Quoting enilria (Thread starter): AS GTF-HLN AUG 2>1.4 SEP 2>0 OCT 2>0 AS SEA-GTF SEP 1.0>2 OCT 1.0>2 |
Quoting enilria (Thread starter): *DL CVG-GRR SEP 0.7>0 |
Quoting enilria (Thread starter): B6 BOS-SEA JUL 3>4 |
Quoting enilria (Thread starter): *B6 ANC-SEA JUL 1.0>2 |
Quoting enilria (Thread starter): *DL SLC-MDW JUL 0>0.8 AUG 0>1.0 SEP 0>1.0 OCT 0>1.0 NOV 0>1.0 DEC 0>1.0 |
Quoting Polot (Reply 1): Looks like 3M is starting to run out of routes intra-FL to put planes on. |
Quoting enilria (Thread starter): AS LWS-PUW AUG 1.0>0.7 SEP 1.0>0 OCT 1.0>0 |
Quoting enilria (Thread starter): KL ATL-AMS NOV 1.7>1.9 DEC 1.7>2 KL SFO-AMS NOV 0.9>1.0 DEC 0.8>1.0 |
Quoting MVAair (Reply 8): Quoting enilria (Thread starter): *DL SLC-MDW JUL 0>0.8 AUG 0>1.0 SEP 0>1.0 OCT 0>1.0 NOV 0>1.0 DEC 0>1.0 Why???? |
Quoting factsonly (Reply 10): DL announces a 3% cut in TATL capacity to destinations like SVO and a 15-20% cut to Africa for W15, yet decides to maintain connectivity with additional JV capacity on hub-hub routes in cooperation with KL. |
Quoting factsonly (Reply 10): Yet capacity will be lower as DL's B744 is replaced with A333. |
Quoting DCAYOW (Reply 11): Alaska is flying ORD - PVR this autumn ???? When was that announced? |
Quoting phatfarmlines (Reply 12): Could this be an AA codeshare? |
Quoting enilria (Reply 13): I assume it is respond to WN? Any other ideas? |
Quoting adamh8297 (Reply 7): They are both filling the planes with out any issue it seems. I'd love to know where B6 is connecting people to (see below may be some BOS-Alaska traffic) since they only get 283 O+D paxs in each direction per day. With a 89% load they had over 100 connections a day from the route. |
Quoting MVAair (Reply 8): Why???? |
Quoting enilria (Reply 13): I assume it is respond to WN? |
Quoting enilria (Reply 13): There is something fishy about that because as I understand it, DL must maintain half of Transatlantic capacity in the JV, so it would appear there will be cuts elsewhere to balance that. |
Quoting mtnwest1979 (Reply 9): Quoting enilria (Thread starter):AS LWS-PUW AUG 1.0>0.7 SEP 1.0>0 OCT 1.0>0 I see they are going to change the sched between LWS and BOI. Then it will be a 0630 dep from LWS with a 19xx arr back from BOI. |
Quoting Deltal1011man (Reply 19): Delta has a pretty nice offering out of MDW, SLC was a missing link though. All of the core hubs (ATL/MSP/DTW/SLC) all have flights to MDW now. |
Quoting Deltal1011man (Reply 19): Quoting enilria (Reply 13): I assume it is respond to WN? of course you do. |
Quoting MVAair (Reply 14): Quoting enilria (Reply 13): I assume it is respond to WN? Any other ideas? You mean a route WN's been flying for 10-20 years? Just now they noticed? |
Quoting Deltal1011man (Reply 19): Delta has a pretty nice offering out of MDW, SLC was a missing link though. |
Quoting MVAair (Reply 14): You mean a route WN's been flying for 10-20 years? Just now they noticed? |
Quoting enilria (Thread starter): Odd... *DL SLC-MDW JUL 0>0.8 AUG 0>1.0 SEP 0>1.0 OCT 0>1.0 NOV 0>1.0 DEC 0>1.0 |
Quoting enilria (Reply 23): In the same way Bigfoot is a missing link. Both are unnecessary to the chain. There is some oddball reason they are flying it. DL just isn't adding capacity in markets like that under their current strategy unless its from SEA or LAX. |
Quoting enilria (Reply 23): That's not how Delta does network planning. |
Quoting MVAair (Reply 21): Ok, but unless there is a lot of SLC originating traffic heading to the south side of Chicago that doesnt mind arriving at midnight, I dont see the market. For Delta loyal customers heading to MDW from the west, MSP is the hub to connect thru. Plus via MSP gets you there at a decent hour. |
Quoting Deltal1011man (Reply 27): false. Delta has already said they would also be growing capacity at SLC. |
Quoting Deltal1011man (Reply 27): SLC will be soon a 2 class only hub with some extra flights being added. |
Quoting Deltal1011man (Reply 27): Yes Yes enilria everything Delta does is simply to piss in some else pool. |
Quoting MVAair (Reply 21): Ok, but unless there is a lot of SLC originating traffic heading to the south side of Chicago that doesnt mind arriving at midnight, I dont see the market. |
Quoting enilria (Thread starter): AS GTF-HLN AUG 2>1.4 SEP 2>0 OCT 2>0 AS LWS-PUW AUG 1.0>0.7 SEP 1.0>0 OCT 1.0>0 |
Quoting enilria (Thread starter): AS PDX-BZN SEP 0>1.0 OCT 0>1.0 AS PDX-FCA SEP 0>1.0 OCT 0>1.0 |
Quoting enilria (Thread starter): DE PDX-FRA SEP 0.1>0.3 |
Quoting enilria (Thread starter): DL SEA-BOI JUL 4>3 |
Quoting enilria (Thread starter): WP HNL-LNY JUN 5>0 JUL 5>0 AUG 5>0 SEP 5>0 OCT 5>0 NOV 5>0 DEC 5>0 |
Quoting boeingrulz (Reply 20): Does this also end the PUW stop of the SEA-BOI-LWS-PUW-SEA rotation? |
Quoting JetBlueCLT (Reply 22): Interesting seeing SY bump up both JFK/BOS To 3 daily. Are they trying to beef up those routes to shy JetBlue off. Still have high hopes of JetBlue being in MSP in the next few years. |
Quoting jfklganyc (Reply 16): It is also quite amazing that you can not connect JFK-SEA-ANC. They have no desire to be in the NY-ANC market at all. |
Quoting enilria (Reply 28): It is when it is out of character. This is out of character. Believe what you will. |
Quoting enilria (Reply 13): I wonder how much of their currency proclamation is really just 747-400 retires we already knew about. |
Quoting enilria (Thread starter): UA ORD-AVL SEP 3>4 OCT 3>4 |
Quoting RWA380 (Reply 29): Looks as if QX is ending triangle & tag routes, which obviously makes sense to them. |
Quoting MSPNWA (Reply 31): I agree. I was going through the list of changes as usual (thanks for doing this every week BTW), and I was like, "woah...." |
Quoting MSPNWA (Reply 31): I think that's a big part of it. In fact I was reading one news story about it, and I believe it said 6 744s would be retired. But not matter how many go this year, moving from a 744 to an A333 is a significant drop in capacity that will impact the numbers. |
Quoting MVAair (Reply 32): Well we'll see how long SLC-MDW lasts. |
Quoting MVAair (Reply 32): Flying lots of low yield connecting traffic into Chicago's LCC airport with a RJ doesnt seem like a profitable opportunity. |
Quoting enilria (Thread starter): US PHX-HMO NOV 1.0>1.9 DEC 1.0>2 |
Quoting enilria (Reply 28): Adding 1 flight to Chicago's second airport is pitiful proof of that. |
Quoting enilria (Reply 28): |
Quoting Deltal1011man (Reply 38): a failure? |
Quoting enilria (Reply 39): That's why SLC-MDW is out of character. |
Quoting Deltal1011man (Reply 27): The MDW-SLC leg is late but again looks to connect to the last bank of west coast to SLC. |
Quoting enilria (Reply 39): BTW, that article is from 15 months ago. That's not exactly a hint at the freshest version of their strategy. |
Quoting Cubsrule (Reply 40): I don't see what it's out of character at all. You act like MDW is the only city in the central time zone that sees a single daily RJ to SLC, and that's simply untrue. Some of those flights (BNA, MSN) have stuck, and others haven't. MDW is more competitive, but even if you say that only 20 percent of the flying public in Chicago prefers MDW, the "market" is still a lot bigger than a place like Madison. |
Quoting Cubsrule (Reply 40): Our single daily SLC flight changes times a lot, and I have found the evening departure to SLC to add the most value over our umpteen ATL flights. That last bank at SLC hits just about every city of more than 500,000 people or so west of SLC, and it gains me about two hours on the ground in Nashville over the ATL terminators to the west coast, most of which leave around 1930. The time discrepancy will be even larger in a place like MDW that is farther from Atlanta. |
Quoting MSPNWA (Reply 31): I agree. I was going through the list of changes as usual (thanks for doing this every week BTW), and I was like, "woah...." To me it doesn't make any sense except to be a shot against WN. |
Quoting RJNUT (Reply 6): I read that they are going to tag on PLN 4 days /week to see if they can draw additonal seasonl traffic. I predict YES! |
Quoting enilria (Thread starter): *B6 ANC-SEA JUL 1.0>2 B6 BOS-SEA JUL 3>4 |
Quoting RWA380 (Reply 29): Quoting enilria (Thread starter): DL SEA-BOI JUL 4>3 Well they are "right sizing" at least one of the markets they entered in the Northwest, I wonder how the winter will shake out? |
Quoting RWA380 (Reply 29): Well they are "right sizing" at least one of the markets they entered in the Northwest, I wonder how the winter will shake out? |
Quoting PlanesNTrains (Reply 44): Pricing a fall trip to the midwest, regardless of the airport I selected, Delta had the lowest fares. Not sure what - if anything - this means, but it could just be that they are trying to trim a little here and there to prop up fares and yields. |
Quoting PlanesNTrains (Reply 44): Quoting enilria (Thread starter): *B6 ANC-SEA JUL 1.0>2 B6 BOS-SEA JUL 3>4 Wow! |
Quoting Deltal1011man (Reply 27): SLC will be soon a 2 class only hub |
Quoting threeifbyair (Reply 5): B6 BOS-SEA JUL 3>4 |
