727tiger
MCI Study Group Recommends Single Terminal
Wed Jul 22, 2015 12:42 pm
A year-long study group of airline representatives, MCI representatives and a consultant for the City of Kansas City aviation department has recommended a new single terminal to replace MCI's existing terminal, citing -- among other reasons -- the believed less expensive nature of building new v. renovating current terminals:
http://www.kansascity.com/news/local/article28037629.html
I grew up first with MKC then MCI, and I loved the unique design of MCI's terminals. But, that was a different age. I'm ready to move on to a new, single modern terminal.
RJNUT
RE: MCI Study Group Recommends Single Terminal
Wed Jul 22, 2015 1:19 pm
as a member of my high school marching band , we played at the inauguration of KCI in OCT.72.. Yes i too am ready to move on.. Heck I still have my fondest memories of old Municpal airport downtown!
KFLLCFII
Wed Jul 22, 2015 1:33 pm
Interesting how (arguably) the very best terminal design for O&D passenger convenience before the screening era could become the very worst for both O&D and connecting passengers with gateside screening halls.
What I don't understand, though, is that if the existing terminal structures already "begin" and "end" roughly around the circumference of a broad circle (Bonn Circle & International Circle within), and generally function sufficiently if not for the security aspect, then why not simply build a central processing/screening center within the circle and connect the three terminals as sterile, airside concourses?
Would something like this not be as cost-effective as building an entire landside-airside complex from the ground up?
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
GSPSPOT
Wed Jul 22, 2015 1:50 pm
Or, if it can be determined that the capacity that all 3 rings provides is not needed, could building a central terminal with security checkpoints between two of the existing rings work? Then, the interiors of those ring terminals could be opened up as true concourses, much closer to what DFW has, as ticketing/baggage claim/security would all be in the central terminal at that point.
Great Lakes, great life.
KFLLCFII
Wed Jul 22, 2015 2:12 pm
Quoting GSPSPOT (Reply 3):
Exactly. Tampa, Orlando...
washingtonflyer
Wed Jul 22, 2015 2:15 pm
How many gates are actually used at MCI these days?
LOWS
Wed Jul 22, 2015 2:45 pm
Quoting KFLLCFII (Reply 2):
Probably not, because they would still need to heat and cool a lot of unused space. Also, you'd have to build and operate a people mover system, as the terminals are pretty big (I like a long walk, but most people in an airport don't). Not to mention, the rings are old and very narrow.
Finally, what would happen to the parking garages in the center of each ring?
enilria
Wed Jul 22, 2015 3:53 pm
I think they should have 7 terminals in different corners of the airfield that are separated by moats with alligators and if an airline can't fit all their operations in one of them then they should spread out over several of them. There should also be an Arby's the least accessible terminal and only a Waldenbooks at the others.
TVNWZ
Wed Jul 22, 2015 4:03 pm
MCI never really panned out the way it was planned. It's time has come and gone and the city really needs to start with a clean sheet of paper and design a much smaller and efficient airport. It was a nice try and the time, but now its time to acknowledge that times are different and move on.
res77W
Wed Jul 22, 2015 6:09 pm
Quoting washingtonflyer (Reply 5):
I'm MCI based. Not many. There are peak times of the day, but often times many gates sit vacant, excluding Terminal A which was shut down a couple years ago I believe.
Byrdluvs747
Wed Jul 22, 2015 6:17 pm
Quoting TVNWZ (Reply 8):
Yes, there comes a time when dynamite and bulldozers are an airports best friend.
Not sure of the exact count, but Terminal A isn't used. This low gate utilization would actually make it easier to plan a clean sheet design.
Quoting enilria (Reply 7):
Isnt that the design MCO went with
construction at the airport will not be paid for with taxes. Bonds issued for a project will be repaid with airline fees and concessions at the airport.
And eventually, Kansas City residents will have a vote on any major airport improvements.
If taxpayers are not footing the bill, why should they have any say on its contruction?
[Edited 2015-07-22 11:24:45]
The 747: The hands who designed it were guided by god.
ScottB
Wed Jul 22, 2015 8:53 pm
There are several key problems with that idea. First is that a landside complex that large would be nearly as expensive as a new terminal and require some very long walks to the farther gates in the rings. It also wouldn't solve the two most valid problems with the terminal design -- the terminals will require some renovation and maintenance on the aging terminal buildings is getting more expensive. There would likely be higher operating costs given larger areas to heat/cool/clean/police. And it would likely be very challenging to phase construction while keeping the existing terminals open.
The potential candidates for renovation & new terminal designs can be seen here: http://data.kcmo.org/Airport/KCI-Pre...15-To-KCMO-City-Council-/s2c7-qczd
Quoting 727tiger (Thread starter):
It looks like the "renovation" plans included some significant construction on their own -- either a new central terminal structure between two of the rings or central structures for ticketing/baggage/security filling in part of the rings, which would also require the parking garages to be replaced.
Given that the proposed "renovation" wasn't going to just be updating the existing structures (as was done around 10 years ago), it's not surprising that the new terminal alternatives are now the cheapest. But it's still going to be important to keep costs under control.
TVNWZ
Wed Jul 22, 2015 9:11 pm
Quoting Byrdluvs747 (Reply 10):
Because taxpayers always foot the bill. It's just the way they foot it. Not to mention the taxpayers own the thing.
christao17
Thu Jul 23, 2015 10:44 am
As a former resident and long-time visitor (since before MCI opened, in fact), I vote for a single terminal.
The convenient horseshoe design became less convenient shortly after the airport opened in 1972 once security screening was added at gates.
It became tremendously inconvenient in the aftermath of 9-11 and even with remodeling combining several gates into a single holding area, facilities are limited and the overall design does not serve passengers effectively.
And then there is the cost issue. If a new terminal is more cost effective, let's do it.
tb727
Thu Jul 23, 2015 12:20 pm
In the presentation it says 29 are currently leased, 35 gates are needed in 2030.
I like Major Renovation Concept B myself.
MCI is my favorite overnight at the moment believe it or not.
knope2001
Thu Jul 23, 2015 1:17 pm
Quoting tb727 (Reply 14):
Although the current KCI terminals are numbered for 90 gates I think each of the three terminals can reasonably park up to 20 mainline aircraft. I believe there are about 50 jetways on the three terminals (some unused gates which could have jetways currently do not). If the projection of needing 35 gates by 2030 is accurate, the current terminal would still have about 25 surplus gates, about 15 of which currently have jetways.
As reference, KCI has roughly150 daily departures, 2/3 of which are mainline. (That excludes the handful of SeaPort flights which use the FBO.)
sw733
Thu Jul 23, 2015 1:46 pm
As an MCI-based frequent flyer, I am curious...why?
tb727
Thu Jul 23, 2015 2:29 pm
Quoting sw733 (Reply 16):
We stay downtown, most downtowns we stay in kinda suck but KC is pretty cool. Good restaurants and stuff to do.
kstateinALB
Thu Jul 23, 2015 9:45 pm
I feel like I'm one of a few that actually likes MCI's terminal!
I completely understand people's qualms over the airport. In all honesty, MCI is a blessing and a curse. A blessing, meaning you can get from curb to gate in ten minutes, maybe even less that (which saved me a few times). A curse, if you're trying to eat/not wait in line for the bathroom/find a seat near your gate.
MCI was my home airport for six years. I always appreciated that I could get from economy parking to my gate in 15 minutes. But yes, the curses outweigh the blessings. Something with more amenities for passengers is much needed. Whether it be a renovation or a completely new building, it'll be nice to see one day.
ALB, DTW, ORD, MDW, MCI, JFK, LGA, LHR, MAD, MSP, IAD, DCA, MCO, ATL, CVG, TUL, MHK, PHL, PIT, DFW, DAL, CLT, IND, AUS,
afcjets
Thu Jul 23, 2015 10:44 pm
Quoting ScottB (Reply 11):
First of all the central terminal area would not need to be that large and most importantly while you would no longer be able to drive up to your gate, the walks would be very short by the way the terminals are designed. Look at the pic above, any point in the blue region to any gate on one of the semi-circles is a very short walk, and obviously an airlines ticket counter would be located in relation to their gates.
The thing that really blows my mind about this article is that it says it will need 6 more gates in 15 years, and it says it will be easy to build a new terminal where terminal A is now which is not being used. Um, why not use terminal A then, wouldn't that give you six new gates and then some? Or am I missing something here?
[Edited 2015-07-23 15:48:58]
stburke
Thu Jul 23, 2015 10:52 pm
Quoting afcjets (Reply 19):
The need for additional new gates may be marginal but the need for a new modern facility is pretty huge - and ultimately what's driving all this. Outdated, cumbersome facilities being replaced by a single "right sized" efficient terminal is what the city needs.
Or a return to the downtown airport
N1120A
Thu Jul 23, 2015 10:58 pm
The issue isn't the screening era, it is the TSA era, where non-ticketed persons can't go through security.
That would likely cost a fortune, and actually take more space. Some sort of train system would likely have to be used. Basically, this is something similar to what LAS does.
afcjets
Thu Jul 23, 2015 11:10 pm
Quoting N1120A (Reply 21):
There is no reason a tiny airport with 35 gates which is not even a hub (barring WN but it is probably their smallest of approximately 15 mostly redundant hubs) would need a train or people mover system. Also the semicircular design of the concourses means a short walk to each gate even from a central terminal area. The concourses/terminals are right on top of each other too, not spread out like at TPA.
tb727
Thu Jul 23, 2015 11:58 pm
Quoting stburke (Reply 20):
Now there is an idea, that's a fun airport to land at! Shorter van ride to the hotel too.
airplanedaj
Fri Jul 24, 2015 1:26 am
The only issue there is how many gates/parking spaces would you have. No passenger airline flies anything greater than a 757 in (do they), but terminal/gate space would be the main issue. As a pilot (commercial student with airline ambitions), I would love more small airports to break up the monotony of 8,000+ ft runways.
asaad11
Fri Jul 24, 2015 9:02 am
There is definitely a need for a single terminal at MCI take for example DL who has 2 separate gate areas for departures...if a gate change has to be made then all pax must exit security and go through it again in the other secured area. There are no shops and very minimal restaurants inside security which could aid in keeping passengers busy when there is an IROP or delayed flights. DL also has two 757's, three airbus, one CRJ 700 that all depart in the first hour of the day which makes for little to no seating for anyone and one mens restroom with two stalls and one womens restroom with two stalls, For 500+ people that is not much at all.
Just my take on it
JBAirwaysFan
Sat Jul 25, 2015 12:58 am
I travel somewhat regularly to MCI. The layout is very O&D friendly, but MCI's location in the middle of the country would make it great for connections. Their terminal layout? Not so much. Though I did notice terminal B is much more open, at least on the WN side because WN does have connecting opportunities there. You don't have to leave the sterile area to go between their gates. I think it's a great airport, but like I said I'm an O&D passenger there, not connecting.
In Loving Memory of Casey Edward Falconer; May 16, 1992-May 9, 2012
MIflyer12
Sat Jul 25, 2015 2:30 am
Construction won't be pay-as-you-go -- there will be bonds sold by the city with the city on the hook.
toltommy
Sat Jul 25, 2015 3:28 am
Except for todays population lives in the suburbs, and the flooding issue.
A300/A310/A319/A320/A321/A332/A333 / 707/712/727/732/733/734/735/738/739/752/753
/762/763/764/772/788/789/DC8/DC9-10/30/40/50/MD81/83/87/88/90/L1011-/250/500/CRJ200/440 /700/900/EMB135/140/145/170/175/190/328Jet/F70/SF3/BE1/J31
N1120A
Sat Jul 25, 2015 6:55 am
Quoting afcjets (Reply 22):
They aren't exactly on top of each other - they even have different roadways.
afcjets
Sat Jul 25, 2015 12:37 pm
Quoting N1120A (Reply 29):
Figure of speech obviously. Looking at the aerial shot in post 2, if you connected the terminals you might could squeeze one or two gates in between them.
compensateme
Sun Jul 26, 2015 1:51 am
It sounds like MCI has reached the end of its useful life. Considering what must be done to renew the building's life -- everything from new roofs to structural reinforcements to replacements of the HAVAC & baggage systems/etc. -- costs can easily climb into the hundreds of millions. In addition to a modern terminal & amenities, new construction has the advantage of reducing annual repair & maintenance, labor, utilities, etc. as well as increasing revenues from concessions. I've never worked with MCI but I'm skeptical of the $1B price tag to renew the building's life although I won't disagree that it's possible new construction would be a better option.
MEM is a great example of an airport that will ultimately pay more to renovate an antiqued facility vs. construction a new one. But MEM was in a more political situation given that new construction would've relinquished 3/4 of its gates (the former NW hub) and its constituents believe that MEM should be able to fill every one of those...
We don’t care what your next flight is.
slcdeltarumd11
Sun Jul 26, 2015 2:46 am
Should MCI even consider connections in their design? I feel like its primarily an o&d airport and will continue to be that even if its one building. This is not a legacy connection city that really needs to consider connections in their design. Doesnt MCI have way way too many gates as is? I think almost any project that the city has to pay for the renovation is a bad idea, to go this big.
This is also the airport where a representative said they needed a modern terminal setup to attract premium routes like a non-stop to Europe. Lets be clear here a new terminal in no way will enhance MCIs chances of a route to Europe, Hawaii, or Asia. The people running MCI seem to want a world class hub airport when its a spoke o&d city you making taxpayers pay for this is bad. If the airport itself can't pay for this over time they are thinking too big.
afcjets
Sun Jul 26, 2015 4:42 am
Quoting slcdeltarumd11 (Reply 32):
Yes, MCI has been a hub at least three times before, if they do not take connections into account in their design that decreases their chance anyone would look twice in the future. Even as an O&D airport, it makes no sense to hire TSA agents for every two gates or however many gates per checkpoint they currently have.
815Oceanic
Sun Jul 26, 2015 6:12 am
In Singapore, every gate or two gates has security screening and that was voted the #1 airport in the world. I've never been to MCI so I am honestly curious, why is the separate screening for gates any different other than the added cost of TSA? In SIN, the gate opens about an hour before the flight and you go through security and stay in the secure area until your flight takes off.
christao17
Sun Jul 26, 2015 6:31 am
Quoting 815Oceanic (Reply 34):
Great question. Let me take a stab at it from my experience with both airports:
SIN has security arrive at a single gate about 1 hour before the flight and then once the majority of the pax have arrived, most of them move on to the next scheduled gate. Gates are fairly close together so not too hard to manage staffing levels.
MCI was remodeled after 9-11 and have about a half-dozen (sometimes more/less) gates per sterile area. With the different levels of traffic, the security areas goes from extremely crowded to very quiet, but a minimum staffing is always required. With these sterile areas spread further apart, it is more difficult to shift staff.
Now, I would argue that SIN doesn't have the most efficient layout; most international airports just have pax go through a central security screening, which is what the new MCI layouts would do.
815Oceanic
Sun Jul 26, 2015 2:36 pm
Quoting christao17 (Reply 35):
Ahh thanks that makes sense! I never liked Singapore's layout but they did do screenings efficiently. But when you have a Cebu A330 with 400 people on it, those screening areas are just not enough. I hope MCI does get a central screening!
afcjets
Sun Jul 26, 2015 5:10 pm
How many gates before then? The last time I flew there was the 1990s and it seemed like each gate or pair of gates had it's own checkpoint.
knope2001
Sun Jul 26, 2015 7:03 pm
Quoting afcjets (Reply 37):
IIRC it was usually 3 or 4, though (as today) some numbered gates don't have jetways and may have use as an overflow aircraft parking spot or for parking for ground equipment. The remodeling over the past 10-15 years or so did create some areas of combined security but the bigger change was installing restrooms and adding services as best they can within security. The restrooms, newsstands and other services within the secured areas today come off very poorly for an airport the size of KCI . But not too long ago even getting drink of water or washing your hands meant leaving security. I *think* all the actively-used gate areas at KCI today have restrooms and some sort of service like a newsstand kiosk, but I'm pretty sure there are unused gates where that's still not true. Most of the cases where separate sterile areas were joined were efforts to better accommodate specific airlines (most notably Southwest and Midwest) being able to handle connections.
As someone who's not KC-based but who has flown in and out of that airport several dozen times in the past years, the big shortcoming is on space and services. No, I don't want nor need for there to be a Brooks Brothers or a L'occitane (though apparently those places do enough business to last at airports). But life behind security at KCI is often about as comfortable as the older terminal at LaGuardia in terms of space and amenities. Life outside of security is worse than LGA because at least they have that huge, relatively spacious food court at LGA. To be fair KCI is frequently not as packed as LGA's B and isn't as neglected as some of LaGuardia's old terminal is. But to me KCI is about as bad as LGA for in-terminal experience.
To be sure, there are other things which often make LGA a worse overall experience than KCI...ATC delays, crowded/overstressed ground transportation facilities, waiting for gates to open up, more overcrowded peak periods than KCI, etc. And there are few (if any) parts of KCI that feel like they haven't had a facelift since Ford was in office. But to grab a pre-flight meal, or cool your heels during a delay, or to get to early in case you can go standby sooner, or meet up with a local friend before you head home, or to talk a walk to pass the time, or to find an open area where you can plug in and recharge a device...it's pretty much on par with the old terminal at LaGuardia in my book.
slcdeltarumd11
Sun Jul 26, 2015 8:00 pm
Its great to see us talking about MCI, not an airport that gets much talk on here, not much going on usually. Its good to see some discussions on MCI
I have always thought MCI is super fast and amazingly easy as an o&d airport. In and out pretty fast out of that place. They already have way way too many mainline sized gates i think they should just renovate. Taking out bonds for a middle sized airport with no hub carrier to help cover the costs makes this a bad idea IMHO. Look at ONT the new terminals raised costs a ton and airlines reduced service. Terminals dont bring in new service it often reduces service if the fees the airlines pay goes up. MCI has no hub and its become much less important to Southwest with the Denver hub, raising costs is a horrible idea and that is how this terminal will be built.
I think MCI should be trying to keep costs as low as humanly possible and add what specifically airlines need to the current design or use the money to bring in new service. A flight to Europe wont happen because of a flashy new terminal, you might get that flight with a large subsidy or revenue guarantees that you could offer if you didnt spend a fortune building new terminals when you already have too much space. Flashy terminals and increased costs will only drive service away. I think southwest is still artificially large in MCI they will shrink more in the future if/when they get more DEN gates on concourse C.
airplaneboy
Sun Jul 26, 2015 8:17 pm
Quoting slcdeltarumd11 (Reply 39):
Southwest has grown in MCI the last couple of years. Their MCI schedule is actually *very tailored* to MCI O&D (take a look). Although they do sell connections through MCI, that station never functioned in the same capacity as DEN. It still remained a very local O&D destination. Every destination WN serves from MCI is in the top 30 markets of most traveled destinations- and the schedules suit locals. Cheers!
2travel2know2
Sun Jul 26, 2015 8:39 pm
Just by seeing the pic, seems an easy way to improve MCI would be to keep the current terminals, make them a full circle and join the terminals to the centre circle with wider connecting structures, widening and/or adding extra floors to any part of the 3 circles if needed.
I'm not on CM's payroll.
FlyingJhawk
Sun Jul 26, 2015 9:42 pm
I've been based in MCI for over 30 years. And while I would love a shiny new terminal configuration the reality is that for people living in the area MCI is an absolute dream airport. I don't hang out in bars nor do I need dining options and really, security for the most part is a breeze. In addition, I've had time that from when the plane landed to being in my car about about 20 minutes - usually it's no more than 45 minutes if I include taxi to the gate, waiting to get off, getting by bags from baggage claim and getting to remote parking. That's awfully nice after a late arriving return from a business trip.
Now would I support higher landing fees for a new terminal. Yes. The vast majority of my travel out of MCI is for business so I won't be absorbing the additional costs anyway.
DiamondFlyer
Mon Jul 27, 2015 3:33 pm
Whatever they do, they've got to keep the costs down for the airlines, lest they end up like PIT or CVG, more empty than they are now. The amount of money they've spent in the last 10 years on renovations in the terminal and building the new consolidated rental car lot, would be wasted, IMO, if they move the terminal to the other side of the airport, like the initial plan had called for.
Personally, I think a centralized non-secure area is the way to go, connecting it to terminal A & B (which could yet again be remodeled). Build the central area, move half the airlines into A (which would be remodeled) and then close B to remodel. When that's done, move everyone into the new terminal and remove C.
-DiamondFlyer
From my cold, dead hands
desertjets
Mon Jul 27, 2015 3:47 pm
I can tell who actually bothered to look at the proposal presentation and those who didn't (or just looked at the pictures).
The biggest takeaway for me is how the current terminal complex would still be bigger in total square footage than the either of the new construction proposals -- but the allocation of space is horribly inefficient in the existing complex. So as far as I can tell the new construction proposals are not going to be for some fancy palace, but rather something more right sized with room for expansion. And it will likely be cheaper to operate.
DiamondFlyer
Mon Jul 27, 2015 3:55 pm
Quoting desertjets (Reply 44):
For what it's worth, the original idea floated a couple of years ago relocated the entire terminal complex to the south side of the airport. I'm glad to see they seem to have moved away from that idea.
-DiamondFlyer
sw733
Mon Jul 27, 2015 4:00 pm
Quoting afcjets (Reply 33):
And in this day in age, when the number of hubs is DECREASING as a result of airline consolidation, what airline would go make MCI a hub? I sure can't think of a single one.
