Quoting StrandedAtMKG (Reply 2): This route didn't have a prayer, honestly. ACA/Independence flew LAN-IAD briefly a long time ago when they were trying to make it as an independent carrier, and Northwest ate their lunch. Now it's DL's turn to eat SY's lunch. |
Quoting DTW.SCE" class="quote" target="_blank">PSU.DTW.SCE (Reply 4): Not to mention, LAN gets squeezed on all sides by airports all with far superior air service - GRR, FNT, and DTW. |
Quoting FWAERJ (Reply 5): Speaking of G4, they left LAN twice, so I wouldn't bank on G4 being LAN's savior. The first time was when they moved to GRR, and the second (which ended this past January) showed G4 packing up as soon as the incentives dried up. A good reason in both cases: LAN's CPE is in the $32 range - one of the most expensive of any airport in America, big or small. DTW and FWA's CPE are both in the $8-10 range, and GRR is even cheaper at around $5. Unless you can charge a massive fare premium and maintain good yields, as seems to be what the case is with DL and UA, LAN is a money-losing proposition to airlines - especially if you are an LCC or ULCC. |
Quoting jetlanta (Reply 6): Where did you get those numbers from? I don't think they are accurate in real world terms. |
Quoting COMPENSATEME (Reply 7): From memory, LAN collects about $3M annually from airlines -- slightly higher than similar sized airports (but far from your numbers ) but that's because of the debt taken on to fund the FIS as well as the cost to staff it annually. |
Quoting UA444 (Reply 10): I used to live in Lansing and it's difficult to see it suffer. The air fares were completely ludicrous at the time and often found us driving to DTW. |
Quoting FWAERJ (Reply 8): It was some old data from a while back, so I looked at the FAA website to get a better, more recent picture. I checked the numbers for LAN and its rivals in 2014 from the FAA CATS site, and here they are from most to least expensive. LAN: $19.93 DTW: $10.06 GRR: $9.79 FWA: $7.08 FNT: $2.26 LAN may have gone down from that old study, but is still the most expensive in terms of CPE among its peers. LAN is 8.8x(!) more expensive to operate from than FNT, 2.8x that of FWA, 2x that of GRR, and 1.9x more than DTW. |
Quoting COMPENSATEME (Reply 12): A quick & dirty glance at FWA & LAN's financials concludes that both airports collect a similar amount of revenue from the airlines. In other words... LAN is as competitive for an airline to operate into as FWA. |
Quoting COMPENSATEME (Reply 12): FWA has a larger overall revenue stream -- primarily from the onsite maintenance facility and significantly larger tax collections from the locals |
Quoting FWAERJ (Reply 14): I don't see how it can be the case. This month, FWA has 22 weekday departures on legacies (all 50-seaters) plus 8-10 G4 flights (all A32x or MD-80) on average per week. LAN has a fraction of that: 10 50-seaters plus 1 73G per weekday. Simply put, FWA can get the same amount of revenue as LAN, even with a lower CPE, because many more passengers come into FWA. |
Quoting freakyrat (Reply 15): According to surveys and studies done on behalf of corporate aviation at SBN, the FIS when completed will see a lot of use. Also when the FIS was proposed an unnamed airline said that they were interested in offering service from SBN to the Bahamas. Might that be Sun Country? Before the arrival of Allegiant, Sun Country used to do lots of Vegas charters from SBN and now they do a monthly charter to Laughlin. I was just checking an old United timetable before deregulation and mostly all the Westbound DC6 and Viscount flights into SBN originated at DCA or Eastbound flights terminated at DCA. So I'm just curious if SBN-DCA would be profitable now for SY or any other carrier. |
Quoting sunking737 (Reply 16): LAN was a step into DC, but SY also had charter flights out of LAN to Fla, and Mexico. The charter contract was not renewed so it made sense to end all service in LAN. |
Quoting JetBlueGuy2006 (Thread starter): A 737 is a large plane to fill on a daily basis. |
Quoting flyinryan99 (Reply 19): Great...so the Air-21 slot can go to Southwest to serve an underserved market in DCA-SRQ or something ridiculous. If I were medium sized markets that already have AA and don't have access to DCA, would be trying to think of something out of the box and gear up the political power to obtain this slot. |
Quoting COMPENSATEME (Reply 20): At least people would fly DCA-SRQ... |
Quoting flyinryan99 (Reply 21): People are flying LAN-DCA. Just not enough to justify a 737 |
Quoting flyinryan99 (Reply 21): People are flying LAN-DCA. Just not enough to justify a 737. |
Quoting msp747 (Reply 23): So does SY have to give the slot up? Or can they use it to add another DCA-MSP flight? |
Quoting iflycanadian (Reply 25): Can someone please explain: What does CPE mean? |
Quoting FWAERJ (Reply 26): Cost per enplanement. It's the average cost for an airline of using an airport on a per-passenger basis based on an airport's projected volume for a year, barring any incentives or subsidies. |
Quoting JetBlueGuy2006 (Reply 24): I don't believe they can, I believe it is a slot specifically for smaller communities...so they will either find another airport to route through or have to return it. |
Quoting flyinryan99 (Reply 19): Great...so the Air-21 slot can go to Southwest to serve an underserved market in DCA-SRQ or something ridiculous. |
Quoting flyinryan99 (Reply 21): If people would fly DCA-SRQ, why isn't it flown now? |
Quoting flyinryan99 (Reply 19): If I were medium sized markets that already have AA and don't have access to DCA, |
Quoting FlyPNS1 (Reply 28): The more interesting question is to see who picks up the slot....WN, B6 or AA are the most likely candidates. |
Quoting crazytoaster (Reply 31): So if it goes to bid, is it only for the specific route (DCA-LAN)? Or any small community. |
Quoting FlyPNS1 (Reply 33): |
Quoting sdoyon (Reply 32): |
Quoting sdoyon (Reply 32): WN bid for DCA-OKC |
Quoting flyiguy (Reply 38): I'm pretty sure this is the slot that WN is already going to use to operate DCA-MCO making it 45 daily flights for WN from DCA. |
Quoting ridgid727 (Reply 37): The DOT would favor any airline like Virgin America, Hawaiian, Alaska, |
Quoting COMPENSATEME (Reply 12): The problem is the way CPE is being used (calculated) here. A quick & dirty glance at FWA & LAN's financials concludes that both airports collect a similar amount of revenue from the airlines. In other words... LAN is as competitive for an airline to operate into as FWA. FWA has a larger overall revenue stream -- primarily from the onsite maintenance facility and significantly larger tax collections from the locals -- but this isn't being used to reduce the airlines' operating costs. And at the end of the day... that's all they care about. |
Quoting billreid (Reply 41): If you look at the data you will find that the CPE is the funds collected from the airlines divided by the passengers enplaned.Under your premise that a similar amount collected. Revenues from other sources reduce CPE through having other sources of income. This is the advantage of building a more diverse business model.LAN is an airport that has very high cost per enplanement. It is comparative to EWR, MIA, JFK for costs with a highly different demand basis. LAN is not a critical destination whereas NYC is, MIA is.If LAN wanted to be competitive it would need to reduce its costs by $10 per passenger. At the end of the day why would airlines be interested in paying an extra $10 per passenger when they do not have to at nearby airports?The position of LAN is the same idiotic argument used by MLB and SRQ in Florida. SRQ has a CPE of $12.34 while PIE has a CPE of $1.93 and TPA has a CPE of just over $5.00. What does an airline get for the extra $10? |
Quoting FlyPNS1 (Reply 30): I'm not sure there exists any medium markets (within the perimeter) that don't already have access to DCA, so there's really no fight there. At this point, the only markets (again within the perimeter) that don't have DCA access are all qualified as small. |
Quoting flyinryan99 (Reply 43): You still have markets like GRR or FWA or AZO or FNT that doesn't have access to DCA that *theoretically* could qualify for this slot. |
Quoting COMPENSATEME (Reply 42): Smaller airports traditionally have higher CPE, since there's fewer passengers to spread costs amongst. But smaller airports also typically have higher average airfares, which offset the slightly higher per-passenger CPE. Take it into context: if Allegiant had been successful at LAN, LAN would have a lower overall CPE, but DL & UA's CPE wouldn't be much lower -- Allegiant's would be bringing the average down, but it would also have significantly lower per passenger revenues. You need to take CPE into context. |
Quoting billreid (Reply 45): Quoting COMPENSATEME (Reply 42): Smaller airports traditionally have higher CPE Where in heavens name do you get your numbers? |
Quoting billreid (Reply 45): Where in heavens name do you get your numbers? The smaller airports traditionally have a much lower CPE. The reason is the airlines DON'T have to serve those markets. Smaller airports HAVE to be competitive. Airports like PGD doesn't charge either a landing or terminal fee. So where does that leave LAN? NYC has the three highest costing airports in the USA. MIA is right at the Top. LAX is way up there, SFO is up there. ATL, and DFW are low. $19 is a joke and the reason airline service is so dreadful! |
Quoting mariner (Reply 39): How did Southwest get the LAN-DCA slots from Sun Country? It's my understanding that these particular slots can't be bought or sold - although they can be acquired by merger, as Republic showed, and took the DOT to court to establish that. I thought they had to go back up for bid, and that they were limited to smaller cities. I could be wrong, but that's how it used to be. mariner |
