barney captain
LAX T1 Gate Renumbering
Sat May 23, 2015 6:57 pm
The title says it all. Does anyone know what the logic is in the new numbering? The previous ones seemed to make sense, the new ones, not so much. I know it is related to the construction, but I'm having a hard time with the logic.
Southeast Of Disorder
raddek
RE: LAX T1 Gate Renumbering
Sat May 23, 2015 7:02 pm
Ok, there is very little information here you provided in the OP.
Not all of us live and fly our of LAX on a daily basis, so most of us need some extra juicy details on what they
are going to, gate numbers wise, to what they have had currently. I know gates in T1 are just numbered 1-3-10 etc.
CONTACREW
Sat May 23, 2015 7:19 pm
Quoting raddek (Reply 1):
Gates in T1 are now numbered 12A, 13, 14, 15, 16A, 16B, 17A, 17B, 18A, 18B as opposed to the previous format of 1 - 13.
Flight Attendants prepare doors for departure, cross check verify straps standby for all call
barney captain
Sat May 23, 2015 7:21 pm
My apologies, I didn't mean to leave you hanging. CONTACREW did a nice job of filling the blanks for me - thank you.
Do you see what I mean? Odd selection of numbers/letters wouldn't you say?
[Edited 2015-05-23 12:41:46]
msp747
Sat May 23, 2015 7:24 pm
Does this have something to do with the planned Terminal 0 Expansion? Or is that proposal not moving forward?
barney captain
Sat May 23, 2015 7:32 pm
Here is the new layout - starting at Gate 9? Strange. And why the A/B numbering split?
[Edited 2015-05-23 12:33:08]
[Edited 2015-05-23 12:33:48]
ty97
Sat May 23, 2015 7:43 pm
This is how the numbering for all of the other non-TBIT terminals work so I assume T1 gates were renumbered to conform. Gate numbers (except for TBIT) are two digit numbers where the first digit is the terminal number. If more than 10 gates numbers are needed in a given terminal, letters (A, B) are added to created more gates numbers.
See for example American's T4 (*this does not include the remote Eagle terminal which uses 44A, 44B, 44C, etc)
http://cdn.nerdwallet.com/travel/air...standard/lax_terminal_4_360_wl.png
And Delta's T5 (which also feature some similarly numbered Alaska gates in T6)
http://www.delta.com/content/www/en_...aircraft/airports/los-angeles.html
TBIT uses three digit gate numbers.
strfyr51
Sat May 23, 2015 7:49 pm
I'll bet it was to keep the gate numbers under #100
LAXintl
Sat May 23, 2015 7:50 pm
Here is the new numbering.
Project is not final and there will be an additional round of renumber once gates are fully reconfigured.
But simple logic is T1 = 1x gates, T2 = 2x gates, etc. TBIT will use 1xx and remote gates 2xx
ikramerica
Sat May 23, 2015 7:55 pm
Because T1 was not consistent with the airport.
The rest of LAX is numbered so that the first number indicates Terminal, and the second number indicates side of terminal (odd v. even). The Second number also must be between 0 and 9. A and B used to indicate a wide body gate split into two smaller gates (where one is disabled when the wide body is docked) but now it's just a way to fit 13 gates in a system that can't fit it.
And TBIT gates are all 1XX.
So...
If you are in gate 17 you know it's T1. Before if it was gate 7, it could confuse you into thinking it's T7.
It may be more for the benefit of security and ground personnel.
azjubilee
Sat May 23, 2015 8:06 pm
Quoting ty97 (Reply 6):
Quoting ikramerica (Reply 9):
That all makes great sense, but how in the world do you explain gate 9? And if they wanted to align with T2-T8, shouldn't they have started with 11?
LAXintl
Sat May 23, 2015 8:26 pm
Quoting azjubilee (Reply 10):
As I explained...
Quoting LAXintl (Reply 8):
Modernized terminal will actually have fewer gates than current facility does once all the reconfiguration is complete.
azjubilee
Sat May 23, 2015 8:38 pm
Quoting LAXintl (Reply 11):
Sorry, missed that part. But that begs to question... why bother doing an interim renumbering and just do it once the project is complete?
On a side note... how on earth is it taking the T2 refurbishing so long? And what happened to the men's room? It was complete and last time I was in T2 half of it was closed, with the open half, partially working. It actually was worse that the old restrooms when they were across the hall.
usflyguy
Sat May 23, 2015 8:51 pm
Why is WN getting rid of gates if they use all of them currently?
My post is my ideas and my opinions only, I do not represent the ideas or opinions of anyone else or company.
aklrno
Sat May 23, 2015 9:15 pm
Quoting usflyguy (Reply 13):
Something about 737-800 being bigger than other 737s.
goosebayguy
Sat May 23, 2015 9:47 pm
I passed through terminal 1 a couple of years ago. The queue reached out of the door. I only just managed to check in in time then the security line was equally long. Clearly the terminal wasn't large enough to cope with the number of passengers. Is this being addressed at all?
phllax
Sat May 23, 2015 9:56 pm
Because the 800's couldn't fit into any of the odd numbered gates except maybe 13, in addition to gate 2 and 14.
[Edited 2015-05-23 15:30:34]
afcjets
Sat May 23, 2015 10:12 pm
Expansion plans call for a new Terminal 0 just east of T1. This will allow for those gates to be numbered 1-8 followed by a letter if necessary. That is the only reason I can figure out.
[Edited 2015-05-23 15:13:01]
afcjets
Sat May 23, 2015 10:16 pm
Quoting goosebayguy (Reply 15):
In addition to a new terminal, they are going to also relocate the doors at T1 further west so cars will pull further ahead to relieve roadway congestion. This will likely result in a complete redesign of the ticketing and TSA areas, where the lines can queue inside instead of outside. Part of the problem now is the TSA checkpoint is just steps from the front door.
[Edited 2015-05-23 15:17:53]
phllax
Sat May 23, 2015 10:35 pm
Quoting afcjets (Reply 18):
The plan is to re-locate the check-in counters to the former US/HP side, and have security screening be on the current WN ticketing hall side.
All non-private vehicle drop-offs are now down on the former US/HP side.
I have heard that the current overflow security checkpoint near gate 1 is to become the FIS/customs area, but I can't quite picture how the logistics would work.
LAXintl
Sat May 23, 2015 10:48 pm
SWA previous T-1 configuration gave it only 3 737-800 capable gates without impacting adjacent gates. After the remodel SWA will have use of 12 737-800 capable gates.
barney captain
Sat May 23, 2015 11:23 pm
Quoting afcjets (Reply 17):
I've heard of this plan, but it begs the question - how? Are they going to close the road immediately East of T1 or possibly just cover it up and make it into a tunnel?
afcjets
Sat May 23, 2015 11:31 pm
Quoting barney captain (Reply 21):
IIRC the plans call for the rerouting of Sepulveda Blvd.
EDIT: There are so many plans in the works it is very confusing, one even calls for another terminal across Sepulveda Blvd, (not relocating it) yet further out they want to demolish T1-T3 and build a linear one-sided concourse parallel to the runways. Here though is a link with pictures of what T1 will look like and construction has already begun.
http://la.curbed.com/archives/2014/0...over_coming_to_laxs_terminal_1.php
[Edited 2015-05-23 16:48:41]
QANTAS747-438
Sun May 24, 2015 4:25 am
Why is there no gate 19 but there's a 17A and 17B??! Previously, paxs were confused with gates 11 and 13. They couldn't figure out which was which for some bizarre reason. Now... they're both 17 and it's mayhem in that corner.
jfklganyc
Sun May 24, 2015 12:57 pm
Talk about morons in a conference room convincing themselves they have a good idea!
1-1
1-2
So I (John Q Public Traveler) am supposed to know that all gates in T1 start with a 1...and since there are more gates than 10 allotted, I will throw an A or B on 4 of the gates?
What a pitifully stupid idea!
How about you start at 1 at T1 and just keep going throughout the airport?
Or how about saying to yourselves...In terms of airport design...you and JFK are alone in your "terminal city" concept...so what is JFK doing? Each terminal has their own numbering system. Which is fine because each terminal (with the exception of DL T2/4) operate as their own entity.
ScottB
Sun May 24, 2015 2:09 pm
Quoting jfklganyc (Reply 24):
It actually makes sense for wayfinding to break the numbering of gates on tens. EWR uses a similar numbering scheme, where the concourses in Terminals A & B use subsequent groups of ten (concourse A-1 uses 10-19, A-2 uses 20-29, etc.) and the concourses in Terminal C are broken up similarly (the three arms of C-1 are separated among 70-79,80-89,90-99) and C-2 and C-3 use groups of twenty.
On the south side of LAX, it's simple to follow the numbers between the interconnected terminals; i.e. if in Terminal 6, there will be signs for 40-59 and 70-89 in the other terminals.
I'd have to imagine that it'd be called something other than "Terminal 0" though. It probably makes more sense to just have an enlarged Terminal 1 akin to how Terminal 8 is mostly just an adjunct of Terminal 7.
I suppose "LAX is happening" is a better construction slogan than "LAX happens" but it's awfully close...
futureorthopod
Sun May 24, 2015 4:18 pm
This is for what I was hoping.
Polot
Sun May 24, 2015 4:25 pm
In reality that is what is basically going to happen. T1 is 10-19, T2 is 20-29, T3 is 30-39 etc. Any future T0 is 1-9. The problem with starting at 1 and just counting up (and ignoring A/B gates) is that it completely messes things up when you reconfigure/expand terminals and add gates. You then have to renumber every gate throughout the airport from that point on or add a letter to the new gate or break up the pattern some other way. .
[Edited 2015-05-24 09:26:29]
aklrno
Mon May 25, 2015 1:38 am
So by your scheme if I need to get to gate 53 I have no idea what building it is in? What a pitifully stupid idea.
Most airports would assign letters to the buildings, then numbers to the gates in the buildings. I guess LAX could do that, but those building numbers go back about 40 years.
The numbering scheme is perfectly understandable. I don't see how 17A is much less understandable than A17. If and when they build terminal 0, the gates will probably look like 01,02,03.
I've talked to passengers looking for help, mostly because of a language problem or because they just don't fly much. One glance at their boarding pass and I can tell them exactly where they need to go.
Someone asked about the road next to T1, and what happens to it if T0 is built. They plan to reroute that entrance to the airport through the parking lot next to T1. T0 goes where the road is now. It's a fairly easy change, but a bit expensive because it is two levels. The land is available.
Its bad enough that they broke the number scheme when TBIT went between buildings 3 and 4. At least it is simple, gate numbers 100 and up are at TBIT.
As for the crowding issue at T1, long security lines, etc. The construction to fix that is underway now. T1 was a mess when I passed through there a few weeks ago. Very few services available, but since most of the work in non-structural it should be much better soon.
N1120A
Mon May 25, 2015 2:06 am
Quoting barney captain (Reply 5):
If you think about it, Gate 9 (the old Gate 1) potentially connects over to a future T0. Also, A/B is common at LAX. Allows gates to fit into the numbering system.
73H and also the eventual connection over to T2.
Quoting ScottB (Reply 25):
I kind of hope they keep Terminal 0. Would be unique.
RedTailDTW
Mon May 25, 2015 4:00 am
It begs the question of why they didn't just assign concourse letters to each terminal (For example Terminal 1 would start with "A1" and Terminal 7 would start with "H1"). Many other airports, ORD comes to mind, use this type of system. I find it much easier to understand than the complex system that LAX is using.
Just my two cents...
Mason
Airlines Flown: 9E, AA, AS, B6, CO, DL, G7, HP, MQ, NW, RP, UA, US, WN, YX / Aircraft Flown: 737-200/300/700/800, 757-200/300, 777-200, A319/A320/A321, CRJ-200/900, DC-9-30/50, DC-10-40, ERJ 140/145, E170/175, MD80/83/90
mercure1
Mon May 25, 2015 4:12 am
Quoting RedTailDTW (Reply 30):
Complex
Terminals are 1,2,3, etc.
All terminals are numbered except the International terminal.
Whats complex about 1,2,3??
If anything that is more universal than using letters, which might actually confuse or be hard for those that do not utilize modern greek lettering and know the alphabet.
mercure f-wtcc
airplaneboy
Mon May 25, 2015 4:45 am
So is LAX building a terminal 0? A connector between T1 and T2? FIS/customs hall? I thought all 3 of these ideas were scrapped altogether if I remember correctly.
afcjets
Mon May 25, 2015 10:03 am
It may even be more complex than you realize. ONT which is also part of Los Angeles World Airports (LAWA) gates start at gate 201, and as mentioned above TBIT gates at LAX are numbered 100something. By gate numbers, ONT appears to be just another terminal at LAWA. BUR airport though, has gates as A1, B1, etc, which does not fit the pattern, yet still there is no duplicate gate number within the three airports that make up Los Angeles World Airports.
ikramerica
Mon May 25, 2015 11:00 am
Why not Terminal 0? The gates in each terminal start at 0. Gate 60 is really gate 6-0.
QANTAS747-438
Mon May 25, 2015 11:22 am
Quoting airplaneboy (Reply 32):
No, the T1 - T2 connector has been canceled as of now due to budget issues. The emphasis being 'as of now'.
YVRFlyer
Mon May 25, 2015 1:58 pm
Wow, the planners at LAX probably watched The Onion too often and got their inspiration from this
YVRFlyer
ikramerica
Mon May 25, 2015 2:09 pm
Quoting QANTAS747-438 (Reply 35):
Which is likely why gate 10 is there. Gate 9 will likely go away once the new TSA (and FIS?) area is finished.
UA1K3MM
Mon May 25, 2015 3:04 pm
Quoting afcjets (Reply 33):
"It may even be more complex than you realize. ONT which is also part of Los Angeles World Airports (LAWA) gates start at gate 201, and as mentioned above TBIT gates at LAX are numbered 100something. By gate numbers, ONT appears to be just another terminal at LAWA. BUR airport though, has gates as A1, B1, etc, which does not fit the pattern, yet still there is no duplicate gate number within the three airports that make up Los Angeles World Airports."
Sorry, but I believe your statements are incorrect on both counts. #1 - BUR is not owned or operated by LAWA. It is an separate commercial airport. LAWA operates LAX, ONT and VNY. See LAWA.org
#2 The master plan for ONT at the time the current "new" terminals were built in the mid 1990s and opening tn 1998, there were plans for four terminals. Terminal 2 (UA, AS, DL and Mexican flights) and Terminal 4 (AA and SW) thus you have the 200 and 400 series gate numbering. Terminal 3 was to be built for future growth in between these two terminals where the overnight aircraft stands are currently. Terminal 1 was going to be west of Terminal 1 in the area where the current FIS arrival building is today. Of course you also still have the old terminal building as well which today houses the ONT offices, USO and Hollywood old airport movie set location. Keep in mind this plan was developed in the early 1990s when passenger projections for ONT were being estimated at over 20 million a year and ONT was serving about 9 million passengers annually when the new terminals opened.
ONT is still the best located and most under served airport in Southern California.
afcjets
Mon May 25, 2015 3:56 pm
Quoting UA1K3MM (Reply 38):
That may explain why BUR has a different numbering convention. Having the first number designate the terminal number is not very common and specific to LAWA and regardless of the master plan the fact remains that LAX gate numbers are between 1 and 159 and ONT starts at gate 201 and therefore they appear sequential with no duplicate gate numbers and both operated by LAWA. It is interesting they operate 2 commercial airports and one private airport. Also, LA county, yet BUR and LGB are, which they do not operate.
Top
LAXintl
Mon May 25, 2015 4:44 pm
First LAX is not into "expansion" projects.
Todays work is considered renovation. At the end of the day the airport operates under a court approved annual passenger limit and gate count cap, and community certainly does not wanted to see an expanded LAX.
Secondly Terminal-0 concept is one of the alternative that came out of the specific plan amendment study in 2012, but things have not beyond moved that. There has been no required environmental reviews on the project nor a formal green light from the city.
This is pure A.net lure.
The LAX masterplan has no plans for a T1 to T2 connection. Its not even one of the yellow lighted(yet to be approved) concepts.
In addition the 2013 T-1 renovation concept study itself made no proposals for a T-1 to T-2 connection either, let alone one being approved.
Quoting afcjets (Reply 39):
You can forget your hypothesis. LAX remote gates are 2xx.
[Edited 2015-05-25 09:50:02]
ldvaviation
Mon May 25, 2015 4:49 pm
Quoting LAXintl (Reply 40):
In addition the 2013 T-1 renovation concept study itself made no proposals for a T-1 to T-2 connection either, let alone one beign approved.
It has been discussed internally.
But you are correct. It has never been formally proposed or budgeted.
afcjets
Mon May 25, 2015 5:04 pm
Do you mean the Imperial Terminal where MGM Grand Air used to depart from?
LAXintl
Mon May 25, 2015 5:08 pm
No the 19 remote gates and facilities at West end of airport.
barney captain
Mon May 25, 2015 6:01 pm
LAXintl, and all -
Thanks for your insight and clarification, it is much appreciated.
