a 5 to 10 minute walk from D. I always head to C or E to get a bite when flying out of D, as the food options are non-existent in D.
There's always money IN the banana stand.
byronicle6
Will most likely be a mid-afternoon IAH arrival, and a late evening IAH departure (in order to connect with NZ's main bank of Australia flights) whilst also connecting to UA flights in/out of IAH
Travel is my thing
yellowtail
Wed Apr 15, 2015 5:24 pm
This would be interesting route wise......down over Mexico I assume
When in doubt, hold on to your altitude. No-one has ever collided with the sky.
Sooner787
Quoting jetblue1965 (Reply 7):
Does the 789 have the legs for this route?
Or will this be a 77W ?
Pbb152
Wed Apr 15, 2015 5:26 pm
Once again, you are completely wrong. International departures never take place on a handstand. Ever. While it is true that Terminal D is pretty maxed out between about 1pm and 6pm, there is plenty of room throughout the rest of the day. But don't let the facts get in the way. You never do miaintl.
jetblue1965
Quoting IAHflyer97 (Reply 6):
Some "claim" YYZ to be part of that club because they count the "direct" YYZ-YVR-SYD service, which in my opinion is really stretching the truth
Now someone will come and lecture us how the continent is "Australia", so therefore AKL doesn't count.
byronicle6
Wed Apr 15, 2015 5:27 pm
Quoting Sooner787 (Reply 12):
Probably a 77E. Wont be 789 (as NZ has stated the new route would be on a '777') and will only be 77W if they take it off LAX or SFO (unlikely)
Edited to add: The current NZ 789 is in a very high density layout which isn't very suitable for the North America market. Plus, all NZ 789 for the rest of the year are accounted for, and since NZ is switching SIN from 77E to 789, there is some slack in the 77E fleet.
[Edited 2015-04-15 10:33:17]
Travel is my thing
76794p
Wed Apr 15, 2015 5:28 pm
The published max range for a 789 is 8300 nm and the GC distance for IAH-AKL is 7415 nm. Thus it is easily within the reach.
jetblue1965
Wed Apr 15, 2015 5:40 pm
789? Easily. UA's 789 plows LAX-MEL everyday (which I believe is longer)
In terms of testing new routes, NZ 789 may be better, but maybe ETOPS maturity is what's driving NZ to use 77E instead (my guess here)
yellowtail
Wed Apr 15, 2015 5:43 pm
So if true IAH will have (international carriers)
NZ
SQ
KE
CA
BR
NH
BA
EK
QR
TK
AF
KL
SK
AV
AM
LH
4O
Y4
VB
AC
WS
That a pretty nice lineup for spotters if you throw SA)">UA, SA)">FX, SA)">NK, SA)">AA, SA)">DL into the mix.
Pretty much only thing missing to make it a spotters dream would be CM (not going to happen at IAH), BW, LATAM and maybe AI or SA (not going to happen either)
A388
Wed Apr 15, 2015 5:46 pm
Quoting Miami (Reply 2):
So is ORD but based on this thread it does seem IAH will be getting NZ flights soon. I just want the big ME3 carriers and Asian carriers to start passenger flights to MIA. That would make my day any time
A388
SonomaFlyer
Wed Apr 15, 2015 5:48 pm
UA is already flying SFO to SYD on a 77E (7,417 mi via GCMAP). Ditto for LAX which is a bit shorter. Given the current a/c allocation for NZ on the 77W, looks like a 77E route.
Was there talk about NZ outfitting some of their 789s to a less dense long haul configuration in the future?
Motorhussy
Wed Apr 15, 2015 5:53 pm
Quoting byronicle6 (Reply 15):
Probably a 77E. Wont be 789 and will only be 77W if they take it off LAX or SFO (unlikely)
Agreed, most likely scenario though the airline is touted to have 2 new 77W's in the frame. Their 77E's have recently been re-equipped to ETOPS-330 standard which safely clears them over the black hole in the eastern parts of the tropical Pacific. Also, the 77E is configured with a higher ratio of premium classes (J and Y+) than the 789 and is less of a risk for a new route than the similarly configured but larger 77W... this configuration is what NZ has figured is right for North American routes.
Congratulations to NZ and IAH, and to partner UA.
Edit: announcement to be made this morning 0730 NZST.
[Edited 2015-04-15 10:55:38]
come visit the south pacific
miaintl
Wed Apr 15, 2015 5:57 pm
Quoting A388 (Reply 19):
QR flies daily to MIA with a 77W. That is all the market can handle at the moment. Maybe a JL flight to NRT can be feasible.
[Edited 2015-04-15 10:58:47]
A388
Wed Apr 15, 2015 6:00 pm
Quoting miaintl (Reply 22):
I know but that's just one airline. Don't get me wrong, it's good but wouldn't it be nicer to see more of those airlines?
A388
jetblue1965
Quoting yellowtail (Reply 18):
Let me decipher your list
Star : NZ SQ CA BR NH TK SK AV LH AC
Skyteam : KE AF KL AM
oneworld : BA QR
Unaligned : EK WS 4O Y4 VB (last 3 all Mexico LCC)
Within Star, nearly no glaring gaps. For a stretch goal, we can hope for LX and ET (they can pull one of those ADD-DUB-IAH)
I don't agree that CM is completely out of the question, just because UA flies IAH-PTY.
thekorean
Wed Apr 15, 2015 6:04 pm
Makes more sense considering the distance as ORD is a lot further.
Connection at IAH to US and Canada will make this a siccessful route.
Has UA considered flying to OZ from IAH? Or is that too far from SYD and MEL?
jetblastdubai
Wed Apr 15, 2015 6:10 pm
Quoting jetblue1965 (Reply 24):
Maybe CM could run HOU-PTY and go head-to-head with WN.
jetblue1965
Wed Apr 15, 2015 6:12 pm
Quoting thekorean (Reply 25):
Previously there were online whispers about IAH-SYD. Who knows if those were wild rumors, or grounded in some reality ....
76794p
Wed Apr 15, 2015 6:13 pm
Quoting jetblastdubai (Reply 26):
It would be interesting. WN will run a 737 or 738 from HOU and United runs 753s and 739s on that route.
IAHflyer97
Wed Apr 15, 2015 6:14 pm
Quoting jetblue1965 (Reply 27):
Back in the days of CO, they were looking at an IAH-SYD. But now that the merged airline has SFO and LAX, and QF is up in Dallas, it's not needed from IAH. AKL is the only one that makes sense.
MaverickM11
Wed Apr 15, 2015 6:15 pm
Quoting motorhussy (Reply 21):
Yes. Congrats to UA
E pur si muove -Galileo
jetblue1965
Wed Apr 15, 2015 6:20 pm
I'd say co-locate at IAH and code-share with each other .... hub-to-hub feed is a lot stronger than trying to spite WN
thomasphoto60
Wed Apr 15, 2015 6:25 pm
Seriously, another prestigious long haul route connecting Houston to the world from a world class carrier, taking up more space at IAH, when will it stop?
Frankly I was hoping for N/S to Branson.
"Show me the Braniffs"
slcdeltarumd11
Wed Apr 15, 2015 6:26 pm
No way is that gonna let them stop service to New Zealand from happening. United can simply reschedule a few of their million flights to mexico etc
MaverickM11
Wed Apr 15, 2015 6:36 pm
Quoting slcdeltarumd11 (Reply 33):
   Airports *always* find a way for new, sexy service. Customs on the other hand...
Miami
Wed Apr 15, 2015 6:49 pm
Wrong and wrong. QR does NOT fly daily to MIA. They will in November. And they don't fly the 77W 5x weekly. They will in May.
Please keep this thread about NZ and it's next US city.
jobu7282
Wed Apr 15, 2015 6:53 pm
United doesn't use D as it's international terminal. United uses terminal E. What would interesting and I have nothing to back this up is if United would let them use an E gate, highly unlikely.
slider
Wed Apr 15, 2015 6:54 pm
Quoting Pbb152 (Reply 13):
You beat me to it, thank you. I was going to zap that one hard.
Moreover, that Term D apron area is in a refurb process right now, over several phases.
Term D is pretty full in afternoons with the big intl push, but there's plenty of time to accommodate much more traffic. Lord know the airfield can handle it.
kiwiandrew
Wed Apr 15, 2015 7:10 pm
I saw yesterday in the NZ thread that an announcement is expected 07:30 New Zealand time but if I have worked the time difference correctly that's about 90 minutes prior to the time mentioned in the link. I have to admit that 07:30 seemed very early in the morning for an announcement, but it came from a very reliable source. I'm still sure it's the same announcement in both cities, i.e. NZ to IAH , but surprised it's not simultaneous. ( unless maybe 07:30 is when NZ employees are officially advised with a public announcement to follow )
yellowtail
Wed Apr 15, 2015 7:12 pm
Quoting 76794p (Reply 28):
Unless I have missed something WN has not announced HOU-PTY
Quoting MaverickM11 (Reply 34):
Tell me about it....afternoon in IAH customs is a night mare.....it is almost as bad at MIA now.
Quoting Slider (Reply 37):
But D and E do share the same FIS which can be a real logjam despite HAS pledges to fix it.
jetblue1965
Wed Apr 15, 2015 7:18 pm
Quoting yellowtail (Reply 39):
JFK T1 in mid afternoon is horrendous too ... I swear it was like Ellis Island there
hohd
UA's Smisek was going to punish IAH by taking away the NZ route and they did. How will this route fit in with the "punishment" meted out by Smisek (if it is true that Air NZ will be new carrier).
Since WN was granted permission to fly internationally Spirit is giving new competition to the WN international routes and Spirit is in IAH. So for UA, you now have Spirit, which would started international service whether WN does or not.
MaverickM11
Wed Apr 15, 2015 7:28 pm
Quoting hohd (Reply 41):
Same as PEK, SCL, PUJ, IST, ICN, TPE, SVG,.... IAH gets loads of new service and less UA. Win-win-win.
thomasphoto60
Wed Apr 15, 2015 7:30 pm
Yep and back in the 90s, when HAS was begging for new int'l service, one of their big selling points was how much quicker and smoother clearing customs and immigration was compared to MIA.
thomasphoto60
Wed Apr 15, 2015 7:33 pm
Quoting MaverickM11 (Reply 42):
I am elated to see UA dragging their feet on int'l ops from IAH, as you say "win-win-win". The big question is how long will it last?
tortugamon
Wed Apr 15, 2015 7:35 pm
Should we consider New Zealand part of the Australian continent? I don't.
LAX-MEL is 500nm longer and that is done with a 789.
Quoting jetblue1965 (Reply 14):
Guilty. Not a lecture though.
Quoting jetblue1965 (Reply 17):
Indeed.
A great route addition. Happy to hear it. Announcement should be any second now. Its 0730 New Zealand time.
tortugamon
slider
Wed Apr 15, 2015 7:39 pm
That's not HAS's shop--it's a Federal deal.
And to the prior point made about WN and international service at HOU and UA's subsequent tantrum, the point was then and remains valid now that there just isn't enough inspection throughput. The City of Houston made a decision that really wasn't valid to make since FIS headcount has to be shared between IAH/HOU/Port of Houston. This was made very clear since there was allegedly a hiring freeze on the federal level.
UA mishandled the whole WN/HOU thing entirely.
Now NZ going to run IAH too is just icing on that cake. A good business lesson for everyone, really.
OA412
Wed Apr 15, 2015 7:40 pm
Quoting thomasphoto60 (Reply 44):
Is there really much UA can do at this point? They tried a second daily to NRT, and pulled that. IAH's O/D numbers on many routes are often smaller than those seen at DFW and ATL. I can't imagine that you're going to see 2nd dailies to PEK, IST, TPE, or now AKL any time soon. All UA can do, IMHO, is to grow in markets where another airline hasn't already staked a claim, like PVG, but they chose to go double-daily from SFO before starting IAH.
nzrich
Wed Apr 15, 2015 7:43 pm
"Pride of the pacific"
dubaiamman243
Wed Apr 15, 2015 7:46 pm
The New Zealand Herald Reports Air New Zealand to start Houston operation before the end of 2015 with Boeing 777
The next airline CEO :crossfingers:
