Quoting flybynight (Thread starter): 1 - do they actually have one 753? 2 - I believe the average fleet is close to 20 years old, which is not a big deal for all of their long haul flights, but at the same time they must be thinking of fleet renewal 3 - Are they still getting one 787? 4 - Seems like the 787 would be a good plane for them. More efficient compared with the 757, yet not that much larger. In fact, even if their yields didn't go up. the efficiency of the 787 seems like it would offset the difference 5 - Or are they looking at the new generation of 737 MAX or A320 NEO's? 6 - I like their niche and it is a perfect way to break-up a flight to Europe. I see a lot of potential with Icelandaire but are they too much of a lonewolf? 7 - How about AS and Icelandaire code-share (again). |
Quoting btblue (Reply 5): I wonder if they were one of the 30 airlines Boeing have discussed the MOM aircraft with. |
Quoting mjoelnir (Reply 6): I do not believe FI going for the A321LR. FI has been a Boeing only airline for quite a while. |
Quoting eaa3 (Reply 8): I actually think they're smarter than that. It will depend on what's best for their operation. And the A321LR is clearly a much better fit than the B737-9 that can't make it to North America with anything approaching a full load. It couldn't take off from KEF. |
Quoting AndyEastMids (Reply 10): 737MAX9 mainly for Europe and 737MAX8 for near USA... Frequency will increase on some routes as capacity per flight goes down |
Quoting mjoelnir (Reply 9): 767-300 for high density routes like LHR starting early 2016... Not for new destinations outside the payload range capability of the 757 |
Quoting by738 (Reply 12): The fish jokes werent funny the first time... I doubt the 787 will ever see FI colours |
Quoting UsAir737 (Reply 14): Wow 1 788. How many fish can you fit on a 788 anyway? |
Quoting mjoelnir (Reply 15): I could agree with that it is likely that Icelandair is buying a 787, but I also agree that it as likely that they will use it for their wet leasing operation. |
Quoting mjoelnir (Reply 11): I heard it different. |
Quoting mjoelnir (Reply 9): Both runways are 10,000 feet. KEF is a sea level and never hot. So there are no problems with the runway with whatever frame FI will use. I do not expect the 737MAX to be used, but to Europe and east coast of North America. |
Quoting mjoelnir (Reply 9): Fi will keep the 757 for quite a few years to come. Apart from that, the A321LR has no volume left for freight after passenger and luggage. |
Quoting ams747757 (Reply 19): I'd guess that some of those recent birds they acquired from AA were due for heavy checks, which FI did |
Quoting eaa3 (Reply 17): It's got more volume than the B737-9. That's what we're talking about here. This comment about freight is what started the whole fish thing. You hijacked an entire thread about the A321LR to talk about that. Please stop being stubborn about this point. We get it. |
Quoting eaa3 (Reply 8): Being stubborn is a really stupid business reason! I actually think they're smarter than that. It will depend on what's best for their operation. And the A321LR is clearly a much better fit than the B737-9 that can't make it to North America with anything approaching a full load. It couldn't take off from KEF. Although, I think we'll see more from Airbus in the form of a larger A321 (A322) with larger wings and longer range. I think that wing will also be put on the A321, giving it more fuel capacity and therefore range. If (when) that happens Icelandair will have no choice at all if Boeing doesn't respond. It would be a question of life or death. [Edited 2015-06-09 18:08:38] |
Quoting DualQual (Reply 24): How did you arrive at a 737-900ER needing 11000 feet of runway fully loaded on a cold day? |
Quoting by738 (Reply 12): The fish jokes werent funny the first time... |
Quoting btblue (Reply 23): Maybe, just maybe, the 739-Max is just a slot holding for something better |
Quoting AndyEastMids (Reply 20): The ex-AA aircraft have had repaint, scheduled maintenance checks, minor corrosion work where needed, flight deck upgrades (new glass cockpit displays), cabin refit, IFE/VOD and Wifi |
Quoting eaa3 (Reply 17): I don't think you've done your research here. A B737-900ER needs over 11,000 feet to take off fully loaded on a cold day. The B737-9 is heavier but with the same thrust. Basic physics tells us that it will need more runway. Then of course it has to return to Iceland. Imagine that the a 30 degree celcius day in Boston. The B737-9 would be a nightmare in that situation. |
Quoting sassiciai (Reply 25): Obviously something fishy about that claim! |
Quoting flybynight (Reply 28): I don't think 11,000 feet is correct. I certainly could be wrong, but I would have it put it around 7,000 feet. Not even an A380 needs 11,000 feet to takeoff. |
Quoting eaa3 (Reply 30): I’m not just saying this randomly. The B737-9MAX will be challenged out of KEF and extremely challenged out of North American airports on hotter days. |
Quoting EC99 (Reply 33): These numbers seem basically correct. However, do you know how severe the weight restrictions actually are. Alaska Airlines flies BOS to SEA on a 737-900ER. This flight is slightly longer than BOS-REK and going westbound faces the same headwind as REK-BOS. If Alaska Airlines can do BOS-SEA on a 739, I dont see why FI couldn't do it to BOS-REK. |
Quoting eaa3 (Reply 37): |
Quoting DualQual (Reply 38): Again, what flap setting and bleed setting are you assuming? The airlines use sophisticated performance software that run through a multitude of calculations at differing settings to come up with a good mix. What might be a struggle at flaps 1 is better at flaps 15. Flaps 5 or 10 is a common setting. You can also go bleeds off and get more weight. |
Quoting eaa3 (Reply 39): |
Quoting flybynight (Reply 36): Where are the 763's coming from? |
Quoting hilram (Reply 35): On Boeing website it only lists 12 737 Max 8 & 9 with 12 options. Does anybody know the breakdown between the first 12? How many 8's and how many 9's ? |
Quoting prebennorholm (Reply 44): Their final replacement of 757 and 767 has likely not been invented yet. |
