Quoting wnflyguy (Thread starter): appeal to wall street |
Quoting wnflyguy (Thread starter): Odd rumor is FNT,DAY,DSM and CAK are being shutdown and resources shifting to adding CVG. But I highly doubt this is even a plan |
Quoting RL757PVD (Reply 2): hooray for short sighted, short term gains! Lets restrict demand/capacity, and fatten the bottom line so that new LCC entrants can come in and trash them! |
Quoting jbmitt (Reply 3): I hate that rumor.. being based in CVG, moving to DSM shortly, and having flown WN a number of times from DAY/CMH and DSM. |
Quoting wnflyguy (Thread starter): Odd rumor is FNT,DAY,DSM and CAK are being shutdown and resources shifting to adding CVG. But I highly doubt this is even a plan. |
Quoting enilria (Reply 4): CAK-ATL was good, but has been dying since they debanked ATL. |
Quoting rtalk25 (Reply 5): I thought ATL is still banked. It's possible to do PHL-ATL-CAK, RIC-ATL-PIT etc. |
Quoting enilria (Reply 6): You can still connect, but the flights aren't timed for it. |
Quoting rtalk25 (Reply 8): Quoting enilria (Reply 6): You can still connect, but the flights aren't timed for it. I remember reading a thread not too long ago, from knope2001, where he did an analysis, and concluded banking activity was still present. But perhaps the schedule has changed even more since the period used in that analysis. |
Quoting wnflyguy (Reply 9): For myself I don't think or see any major cuts coming to the network. |
Quoting wnflyguy (Reply 9): I would not be shocked at all to see a small market/city cut. |
Quoting usflyguy (Reply 11): Quoting wnflyguy (Reply 9): I would not be shocked at all to see a small market/city cut. It's only a matter of time for CRP. |
Quoting enilria (Reply 10): So it is still banked to my surprise, but it is much less effective than in the past...thus the diminished performance. |
Quoting rtalk25 (Reply 14): I just wonder if CAK-ATL might be a casaulty in this next schedule release as the connect in ATL faring from CAK also seems more off than in the past |
Quoting rtalk25 (Reply 14): Atleast CLE is up the road and many connects via BWI/MDW/DEN are possible from there. |
Quoting rtalk25 (Reply 14): Could WN make a daily RIC-DEN |
Quoting rtalk25 (Reply 14): RIC-LAS work for better west-bound? |
Quoting enilria (Reply 4): ROC-BWI looks good, but the rest is junk |
Quoting ryanrap1 (Reply 12): Are the CRP loads that low? |
Quoting enilria (Reply 13): |
Quoting AWACSooner (Reply 18): Maybe it's my naivete, but there should be zero reason why cities like DSM and RIC should be failing cities for WN. DAY is understandable due to proximity to CMH and IND...but somehow AirTran made it work just fine before the merger. |
Quoting AWACSooner (Reply 18): Second, I personally think, due to the deviation mentioned above, in most cases, it's WN's fault for pulling out of these cities or drastically reducing their services when they didn't provide because of their limited flights. |
Quoting DCA-ROCguy (Reply 16): If they got back to something closer to what they used to be, many of the markets in discussion here would probably be well above water. |
Quoting AWACSooner (Reply 18): First of all, I don't get why WN decided to deviate from their decades-long strategy of "we won't start em unless we think they can sustain 10 daily flights." |
Quoting AWACSooner (Reply 18): Maybe it's my naivete, but there should be zero reason why cities like DSM and RIC should be failing cities for WN. |
Quoting ROCDLFAN (Reply 17): Quoting enilria (Reply 4): ROC-BWI looks good, but the rest is junk Are you kidding? WN has a total monopoly over MCO and TPA in ROC. |
Quoting enilria (Reply 21): |
Quoting ROCDLFAN (Reply 22): According to BTS, ROC-MCO carried aprox. 49,000 passengers between APR 2014 and MAR 2015. That adverages out to aprox. 134 pax per day. With an aircraft capacity of 143, that's a 93.7% L/F. Albeit not 100%, but I would hardly call that Sub Par. |
Quoting sdoyon (Reply 25): |
Quoting enilria (Reply 4): There are other crappy markets like GRR. |
Quoting AWACSooner (Reply 29): AMA, etc. would've been dropped by Herb a long time ago |
Quoting rdh3e (Reply 30): AMA existed as a Wright Amendment stop, no more WA no more AMA. |
Quoting rtalk25 (Reply 14): If ATL becomes more debanked, RIC is going to need MDW flight service |
Quoting sdoyon (Reply 25): If there's one thing I've learned on a.net, it's that LF doesn't tell the whole story. It may go out 94% full, but what if they're only paying $59? $79? $99? It's more complicated than just LF. |
Quoting ROCDLFAN (Reply 27): My argument for WN as a whole however would be that they have been posting record numbers overall at ROC since service first began. (as far as the first 3 months posted) |
Quoting rtalk25 (Reply 26): If WN dropped ROC-MCO/TPA, probably B6 would add it. It's in New York state and B6 wants to stand behind being New York's Hometown Airline. |
Quoting rdh3e (Reply 24): They flew more than daily. Average for the year was 1.1 deps/day, so the load factor was actually about 83%. |
Quoting glbltrvlr (Reply 28): GRR wouldn't be crappy if SWA was still following their original model of pricing to build a market, and if they offered more balanced routes to the west. |
Quoting mfe777 (Reply 32): What about HRL (Harlingen)? |
Quoting enilria (Reply 4): DSM-LAS looks awful. DSM-MDW looks similar to DAY-BWI. Close to profitable, but slightly under. |
Quoting dbo861 (Reply 38): Quoting enilria (Reply 4): DSM-LAS looks awful. DSM-MDW looks similar to DAY-BWI. Close to profitable, but slightly under. I don't know if this means much, but WN has upgauged DSM-LAS to a 738 this fall. Then back to a 73G in November. If the route is so awful, why would they put a larger aircraft on it? |
Quoting dbo861 (Reply 38): I don't know if this means much, but WN has upgauged DSM-LAS to a 738 this fall. Then back to a 73G in November. If the route is so awful, why would they put a larger aircraft on it? |
Quoting infiniti329 (Reply 33): the 737 is too big for alot of the smaller markets currently left unserved. I know alot of people don't like to except this but if WN wants to dominate these smaller markets they need a smaller aircraft that with built in effencies. with a smaller aircraft I think some of these routes can be done profitably...as long as they are priced right. |
Quoting crazytoaster (Reply 43): From the route map I don't see any new destinations but from my home airport IND-MDW has been added after 1/06/2016 at 2x weekly |
Quoting ROCDLFAN (Reply 39): Upgrading doesn't mean much. |
Quoting kcrwflyer (Reply 41): Sometimes you get what's at the gate. It's not a perfect system. |
Quoting kcrwflyer (Reply 41): Accept. A smaller plane isn't always the answer. If they're willing to happily serve cities whose peak potential is 4-6 flights per day, I think they're just fine with the 737 for a while. Smaller planes have higher costs per seats, generally, so bringing in a smaller plane doesn't do much for the equation in some cases. |
Quoting Joeljack (Reply 40): enilria, can you post the data on why DSM-LAS is so bad? Just curios? I'd look it up myself but no easy access this week, out of town. |
Quoting enilria (Reply 46): That resulted in a low prorated average fare of $153. For a distance of 1216 miles that is very low. |
Quoting enilria (Reply 46): For 2014 the LF was fine at 92%, but it was only 47% local which is very low for LAS. That resulted in a low prorated average fare of $153. For a distance of 1216 miles that is very low. Also, keep in mind for WN that is nearly all the revenue as there is no bag fee revenue. |
