Quoting tortugamon (Reply 1): Google: "Boeing Believes Demand Exists for New Midrange Jetliner" |
Quoting tortugamon (Reply 1): "Mr. Wojick said airlines want a jet that would be larger than the 757, with 234 to 253 seats and a flying range of 4,300 to 4,800 nautical miles. That would be at least 30% larger than its biggest 737, with about a third more range." |
Quoting LH707330 (Reply 2): We've also seen gems like "Boeing close to 15-frame 747-8 order." |
Quoting LH707330 (Reply 2): This design looks to be right in the middle of the "Bermuda box." |
Quoting EA CO AS (Reply 3): Build it, and AS will be among the first in line. |
Quoting LH707330 (Reply 2): I could see FI picking up a fleet |
Quoting tortugamon (Reply 4): I don't think AS, currently, need the range |
Quoting tortugamon (Reply 6): Why do you think they would need the capacity/range? |
Quoting Aesma: Airlines can buy the A321, what Boeing says or doesn't say can't change that fact. |
Quoting scbriml: Boeing can't do anything more with the 737. The -9 is the be-all and end-all of the 737. 'MOM' is a larger narrowbody than the -9 and will have to be an all-new plane. The bill will be a minimum of $10billion and probably closer to $15billion. |
Quoting astuteman: There's no reason why Airbus can't respond in a substantially shorter timescale at lower cost with an ENEO (even newer engine option) A32X, using the same engine technology, perhaps with a newer CFRP wing with greater fuel capacity. |
Quoting Aesma: So Boeing will keep 737 (707 really) commonality forever ? Why ? |
Quoting SQ22 (Reply 8): I think this is just the usual marketing bla bla to remain in the media, a-net and to keep the fanboys happy. |
Quoting dare100em (Reply 11): Furthermore this isn't about a NB in the size of the 737/A320. It may be a NB, but even than with a diameter of 4,2m. |
Quoting CALTECH (Reply 10): Southwest, Ryanair ? |
Quoting EA CO AS (Reply 7): 4800nm range from SEA gives you all of Japan plus most of Continental Europe. |
Quoting EA CO AS (Reply 7): AS is done with an eye on the future as there's always an expectation of a 20 year timeline |
Quoting dare100em (Reply 11): It's about all the cap between A321 and A330-800/787-8. |
Quoting DocLightning (Reply 16): So if they still want the 100-150 seat market, they need a separate model with a lighter platform. And they can build a good one. Alternatively, they can cede that market to Embraer, Bombardier, and Mitsubishi. |
Quoting DocLightning (Reply 16): If Boeing wants to build a new aircraft that ranges from 150-220 seats, that's quite doable, but it will become very inefficient if it's any smaller than 150. So if they still want the 100-150 seat market, they need a separate model with a lighter platform. And they can build a good one. |
Quoting btblue (Reply 18): I have no idea about the 717 tooling etc - delta seem to love them, it fits the seat gap, the engineering intelligence known - possibly a product for positioning in this area? |
Quoting SQ22 (Reply 12): That would be a lot of useless space, I am not saying it won't have a bigger diameter, but this would be wasted space and wasted space does not earn money. |
Quoting CALTECH (Reply 10): A.net lesson, Boeing 737 Max with smaller engine then the A-320 is bad, A-321 with smaller engine then the Boeing 757, good. |
Quoting tortugamon (Reply 4): I will state this: in order for this aircraft to work it needs to be able to go from JFK-LAX at a similar cost to a 737max or A320neo: |
Quoting seahawk (Reply 19): 4300-4800nm and around 240 seats, we call it the A321LR. A full new airplane, that the competition could counter with a new wing or even less effort. Not going to work. |
Quoting btblue (Reply 18): I think Boeing cannot ignore this market |
Quoting seahawk (Reply 19): 4300-4800nm and around 240 seats, we call it the A321LR. |
Quoting cougar15 (Reply 21): 2-3-2 would be a nice way to travel , but it will never happen |
Quoting par13del (Reply 23): what Airbus can do with the A321 is not relevant. |
Quoting tortugamon (Reply 4): |
Quoting tortugamon (Reply 27): I think Boeing needs to be mindful of what Airbus can do to compete with a new Boeing design. |
Quoting tortugamon (Reply 27): If Boeing spends $10 billion for a product |
Quoting kanban (Reply 28): People are making it between the target points today without any problem.. |
Quoting kanban (Reply 28): So what would help is some potential passenger numbers and frequencies. |
Quoting par13del (Reply 29): neither OEM will come up with a frame that the other cannot put up a competitive product, they will just offset each other on some parameters of the respective missions. |
Quoting Aircellist (Reply 30): I guess we are talking about nautical miles here) and kind of the general capacities of the A300-600R or the A310-300? |
Quoting Aircellist (Reply 30): Am I the only one to see a resemblance between the stated description of the plane (220-280 pax, 4k-5k Nm, well, I guess we are talking about nautical miles here) and kind of the general capacities of the A300-600R or the A310-300? |
Quoting astuteman (Reply 22): I get the bitterness to be honest, but there are some realities underlying these comments ... |
Quoting astuteman (Reply 22): So apologies if this adds to the bitterness, but the A320NEO actually has a BIGGER engine than the 757, and by a fair margin too. |
Quoting astuteman (Reply 22): As far as the A321NO vs the 757, the RB211 - 535E4B that produces 43 000lb thrust on the 757 has a fan diameter of 74.1" http://en.wikipedia.org/wiki/Rolls-Royce_RB211#RB211-535_series_2 The P+W GTF that produces 35 000lb on the A321NEO has a fan diameter of 81". So apologies if this adds to the bitterness, but the A320NEO actually has a BIGGER engine than the 757, and by a fair margin too. |
Quoting tortugamon (Reply 32): |
Thanks very much for this really interesting chart. A picture says a thousand words!! I've started re-reading from the beginning of the original post, just wanting to try and understand the various implications of designing a single aisle aircraft with ~5000nm range and ~240 passengers in two classes. To a complete (but curious) layman, this is fascinating stuff... ![]() |
Quoting CALTECH (Reply 34): Bigger fan with less thrust / more drag, thanks for proving the bitterness point. Horrid design. |
Quoting DocLightning (Reply 16): Alternatively, they can cede that market to Embraer, Bombardier, and Mitsubishi. |
Quoting seahawk (Reply 38): Yet once the size of the 737-8 is the shrink of your smallest model, you are leaving a lot of the market open for the competition. I can see both moving to something like around 170 - 200 - 240 seats with the single aisle versions. And that is the big problem of the MoM, the large version of the NSA will be a competitor. And I am certain that the large version will have more than 4000nm range. |
Quoting tortugamon (Reply 32): I don't think this market is big enough for two players. I think who ever moves first will capture a lot of the market. |
Quote: The A321neo weight variant with increased MTOW of 97 tons – often called A321LR or sometimes A321neoLR (LR = long-range) – transports 206 passengers in a 2-class layout with increased range to 4,000 nmi (7,400 km; 4,600 mi) by using three additional 2,990 L (790 US gal) fuel tanks.[47][48] An extended 2-class layout additionally including a premium economy class with 164 passengers allows a range of up to 4,100 nmi (7,600 km; 4,700 mi).[49][29] Historically this is the second MTOW increase after the initial A321-100 with 83 tons, which was quickly replaced by the -200 with 93.5 tons. In October 2014 Airbus started to offer it also as a replacement of the aging Boeing 757-200, also the latest variant with winglets, sometimes called 757-200W. Compared to the 757-200W, Airbus predicts an A321LR gives overall 25-30% lower operating cost depending on the number of seats[50][51] on routes where a widebody would be uneconomical. |
Quoting seahawk (Reply 38): Yet once the size of the 737-8 is the shrink of your smallest model, you are leaving a lot of the market open for the competition. |
Quoting seahawk (Reply 38): And that is the big problem of the MoM, the large version of the NSA will be a competitor. And I am certain that the large version will have more than 4000nm range. |
Quoting scbriml (Reply 42): However, if Boeing has MOMmy plane, then they could optimise NSA for shorter ranges. In that case, the largest NSA model needn't have 4,000mn range. NSA could be optimised for 3,000nm segments. If you need more range, then go for MOMmy. |
Quoting hilram (Reply 41): I do not buy the argument that widebodies can't be economical. I do not buy the argument that we need a 240 pax aircraft. I think the whole discussion is moot, based on spin started by Boeing because at the present, they are uncompetitive in this particular (niche) segment of the market |
Quoting scbriml (Reply 42): But look at the sales of neo and MAX - just a very small percentage are for the smallest models and, for Airbus at least, an ever growing proportion of sales are for the largest model in the family. If the new single-aisle families from Airbus & Boeing start at the A320/738 size, I don't see them losing out very much at all. |
Quoting GrahamR (Reply 36): Thanks very much for this really interesting chart. |
Quoting GrahamR (Reply 36): just wanting to try and understand the various implications of designing a single aisle aircraft with ~5000nm range and ~240 passengers in two classes. |
Quoting dare100em (Reply 39): If they go for a small TWIN things are a little different, yes. But I belive they won't do that and when they'll do it this plane will be even further away from any single aisle |
Quoting Revelation (Reply 40): A321LR is moving first in 2017, for the 4000 nm / 200 pax segment. I think they'll capture a lot of the market. |
Quoting dare100em (Reply 44): |
Quoting tortugamon (Reply 46): I think we often think that the market moves and the airplane models adjust - however, the opposite can happen as well. When they are producing these aircraft at 50+/month each their economies of scale result in an affordable aircraft (considering) and I think airlines chose the routes where they can operate those aircraft the most economically. Very few airlines have the ability to mold design and of course they chose the airplane that best fits their structure but it works the other way too. My point is that by the time the market grows and the -8 is the smallest model, the market for that -8 will be similarly tiny as the -7 market. |
Quoting tortugamon (Reply 46): I am personally of the belief that if it is a 5knm aircraft then it really can't be a standard single aisle aircraft. For that range I do believe the aircraft will have to be wider. Exactly how wide is up to smarter people than me. |
Quoting seahawk (Reply 47): Indeed but that means that NSA and MoM will be very close ins size. |
