Quoting Roseflyer (Thread starter): I am completely confident |
Quoting Roseflyer (Thread starter): we continue to be confident that |
Quoting Roseflyer (Thread starter): is on track to deliver |
Quoting SEPilot (Reply 2): However, I have to share some of PlanesNTrains skepticism |
Quoting SEPilot (Reply 2): I certainly hope that the statements are true. |
Quoting SeJoWa (Reply 14): It makes a lot of sense to me, given the inclusion of so much new technology, to actually measure how the assembled engine degrades over time, and one can assume there are data sets specific to every relevant new element that provide a useable baseline individually. |
Quoting seahawk (Reply 16): The interesting test would be to see if the parts age as expected. |
Quoting SEPilot (Reply 2): I have to share some of PlanesNTrains skepticism. |
Quoting JoeCanuck (Reply 6): Nobody will know the real truth until an airline leaks the numbers to the public. |
Quoting JoeCanuck (Reply 11): Oy vey. |
Quoting rheinwaldner (Reply 12): his kind of testing is new to me, I never heard that these kind of tests were done. In the end it is very expensive to build a test engine solely to measure the performance with so called “end of life ”clearances”. |
Quoting seahawk (Reply 16): hat would make sense, but they say the did built a new engine to simulate a used standard. So obviously all parts would need to be artificially aged |
Quoting SeJoWa (Reply 17): Absolutely, but as I've written, they must have a good enough idea about the ageing of individual parts. What's certainly harder to predict are cumulative effects. An aged engine could, at a certain point, display some discontinuity leading to more severe deterioration? If some parts aren't cooled adequately, this engine's high temps would make it especially susceptible. |
Quoting rheinwaldner (Reply 12): There are still reputeable bloggers who doubt the presented PR... http://aeroturbopower.blogspot.ch/20...05/the-cfm-leap-1b-discussion.html Quote: This kind of testing is new to me, I never heard that these kind of tests were done. In the end it is very expensive to build a test engine solely to measure the performance with so called “end of life ”clearances”. (this as a response because CFM said the shortfall came from a test with with a deliberatly degraded engine). |
Quoting Rheinbote (Reply 15): The question is what CFM could do about a shortfall in case? I'd assume that the LEAP already incorporates whatever is in CFM's portfolio of technology bricks in order to counter the PurePower family and make good on the latter's benefit from geared fan technology. |
Quoting seahawk (Reply 20): Yes, but for me it feels a bit early for such test. |
Quoting Stitch (Reply 22): Quoting seahawk (Reply 20): Yes, but for me it feels a bit early for such test. CFM has stated LEAP-X will maintain the same (low) maintenance costs as the CFM56 family, so if CFM is making maintenance and part-life guarantees as part of their current LEAP sales contracts, I could see them wanting to have an idea of how those parts are holding up so they don't end up with a situation like Pratt on the early PW4090s where the guide swirlers had a service life only 33% of plan or GE on the early GE90 where the fuel-injectors were failing within two dozen flights. |
Quoting seahawk (Reply 16): That would make sense, but they say the did built a new engine to simulate a used standard. So obviously all parts would need to be artificially aged. That would be based on your simulations and would at best confirm that the fuel consumption of an old engine would be the same as your simulation says, but only if your simulation on how each part ages is correct. The interesting test would be to see if the parts age as expected. |
Quoting seahawk (Reply 13): Makes sense. They would have to guess how the engine will age, as only real running will show how it will age. Building an engine to a used specification at that stage of the program makes little sense to me. |
Quoting rcair1 (Reply 19): I've done it. Not on jet engines, but on mechanical devices that wear - to make sure the tolerance stacks worked with the specifications. |
Quoting Roseflyer (Reply 21): if you pass every single qualification test on your first try, that means as a designer you failed because you left too much safety margin in your design (ie design is too heavy or the goals weren't good enough). |
Quoting Stitch (Reply 22): I could see them wanting to have an idea of how those parts are holding up so they don't end up with a situation like Pratt on the early PW4090s where the guide swirlers had a service life only 33% of plan or GE on the early GE90 where the fuel-injectors were failing within two dozen flights. |
Quoting lightsaber (Reply 24): Sorry to nitpick, but one of the major issues with the 'used at tolerance' is the temperatures within the engine. While fuel burn will be interesting, how an engine ages for fuel burn is less important at this stage. It is safety so that if bore-o-scope checks will find certain gaps. If the engine is within the test engine gaps, the engine may continue running. So if the engine if found to operate OK, in service engine may continue to run. This is a required step in engine certification; while it can be skipped with earlier overhauls of in service engines, this is the lower cost option if a significant number of engines is expected to be sold quickly (as with the LEAPx). Lightsaber |
Quoting Roseflyer (Reply 21): While exceeding objectives are good, it is better to set higher goals and meet them than predict poor results and exceed. |
Quoting rheinwaldner (Reply 25): It is not about whether they would do those test or not. It is about the motivation why those tests are done so early. |
Quoting rheinwaldner (Reply 25): Quoting Roseflyer (Reply 21): if you pass every single qualification test on your first try, that means as a designer you failed because you left too much safety margin in your design (ie design is too heavy or the goals weren't good enough). The goals in this case are primarily given by the competition. CFM obviously is planning to deliver specs which satisfy a large chunk of the market. So the goals have been set sufficiently high. But this does not mean that you need to haunt the goals up to EIS and beyond. You can reach the goals early, continue to improve the product and deliver even better engines at EIS (as Pratt seems to be doing). |
Quoting Roseflyer (Reply 28): Based in the potential error and accuracy of predictions, promised performance is backed off depending in the confidence of those predictions. If CFM is too cautious on their numbers, they lose millions in potential revenue. Reaching the goals early and then exceeding them is great, but it also means that they lost significant revenue and potential orders. |
Quoting rheinwaldner (Reply 25): You can reach the goals early, continue to improve the product and deliver even better engines at EIS (as Pratt seems to be doing). |
Quoting seahawk (Reply 26): of |
Quoting lightsaber (Reply 32): The GEnX made similar promises. Alas GE has lost their reputation. Now my last information was in March, but I'm not expecting the LEAP-1A to meet promise. I hope I'm wrong and CFM is competitive and a close horse race. |
Quoting KELPkid (Reply 33): Probably not nearly as bad as Pratt did after the P&W6000 fiasco... |
Quoting JoeCanuck (Reply 31): What we haven't heard is anything from the many airlines which would be the ones dealing with any shortfall...and surely they must be in the loop at this point. They were among the loudest complaining about 787 problems and I can't imagine they would be shy about dissing the LEAP if the situation was as severe as some bloggers are predicting...but zip so far, not a peep. |
Quoting Richard28 (Reply 35): It could also be that airlines have performance guarantees written into their contracts, so they will get a contractual perforance either through the LEAP engine itselft or through compensationary payments. |
Quoting mffoda (Reply 37): He adds that Airbus and P&W are addressing a "maturity issue" on the PW1100G, relating to a seal in the vicinity of the high-pressure compressor, some production batches of which have shown "slightly more deviations" during operation. |
Quoting mffoda (Reply 37): "Evrard says that he is confident that both powerplant types will reach the fuel-burn levels promised by their manufacturers, pointing out that the airframer has yet to conduct detailed analysis on the Leap-1A performance because it "hasn't had enough experience in flight". |
Quoting JoeCanuck (Reply 31): What we do have is, the folks dealing with the situation saying everything is A OK. |
Quoting neutronstar73 (Reply 38): No CFM comes out and says the report that many people relied upon was from a test rig, and that all the naysayers were wrong (as usual). |
Quoting rheinwaldner (Reply 41): In which recent project were the naysayers wrong? - The 787? No - The 748? No - The 787&748 engines? No Only for the A350 and the A350 engine we can say that the naysayers were wrong. |
Quoting astuteman (Reply 30): Whatever happened to "under-promise and over-deliver" at Boeing? |
Quoting parapente (Reply 43): The GTF was going onto the A320 (as much as Boeing tried to persuade Airbus not to go down this particular road). |
Quoting parapente (Reply 43): Cfm had to promise the same (or very similar) otherwise there would have been no point.They had to anyway or else Boeing were a dead duck in the narrow-bodied sector and that was not going to happen. |
Quoting parapente (Reply 43): Boeing have got the sales in on the the MAX. If/when the cat comes out of the bag that a GTF engines is 'naturally' a better and more efficient technology, then you will see the 737 replacement come out awful quickly.Oh and yes it will be able to carry a GTF style engine! |
Quoting Roseflyer (Reply 42): Please don't make this Airbus vs Boeing. Both the A320 neo and 737max use the LeapX so this is should be and Airbus and Boeing discussion. The LeapX is more popular on the A320 that the PW engine, so we know at least the airlines feel that it is a competitive engine based in their analysis. |
Quoting Roseflyer (Reply 42): The LeapX is more popular on the A320 that the PW engine, so we know at least the airlines feel that it is a competitive engine based in their analysis. |
