City Of DAL Asks Feds What To Do About DL (by ridgid727 Jun 17 2015 in Civil Aviation)
Enjoy the hot summer
Ben Soriano
Quoting cjpark (Reply 220): My original post said to go back to the original gate allotment of the compromise. 16-2-2. There is is a reason why the 20 gate limit was installed in the compromise. DAL cannot expand, the roads and access to the airport cannot handle additional ground traffic without severe degradation to the surrounding area. Adding more gates to the airport would undoubtedly create more noise pollution for the area and the increase in airline traffic would hamper general aviation operations at the airport. |
Quoting par13del (Reply 2): Except DAL already had the roads and other infrastructure in place in recent times for 32 gates, yes they are tearing down the legend terminal and building additional parking, why, do they expect additional traffic as a result of WA2? The intent is to continue to preserve DFW, what is wrong with stating that, using roads which already exist, plans for increase traffic which also impacts GA does not assist the argument of restraining DAL. |
Quoting sccutler (Reply 5): I have a hard time imagining a ruling which would, in any material way, alter the current legislation; great deference is given to the legislative process. Long term, I see (and predict) a ruling pretty much maintaining the status quo, which leads to Delta's exit being delayed, but inevitable. |
Quoting northwestEWR (Reply 7): If that happens--the Federal court is essentially saying that WN is allowed to have a near monopoly. That sets a dangerous precedent for other airports in the country with the DOT/DOJ. |
Quoting cjpark (Reply 4): The reasoning for the reduction was based on environmental factors. |
Quoting cjpark (Reply 4): The number of gates was decided and insisted upon by the City of Dallas to protect the area around the airport. |
Quoting cjpark (Reply 4): Because it is not true. The number of gates was decided and insisted upon by the City of Dallas to protect the area around the airport. |
Quoting Cubsrule (Reply 10): Is that pretextual, though? The area around MDW is even denser, and MDW has 43 gates. |
Quoting par13del (Reply 12): Honestly, I am hoping that since the local authorities abdicated their responsibilities, the courts will make a ruling to settle the situation once and for all, since the current situation is not tenable. We are presently dealing with 4 operating carriers which does not include B6 or NK, if either of them request access the merry go round will start again. |
Quoting alfa164 (Reply 14): When a Judge schedules a conference call with all parties, and one of those parties does a 180-degree about face after the call, I would suspect there was at least some hint that the Court's decision might not go their way. When WN decided that DL should be allowed to stay - at least in the interim - I would not discount the possibility that they saw some handwriting on the wall. Depending on whose side you take (and I am in the fortunate position of having no dog in this fight), it was either a magnanimous gesture on the part of WN, or capitulation to what they saw was inevitable. Only time will give us the full answer, but - like I said - I do read it as a hint of the route the Court was taking. |
Quoting alfa164 (Reply 14): Only time will give us the full answer, but - like I said - I do read it as a hint of the route the Court was taking. |
Quoting usflyguy (Reply 15): or DL decided that they would pay whatever it was that WN was asking to rent a portion of a gate because the judge indicated the result would be something they didn't like... |
Quoting polot (Reply 16): I suspect WN got a hint that they would be ordered to continue accommodating DL until the whole case is settled and final decision made. In that situation it's better to make the move first from a PR standpoint, as DL would tout the court order as a minor victory even if it is just one battle in the whole war. |
Quoting alfa164 (Reply 14): When a Judge schedules a conference call with all parties, and one of those parties does a 180-degree about face after the call, I would suspect there was at least some hint that the Court's decision might not go their way. When WN decided that DL should be allowed to stay - at least in the interim - I would not discount the possibility that they saw some handwriting on the wall. |
Quoting cjpark (Reply 18): They say money talks and it obviously talked very loud to the City of Dallas during the compromise negotiations and now you have a 20 gate limit at the airport. |
Quoting cjpark (Reply 18): Is Midway bordered on one side by the wealthiest area of Chicago? Love Field is bordered by the Park Cities, and Highland Park on the east side. Lots of wealth concentrated in those areas. They say money talks and it obviously talked very loud to the City of Dallas during the compromise negotiations and now you have a 20 gate limit at the airport. |
Quoting justplanenutz (Reply 21): But Jerry Jones, etal (HP/UP residents) don't pay taxes or vote in Dallas, so do they really have much sway over the City? And doesn't The Bubble keep noise out anyway? |
Quoting justplanenutz (Reply 13): Looks like WN is still planning to expand its schedule while also accommodating the 5 DL flights: http://aviationblog.dallasnews.com/2...erative-at-dallas-love-field.html/ In other words, they have agreed to put 10 lbs. of s*&t in a 5 lb. bag. That should be interesting. |
Quoting CO777DAL (Reply 23): Also once last year when I was there a UA ERJ-145 was broke at gate 17. The had the engine cover opened up and everything. Back then UA was letting WN use gate 15. That day WN couldn't use gate 15 because UA was using it all day as gate 17 had a broke plane sitting there. Granted UA only had two gates and WN has 17 others now to use. But at the end of the day DL was at the mercy of UA and will be with WN as WN now has preferential use of the gates. |
Quoting jetblue1965 (Reply 24): Why can't they be creative and say : "okay, DL you can operate flights, but must be all remote tarmac parked, and all be bussed in" |
Quoting polot (Reply 25): Quoting jetblue1965 (Reply 24): Why can't they be creative and say : "okay, DL you can operate flights, but must be all remote tarmac parked, and all be bussed in" Because that is forbidden by the agreement. They must use a gate, it is very specific. |
Quoting CO777DAL (Reply 23): WN has preferential use of the gates, meaning if WN has IRROPS or something is wrong and a WN plane is at the gate, DL will have to wait till the gate is free. |
Quoting jetblue1965 (Reply 27): That's the agreement. Since it's now in the courts, they can probably make any unpredictable ruling they want that's completely different from what WA2 said. |
Quoting sccutler (Reply 20): Piss on 'em; Dallas is Dallas, Highland Park is Highland Park; they have no say. |
Quoting Cubsrule (Reply 22): And if it is "money talking," then it's NIMBYism talking, not legitimate environmental concerns. |
Quoting cjpark (Reply 30): Just so you know local taxes are not used to support the airport. And yes HP/UP have lots of sway in this city and region. |
Quoting cjpark (Reply 30): Just so you know local taxes are not used to support the airport. |
Quoting cjpark (Reply 30): And yes HP/UP have lots of sway in this city and region. |
Quoting justplanenutz (Reply 32): Did I say they were? |
Quoting justplanenutz (Reply 32): qSo what part of Dallas did JJ build his stadium, his influence with Laura Miller being so large? |
Quoting cjpark (Reply 33): Please re-read your reply 21. |
Quoting cjpark (Reply 33): Just like the gate cap, Laura Miller made the correct call on the stadium question. |
Quoting justplanenutz (Reply 34): Umm, maybe you should. I said HP/UP didn't pay any taxes to the City of Dallas, much less support DAL through taxes. |
Quoting alfa164 (Reply 35): Indeed, it is the proximity to to the upscale HP/UP/North Dallas area that makes flights from Love so desirable. |
Quoting JBo (Reply 37): Dear Mods: I cannot stop giggling at the typo on the thread title. "You said do-do!" Sincerely, My inner 12-year-old |
Quoting cjpark (Reply 30): Quoting sccutler (Reply 20): Piss on 'em; Dallas is Dallas, Highland Park is Highland Park; they have no say. Is that sarcasm? |
Quoting sccutler (Reply 40): Without Dallas, there is no Highland Park or University Park. All that pissin' and moanin' gets old, and you can count the number of residents who were alive when Love Field was built on .... oh, wait; there are none. |
Quoting adipasquale (Reply 1): it really seems that more gates are the only true solution to the problem |
Quoting adipasquale (Reply 1): This whole situation just shows that the Wright amendment is still haunting DAL almost a decade after it has been repealed. If there were still 32 gates we wouldn't have this massive conundrum. IMHO the Wright amendment was one of the worst pieces of legislation ever passed. |
Quoting william (Reply 44): I hope WA gets thrown out just to see the chaos it will cause. Tell Delta there is no gate limit and we will have a new Delta hub as soon as construction permits. Doubt me? This is going to be fun to watch. |
Quoting Sooner787 (Reply 45): DFW is fixin' to start construction of another Terminal building with 35 or so gates. I'd love to see DL come back to DFW and crank up the hub like they had going in the 80's and 90's. There will be plenty of gates to go around |
Quoting Raventech (Reply 3): There is really three ways I see the court ruling |
Quoting Sooner787 (Reply 45): I'd love to see DL come back to DFW and crank up the hub like they had going in the 80's and 90's |
Quoting AST1Driver (Reply 47): Unfortunately, this will never happen. Delta has a very long history with Dallas dating back to 1929, with DAL being its western most airport for most of those years. My personal opinion is that Dallas will never be more than a focus city. And if Delta had been given the gate space at DAL that if originally wanted, I could see DFW operations shrinking even more or ending entirely. |
Quoting northwestEWR (Reply 48): Quoting AST1Driver (Reply 47): Unfortunately, this will never happen. Delta has a very long history with Dallas dating back to 1929, with DAL being its western most airport for most of those years. My personal opinion is that Dallas will never be more than a focus city. And if Delta had been given the gate space at DAL that if originally wanted, I could see DFW operations shrinking even more or ending entirely. The market is large enough for Delta to maintain a presence at DFW and DAL--if WA is repealed, expect to see DL add the flights they originally wanted out of DAL--IIRC it was LAX, DTW, LGA, MSP, SEA. |
