Quoting raddek (Reply 1): |
Quoting raddek (Reply 1): Ok, there is very little information here you provided in the OP. Not all of us live and fly our of LAX on a daily basis, so most of us need some extra juicy details on what they are going to, gate numbers wise, to what they have had currently. I know gates in T1 are just numbered 1-3-10 etc. |
Quoting ty97 (Reply 6): |
Quoting ikramerica (Reply 9): |
Quoting azjubilee (Reply 10): That all makes great sense, but how in the world do you explain gate 9? |
Quoting LAXintl (Reply 8): Project is not final and there will be an additional round of renumber once gates are fully reconfigured. |
Quoting LAXintl (Reply 11): |
Quoting LAXintl (Reply 11): Modernized terminal will actually have fewer gates than current facility does once all the reconfiguration is complete. |
Quoting goosebayguy (Reply 15): I passed through terminal 1 a couple of years ago. The queue reached out of the door. I only just managed to check in in time then the security line was equally long. Clearly the terminal wasn't large enough to cope with the number of passengers. Is this being addressed at all? |
Quoting afcjets (Reply 18): In addition to a new terminal, they are going to also relocate the doors at T1 further west so cars will pull further ahead to relieve roadway congestion. This will likely result in a complete redesign of the ticketing and TSA areas, where the lines can queue inside instead of outside. Part of the problem now is the TSA checkpoint is just steps from the front door. |
Quoting afcjets (Reply 17): xpansion plans call for a new Terminal 0 just east of T1. This will allow for those gates to be numbered 1-8 followed by a letter if necessary. That is the only reason I can figure out. |
Quoting barney captain (Reply 21): I've heard of this plan, but it begs the question - how? Are they going to close the road immediately East of T1 or possibly just cover it up and make it into a tunnel? |
Quoting jfklganyc (Reply 24): So I (John Q Public Traveler) am supposed to know that all gates in T1 start with a 1...and since there are more gates than 10 allotted, I will throw an A or B on 4 of the gates? |
Quoting afcjets (Reply 17): Expansion plans call for a new Terminal 0 just east of T1. This will allow for those gates to be numbered 1-8 followed by a letter if necessary. That is the only reason I can figure out. |
Quoting LAXintl (Reply 8): |
Quoting jfklganyc (Reply 24): How about you start at 1 at T1 and just keep going throughout the airport? |
Quoting barney captain (Reply 5): Here is the new layout - starting at Gate 9? Strange. And why the A/B numbering split? |
Quoting usflyguy (Reply 13): Why is WN getting rid of gates if they use all of them currently? |
Quoting ScottB (Reply 25): I'd have to imagine that it'd be called something other than "Terminal 0" though. It probably makes more sense to just have an enlarged Terminal 1 akin to how Terminal 8 is mostly just an adjunct of Terminal 7. |
Quoting RedTailDTW (Reply 30): find it much easier to understand than the complex system that LAX is using. |
Quoting RedTailDTW (Reply 30): It begs the question of why they didn't just assign concourse letters to each terminal (For example Terminal 1 would start with "A1" and Terminal 7 would start with "H1"). Many other airports, ORD comes to mind, use this type of system. I find it much easier to understand than the complex system that LAX is using. |
Quoting airplaneboy (Reply 32): A connector between T1 and T2? |
Quoting QANTAS747-438 (Reply 35): |
Quoting afcjets (Reply 33): |
Quoting UA1K3MM (Reply 38): #1 - BUR is not owned or operated by LAWA. |
Quoting UA1K3MM (Reply 38): Top RE: LAX T1 Gate Renumbering
First LAX is not into "expansion" projects. Todays work is considered renovation. At the end of the day the airport operates under a court approved annual passenger limit and gate count cap, and community certainly does not wanted to see an expanded LAX. Secondly Terminal-0 concept is one of the alternative that came out of the specific plan amendment study in 2012, but things have not beyond moved that. There has been no required environmental reviews on the project nor a formal green light from the city.
This is pure A.net lure. The LAX masterplan has no plans for a T1 to T2 connection. Its not even one of the yellow lighted(yet to be approved) concepts. In addition the 2013 T-1 renovation concept study itself made no proposals for a T-1 to T-2 connection either, let alone one being approved.
You can forget your hypothesis. LAX remote gates are 2xx. [Edited 2015-05-25 09:50:02] From the desert to the sea, to all of Southern California
It has been discussed internally. But you are correct. It has never been formally proposed or budgeted. RE: LAX T1 Gate RenumberingFrom the desert to the sea, to all of Southern California
RE: LAX T1 Gate RenumberingLAXintl, and all -
Thanks for your insight and clarification, it is much appreciated. Southeast Of Disorder
Who is onlineUsers browsing this forum: bigb, Bing [Bot], CALMSP, CanadianRedneck, CBRboy, csturdiv, Dalavia, eightcone, FlyingHonu001, gdavis003, GeneW, gregn21, hbernal1, irelayer, jamie86, JayinKitsap, lemondao, qf789, rbretas, SoEWR, TTailedTiger, TWA772LR, UALFAson, vadriver, wrenchon727, zippy and 200 guests
