Quoting chrisp390 (Reply 62): I would not fly on SQ, despite their great product they seem to not have as much of a focus on safety as other airlines. Their decision not to divert plus the fact their aircraft was extremly close to the MH aircraft that got shot down while many other airlines had it marked as a no fly zone are 2 clear examples |
Quoting wjcandee (Reply 67): Alaska thought they had the thing basically under control, then they didn't. |
Quoting Rara (Reply 39): As to why the aircraft didn't divert to HKG: Keep in mind that a diversion only makes sense if it improves safety over the alternative. In this case, diverting to Xiamen would have been as safe as diverting to Hong Kong. Diverting to Taipei likewise, Wenzhou likewise, and so on all the way to PVG. In other words, as long as the aircraft is stable and flying, there's no real added safety benefit to landing as soon as possible |
Quoting ChaosTheory (Reply 60): |
Quoting hivue (Reply 48): I think you missed my point. Would they continue to destination (as this airplane did) or divert to the nearest suitable airport 200 min away? |
Quoting mandala499 (Reply 65): If this was NOT a dual flame-out, OK, it's debateable, but if it was a dual flame out on the 330... Why the heck didn't they divert I don't know... again, LOTS of answering to do... |
Quoting chrisp390 (Reply 69): Wjcandee explained it very well. I fly with US airlines, most British and Canadian ones plus CX to name a few. These are airlines based in jurisdictions that put a much greater emphasis on 'safety culture' than most other countries in the world |
Quoting lammified (Reply 71): it is likely that the ground teams at SQ had a good appreciation of the situation on 9V-SSF at the time and I am certain that the crew would have consulted with their ground teams before making the decision to continue the flight to PVG |
Quoting hivue (Reply 32): what would be the proper action if they'd been on an, e.g., ETOPS 240 flight 200 minutes from nearest suitable? Also continue? |
Quoting speedbored (Reply 86): I think this is wildly-optomistic. |
Quoting Roseflyer (Reply 35): I also think the regulators are going to look in to how this happened to an airplane that is only two months old. The airplane being so new raises some questions. |
Quoting mats01776 (Reply 67): This immediately came to mind: Software Cut Off Fuel Supply In Stricken A400M |
Quoting CALTECH (Reply 69): " It also is important to note that more than 90 percent of airplane diversions have nothing to do with engines but rather involve weather, a sick passenger or other reasons." " Records for the four-engine A340 show it has had twice as many diversions and turnbacks as the twin-engine 777, and the A340 has a lower average dispatch reliability rate than the 777" |
Quote: Heard from a Reliable Source By Stan on Wednesday, May 27th 2015 23:59Z Hi Everyone, Just contributing what I heard from those in the know about preliminary findings. SQ-836 had almost brand new engines. Hit turbulence which resulted in minor, momentarily fan blade contact with nacelle in both engines. This was detected by onboard computer. Logic commanded a wind down to prevent fan blade damage. Successful auto restart on one engine within a couple of minutes without crew action. Other engine did not fire up. Crew commenced drift down due single engine ops and perform engine fail checklist. Successful relight of second engine. Crew weighed the risk of another engine fail and the notoriously draconic conditions (and weather conditions) for diversion in China airspace for non domestic flights and elected to press on. To turn back for HKG would have resulted in longer flight time. |
Quoting BoeingGuy (Reply 55): So did SW111 and AC797 think they had everything under control. AC overflew SDF; and SW111 first wanted to go back to BOS and then was dumping fuel rather than landing at YHZ. |
In the time frame between turning back toward the bay, the Mayday call, and the disappearance from radar; they would've still been several miles out from the airport.
Quoting benjjk (Reply 76): Can an A330 glide on no engines at only -500fpm? |
Quoting benjjk (Reply 76): But my opinion remains that there is far less to this incident than some people seem to think. |
Quoting wjcandee (Reply 78): Well...the South China Morning Post is quoting SQ as saying that the pilots initiated a "controlled descent in order to" restart one of the engines, which sure sounds like a windmill relight to me. Which means the candle was out. Which would require any American carrier to land at the nearest suitable. |
Quoting ThirtyEcho (Reply 90): For my money, I prefer the B-36 and its ten engine power. Nice mix of piston and jet power, too. Would be safer if they had just added a couple of rocket packs for that secure over the fence feeling. |
Quoting BoeingGuy (Reply 79): Why couldn't they have done a bleed air assisted start (e.g. a ground start) either from the APU or a cross-bleed start instead? |
Quoting speedbored (Reply 81): The simple fact that they continued suggests to me that they identified the cause of the problem, and how to rectify it, and understood any likely consequences. |
Quoting speedbored (Reply 81): So many people jumping to so many conclusions with almost no evidence whatsoever. |
Quoting speedbored (Reply 81): One fact we can be certain of is that there is nowhere near enough information available publicly for any of us to know what happened so why don't we all wait for the official report before trying to dissect things too much and condemning the pilots for all-sorts of misdeeds? |
Quoting catiii (Reply 13): Since no one knows WHY the engines shut down (maybe they were inadvertantly shut down by the flight crew) |
Quoting speedbored (Reply 81): Regardless of the competence, or otherwise, of the flight crew, simple self-preservation would suggest that they would have declared an emergency and diverted to the nearest airport if things were anywhere near as bad as many people seem to think they were. |
Quoting wjcandee (Reply 84): Once you have even a single engine failure, it's not their decision to make anymore about whether it's safe to proceed to destination rather than diverting. Safety-conscious countries require airlines to have POLICIES about what to do when certain things happen. |
Quoting CALTECH (Reply 69): " If you have two engines, there are two chances of engine failure. If you have four engines, there are four chances of engine failure. The chance of engine malfunction doesn't go down with four engines; it goes up." |
Quoting s5daw (Reply 88): Again: the chance of one of the engines failing goes up with number of engines, but probability of losing all engines goes down drastically |
Quoting Ruscoe (Reply 90): I believe that would only be true for independent events. If there is a common fault, in planning, design or manufacture, and there sometimes is. eg faulty common software, leaking fuel pipe, poorly manufactured oil pipe, then the chances are not so remote |
Quoting questions (Reply 89): What is the passenger experience in situations like this? Do they hear the engines cut off? Power back up? Does the cockpit crew disable the "flight map" that passengers see on PTVs that includes things like altitude? |
Quoting Curiousflyer (Reply 93): Will they eventually publish a detailed account of the issue? When? |
Quoting bhill (Reply 96): why the descent to "restart" engines that were "not" shut down? |
