Quoting eielef (Reply 5): makes for me no sense |
Quoting eielef (Reply 5): Could it be technically posible to have a 150 seater turboprop? |
Quoting DavidByrne (Reply 9): Don't see why not. Back in the 1960s the British Vickers Vanguard (operated primarily by BEA and Trans-Canada) came in at 130 seats plus. And the Russian Tupolev TU-114 was the largest aircraft in the world for its time (late 1950s?) at around 220 seats, if I recall. |
Quoting Dalmd88 (Reply 11): One thing you are all forgetting, The US traveling public hates turboprops. They are perceived as being ancient, noisy, and unsafe. Given a choice between a new Q400 and a 40 year old 737, they will say the 737 has to be newer and safer. A big turboprop will never sell in the US market. |
Quoting TheSonntag (Reply 12): The Transall C-160 has two engines and is almost the size of the C-130. So it is possible with 1960s technology to builld large props. |
Quoting rlwynn (Reply 14): Quoting Dalmd88 (Reply 11): One thing you are all forgetting, The US traveling public hates turboprops. They are perceived as being ancient, noisy, and unsafe. Given a choice between a new Q400 and a 40 year old 737, they will say the 737 has to be newer and safer. A big turboprop will never sell in the US market. People of the USA do not seem to mind Horizon and the Q400. |
Quoting bond007 (Reply 13): But AFAIK, you won't get 150 pax and luggage into a C-160. It looks like around 100 troops ..admittedly that probably includes their equipment, but you'd need to find room for suitcases also. |
Quoting rlwynn (Reply 14): People of the USA do not seem to mind Horizon and the Q400. |
Quoting Marvinhsv (Reply 16): I can hear people complaining about a 'small shitty prop'. |
Quoting DCA-ROCguy (Reply 19): They fly at lower altitudes than jets, so they're best in places where there aren't a lot of storms or bumpy air (the Northwest's regular rain isn't usually stormy). Places where it doesn't get below freezing a lot. |
Quoting DCA-ROCguy (Reply 19): Places where it doesn't get below freezing a lot. |
Quoting kurtverbose (Reply 4): There was a thread a while ago about a 150 seater turboprop using Europrop TP400 engines. Given the demand for short haul aircraft I'm surprised the marked hasn't fragmented to support a big turboprop like this. |
Quoting mpadhi (Reply 8): I wonder if it would be possible for them to use an A400M variant? Although, I don't imagine the A400M was designed for efficiency, even if it does use turboprops. |
Quoting DCA-ROCguy (Reply 19): |
Quoting RyanAirB737 (Reply 28): I thought it was just the opposite: where turboprops can handle snowy and icy conditions better (wind is still a problem) than a jet. I read that is why the CRJ route from SFO-MMH seems to always be canceled whereas the Q400 route from LAX-MMH is not canceled (assuming conditions at SFO and LAX are the same). |
Quoting Marvinhsv (Reply 16): Same in Germany. I'm flying between Hamburg and Nuremberg quite often and every time I board my beloved Q400 I can hear people complaining about a 'small shitty prop'. I have to choose between a Germanwings A319 and the Q400 and I always go with the prop. I like the kind of private feeling and the vibration when flying. You only have one neighbor and it's not any tighter than the GWI ones. |
Quoting LTU330 (Reply 3): |
Quoting Stratofish (Reply 32): Well. it all depends on the point of view: economical or passenger comfort. As far as I (and many else) am concerned, props don't have any place in todays skies! Absolutely zero! |
Quoting 32andBelow (Reply 22): You know turboprops fly all around the state of Alaska including Horizon right? |
Quoting DavidByrne (Reply 9): Quoting eielef (Reply 5): Could it be technically posible to have a 150 seater turboprop? Don't see why not. Back in the 1960s the British Vickers Vanguard (operated primarily by BEA and Trans-Canada) came in at 130 seats plus. |
Quoting Stratofish (Reply 32): Well. it all depends on the point of view: economical or passenger comfort. |
Quoting Stratofish (Reply 32): As far as I (and many else) am concerned, props don't have any place in todays skies! Absolutely zero! I refuse to fly on a prop "airliner",with reason, period! Props are for general aviation and general aviation only! |
Quoting motorhussy (Reply 27): Tahiti to Rarotonga, an international flight of 1,500kms, is flown on an Atr-72. This route used to be flown by NZ (AKL-RAR-PPT-LAX) with a range of aircraft including 763 and 742. |
Quoting iflycanadian (Reply 39): How many seats were on the BEA Vanguard aircraft? |
Quoting bond007 (Reply 13): I fly 2-4 times a week, and this perceived negativity against turboprops is mostly just that ...not reality. 99% of those booking flights do not make it based on aircraft type, even if they do know what they are going to be flying on. |
Quoting warren747sp (Reply 40): The problem is the the max altitude of a Turboprop is only FL25000. So many times it can not climb above bad weather and we get rocked around a lot! |
Quoting lightsaber (Reply 45): But most of the 'road warriors' I know dislike turboprops |
Quoting lightsaber (Reply 45): They know the turboprop is unlikely to climb above the weather. They also notice the speed difference on any route they wouldn't just drive. Here in the USA, unless there is water, people drive 240 to 300 miles without a 2nd thought. |
